Old 04-13-2016, 12:09 AM   #3711
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Originally Posted by MaximeT View Post
The spec says it works from 8 to 9.5in wheels (page 23) :
https://www.hoosiertire.com/pdfs/speccat.pdf
From the spec too, it's 261mm wide (10.3in). dunno if it fits. Looks like a lot of tire.
Your specs listed are for the 245/40ZR17? The 45ZR17 is a bit different sizing.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 04-13-2016, 03:06 AM   #3712
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Dunno, the Hoosier site is kinda confusing.
They are race size tires named with road car sizing. Which is a bit stupid.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 04-13-2016, 07:36 AM   #3713
Bramick
Bramick's Avatar
Adding this tire to my research list. Maxxis VICTRA VR-1 http://www.ft86club.com/forums/showthread.php?t=103625
Old 04-17-2016, 10:48 AM   #3714
ZionsWrath
Thanks
ZionsWrath's Avatar
Anyone running the Jackson Racing oil cooler?
I'm looking for a recommendation for a thin socket to tighten it.
I am having some minor leaking and I am pretty sure it is because it's not tight enough. The socket I have doesn't fit in the VERY SMALL gap so i was very careful and gentle tightening it so I wouldn't round the edges.
Anyway I'm thinking after a bunch of oil changes it might have loosen a bit and I want a socket that will fit over it properly so I can tighten it properly.
Old 04-17-2016, 05:25 PM   #3715
DarkSunrise
DarkSunrise's Avatar
Might consider a local machine shop. When installing my Perrin oil cooler, I brought my socket in to put on their lathe. I had to ask them to thin the wall out a lot to make it fit, but they did a great job and only charged ~$15.
2022 BRZ Build
2013 FR-S Build
Old 04-17-2016, 11:34 PM   #3716
superpenguin
Some Random
superpenguin's Avatar
Drives: 2015 FRS
Hey CSG Mike, what are your thoughts on putting the Edelbrock blower on a track-only car? Michele is running one on her racecar and haven't heard about any engine problems yet, but no idea how much whp she's running.
"You see, nursie, men love women. But even more than that, men...LOVE...CARS!" - Rush
2015 FRS NASA AZ #550
superpenguin is offline   Reply With Quote
Old 04-18-2016, 01:57 PM   #3717
I don't have enough data to say yet.
The Jackson Racing has been proven to be solid on track.
Old 04-18-2016, 01:57 PM   #3718
Use a 12 point socket and hold it in place, as you tighten.
Newer JROC kits have a machined sandwich plate to let you use a normal socket.
Old 04-19-2016, 11:50 PM   #3719
Bramick
Bramick's Avatar
What size is that, 27mm?
Old 04-20-2016, 03:02 AM   #3720
Correct, 27mm,
Old 04-20-2016, 03:06 AM   #3721
Based on Oscar's video posted yesterday, it looks like the Edelbrock/Ace combo is making a bit more power than the JRSC/Tomei combo in a straight line. However, Oscar did get around Michele and ended up winning the race.
Just another data point; it's not perfect because the cars are not set up with identical supporting mods. I don't even know if they're running the same race fuel.
On the flip side, neither car is overheating, since they both clearly finished the race without issue. This bodes well for both setups!
If you want tried and proven, I'm still gonna recommend the JRSC; the Edelbrock is still a new player in the game. On the other hand, if you want to potentially have more power, purchase the Edelbrock from CSG, and you'll still have our full support.
Old 04-20-2016, 04:03 PM   #3722
Uplink
Uplink's Avatar
Drives: anything you let me
On the street I'm currently running:
18x8.5 Rota Grid - Flat Black (5x100/e44/73) on 235/40ZR-18 MICHELIN PILOT SUPER SPORT XL (Fatty setup)
I'd like to pick up a track set of wheels/tires. The plan is to trailer and swap at the track while keeping my alignment and suspension setup the same, with the exception of tightening the dampeners (Tein Flex Z). Perhaps one day I'll update the suspension and convert this car to a dedicated tracker.
Quick note. I'm running a JRSC.
For now I'm looking at the
ENKEI RPF1
or
JR 949Racing 6UL (leaning towards this)
What width and backspacing do you recommend? I'm open to staggered sizing.
Any tires suggestions to research?
I've been extremely happy with Enkei RPF1's in 17x8.5 +45mm (which are 1.5lbs lighter each than the 6UL's) with 245/40-17 Direzza Star Specs. I daily them, drive straight to the track, hot lap, and drive home.
The assembly is only 4oz heavier than stock at each corner, the SS's are cheap enough to bring one to the track as a spare (sits high in the spare well), clears the AP Racing Sprint Kit up front with no spacer, and are a joy to drive.
Uplink is offline   Reply With Quote
Old 04-20-2016, 04:44 PM   #3723
Uplink
Uplink's Avatar
Tried to register but seemed I miss the deadline by 2 days.
I guess my car isn't prepped for the season anyway. Need alignment. Oil changes. tires.
I signed up for friday the 15 at NJMP with NASA. Unfortunately I have to work the weekend so I cant do the 3 days. Also ordered some oil, AD08r and working on getting alignment. And hopefully fix my AC
You gonna be there next weekend?
Ugh, what a crazy week.
The event was awesome. Even with temps in the 30's, snow the day before, and some slick water/ice in T3 & T7 I had an awesome time and still managed to turn condition respectable 1:21.2's... before discovering my freshly installed Perrin Oil Cooler thermo-plate started leaking. Only lost about 1/4qt during the session and it was all contained on the airbox and undertray so no safety issue. Didn't leak with normal rpm's so the car made it home but my concern was more about pressure loss. Luckily it was only in one session and I caught it.
(Side note, anyone know how tight to make this thing? Thought it was pretty tight, didn't want to crush the gaskets/O-rings, and it made over 300mi before it finally leaked with no prior indication and doesn't leak during normal driving.)
Got home late Sunday night, Monday there was a death in the family so it was down to FL for a few days to take care of things. Couldn't make the following week but a few friends were there for NASA comp school/race. I spent the weekend working around the house.
I'm scheduled for Palmer on the 2nd then maybe Thompson or Lime Rock towards the end of the month.
Old 04-22-2016, 05:21 PM   #3724
jdmblood
jdmblood's Avatar
Drives: white subaru brz
@CSG Mike
Hey Mike can you help me out with adjusting tire pressures? Ive been to a few track days already and still haven't figured out a formula on it. Still kinda clueless on the whole thing. Got a track day tommorow!!!
jdmblood is offline   Reply With Quote
