Old 03-07-2014, 05:17 PM   #3683
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Very nice!! Love seeing quality fabrication!
Jesse@JDLAutodesign is offline   Reply With Quote
Old 03-07-2014, 05:25 PM   #3684
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
could it be a plug for the sound generator hose in the intake elbow?
2superblus is offline   Reply With Quote
Old 03-07-2014, 05:27 PM   #3685
raven1231
I thought that too but why?
Old 03-07-2014, 05:30 PM   #3686
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Maybe the header comes up into that area? I have not yet seen any pics of it installed, but it looks like that may be the case.
Decay107 is offline   Reply With Quote
Old 03-07-2014, 05:30 PM   #3687
xjohnx
Grip>Slip
xjohnx's Avatar
Perhaps it interferes with the header piping that comes up to the engine bay?
I'm not so much worried about the plug, i'm sure they can tell me where that goes pretty easily. I'm more concerned about the rumored 9-12" lifting of the motor. 1-2" for the overpipe is one thing, but 9-12? That's HUGE.
Old 03-07-2014, 05:32 PM   #3688
Decay107
Decay107's Avatar
Agreed, was planning on lifting the engine and installing motor mounts with this piece anyway, but lifting the engine 9" makes me a bit uncomfortable.
Old 03-07-2014, 05:36 PM   #3689
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
There is simply no way you have to lift the engine that far if at all for this header. Whoever told you that is fucking with you
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-07-2014, 05:39 PM   #3690
Thatruth2001
Drives: Raven FR-S
Originally Posted by WatchmaN View Post
when you say it sits 6" from the crank pully, you mean it goes away from the crank to the front of the car, does it go higher than the crank?
Anyway I need a good picture top view looking at the crank pully. ;-)
Sits more like 4" in front and 3-6" above the crank pulley.
Thatruth2001 is offline   Reply With Quote
Old 03-07-2014, 05:39 PM   #3691
xjohnx
Grip>Slip
xjohnx's Avatar
I hope so! I just heard back from John @ Nameless. It doesn't sound too bad.
For those who have (or might have) similar questions over the next couple days, here was the response:
The plug is to block off the resonator on the factory intake just before the throttle body on the bottom of the runner hose that attaches to the intake.
Installation is simple. Unbolt the passenger side engine mount and lift the engine up (leave the driver side mount attached) until the passenger side stud is about 1/4" above the surface of the subframe. Remove the factory manifold, then install your new manifold. The new one fits in, it just goes in a very specific way that you have to find by putting it in and moving it around.
Old 03-07-2014, 05:46 PM   #3692
Ryan@Nameless
Ryan@Nameless's Avatar
Drives: 2014 SWP BRZ Limited
John just sent that to me as well, but here it is
"The plug is to block off the resonator on the factory intake just before the throttle body on the bottom of the runner hose that attaches to the intake.
Reuse the header gaskets that you took off with the factory manifold."
-Ryan @ Nameless
Ryan@Nameless is offline   Reply With Quote
Old 03-07-2014, 05:51 PM   #3693
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
ouch
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 03-07-2014, 06:03 PM   #3694
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
The way the header is shaped, it certainly looks like it could, or at least come close enough to melt the plastic since the resonator on the underside of the intake tube hangs down a good 3-5 inches.
raul is offline   Reply With Quote
Old 03-07-2014, 06:23 PM   #3695
14BRZ
14BRZ's Avatar
Drives: 2014 BRZ, 08 CBR600RR
Engine mounts don't need to be loosened to install. I just unhooked the passenger side fan connection and moved it out of the way and moved the overpipe back a few inches and it cleared just fine.
Don't mind the iPhone pics. Install was pretty easy and the header is pure porn
14BRZ is offline   Reply With Quote
Old 03-07-2014, 06:28 PM   #3696
FrsDuke
Fanboy
FrsDuke's Avatar
The fan looks alarmingly close... Seen turbo manifolds melt those, but presumably they also get much hotter.
TL;DR:
-Duke
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
