Old 12-10-2023, 12:34 AM   #365
CBRZY
CBRZY's Avatar
Drives: 2017 BRZ PP (White)
Originally Posted by stanrc View Post
I have the Konig Hypergram 17x8 +40 and I would say technically they do fit. The rubber cap on the bleed valve comes incredibly close though. I put on a 3mm spacer on the front just to be safe.
Super late, but did you need spacers for the back wheels as well?
Would you recommend a 5mm spacer? or 3mm clears them just fine?
thanks!
CBRZY is offline   Reply With Quote
Old 04-03-2024, 11:16 AM   #366
Espi
Espi's Avatar
Drives: 17 BRZ
Enkei RPF1 18x9.5 et38 fit with AP racing brakes
(does this mean it clears brembos also?)
Espi is offline   Reply With Quote
Old 04-03-2024, 12:22 PM   #367
RedReplicant
Drives: None
No
RedReplicant is offline   Reply With Quote
Old 04-03-2024, 05:30 PM   #368
Espi
Espi's Avatar
Drives: 17 BRZ
Originally Posted by RedReplicant View Post
No
Damn thats a huge bummer
Old 04-26-2024, 09:05 PM   #369
Ohio Enthusiast
Drives: 2018 BRZ
Does anyone know if Enkei RPF1 in 17x7.5 ET48 fit? The list doesn't include them in 7.5 width.
Old 05-01-2024, 08:57 AM   #370
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
No, I don't believe the 7.5" width fits. The 9" also doesn't clear due to the shape of the spokes. However and magically the 8" width does clear just barely, again because of the curve of the spokes.
Go with the 8" width if it's a street car and you're not trying to stick to some rule set like for autocross. I know in street class RPF1's are what a lot of people run due to the weight and going up to an 8" wheel isn't an option.
cmiovino is offline   Reply With Quote
Old 05-11-2024, 12:57 AM   #371
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
Does anyone know if the STI 17”x7” wheels will clear the PP Brembo kit with a spacer? If so, what’s the minimum size spacer I would need?
TIA
jbsali is offline   Reply With Quote
Old 05-11-2024, 02:09 AM   #372
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Are the 2018 Brz tS brembos same as the 2024 GR86 trueno?
I assume that the 18” Sti on the 2018 tS will fit nicely the 2024 gr86 but who know if they changes anything.
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 05-12-2024, 12:02 PM   #373
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
The 2024 tS are identical to the trueno except color; not sure about the 2018
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 05-12-2024, 06:37 PM   #374
RedReplicant
Drives: None
yes
Old 10-24-2024, 02:19 PM   #375
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Another one to add:
Konig F3S forged 17x9" ET42 will clear the Brembo's according to Konig customer service (I inquired by email).
Tatsu333 is offline   Reply With Quote
Old 10-24-2024, 02:25 PM   #376
TheBatman
TheBatman's Avatar
Drives: Scion FR-S 10 Series
Adding the to the knowledge base, I learned the hard way that Enkei RPF1 18x9.5 +38 DO NOT fit.
Even though many other versions of the RPF1 do fit, this particular variant has extra concavity to the spokes. And while this does look great, it causes the spoke to interfere with the inside edge of the caliper.
I did eperiment with spacers, here is a pic with a 5mm spacer...
with the 5mm spacer, it is still just barely touching. You could maybe get away with a 7mm spacer, but I feel 8mm minimum is necessary. The problem is with 8mm, the effective offset is +30, so you get a lot of poke and you would have to add a good amount of camber.
I ended up getting a new set of wheels. Will make a separate reply.
TheBatman is offline   Reply With Quote
Old 10-24-2024, 02:40 PM   #377
TheBatman
TheBatman's Avatar
After finding my RPF1's not to fit, I replaced them with a set of Work VS-XX
Fronts are 18x8.5 +32 [A-Disk]
Rears are 18x9.5 +39 [O-Disk]
The rears fit no problem, but the fronts require a 6mm spacer for proper clearance.
This actually works out nicely as it brings out the wheel so the outer fitment matches the rear.
Old 04-10-2025, 06:11 PM   #378
vin61k
vin61k's Avatar
Drives: 2018 BRZ 6MT
TE37SL 18x9.5+45 fits with 3mm spacer.
Does NOT fit without spacer.
vin61k is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
