Old 04-16-2016, 12:30 AM   #351
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Originally Posted by Dru670 View Post
So has anyone tried this on their non-ofh uel header?
Running now on gruppe-s uel. All is well. Can feel a difference in butt dyno. Would recommend but watch the numbers.
ajcarson11 is offline   Reply With Quote
Old 04-16-2016, 12:42 AM   #352
tCsonfrs
Drives: 10 Series FR-S #207
This is like Christmas, feels like I've been waiting that long! lol
tCsonfrs is offline   Reply With Quote
Old 04-16-2016, 01:08 AM   #353
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by RedFRS4me View Post
Dude I just told you. Stoich is 14.7:1 and at idle and cruise its dropping below 13.5 and now even lower than that. Ive been running oft for awhile i know when my afr is off. Get off your high horse. This started happening after running the new tune with my OFH.
You literally said "higher numbers are leaner"
Old 04-16-2016, 01:21 AM   #354
JB86'd
JB86'd's Avatar
Drives: JAWS
Originally Posted by OkieSnuffBox View Post
See, now you've proven you don't know what you're talking about.
The door is over there ----->
You do realize he said Open Loop he's seeing 13's and 14's and running rich right?
The OFT tunes are set to run around 12 Open Loop, hence why he'd actually be running lean.
BUT, I believe he confused closed loop and open loop.
Old 04-16-2016, 02:03 AM   #355
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
Originally Posted by cawith View Post
Say I want to try those new maps on my european GT86 running A00G, would I just have to change the following 12 tables @jvincent ?
Primary open loop fueling
Engine Load Limit B Maximum (RPM)
Engine Load Limit C Maximum (RPM)
Base Timing B
Knock Correction Advance Max A
Timing Compensation (IAT)
Timing Compensation Per Cylinder A
Timing Compensation Per Cylinder B
Intake Cam Advance Angle Safe AVCS
Intake Cam Advance Angle Normal AVCS
Exhaust Cam Retard Angle Safe AVCS
Exhaust Cam Retard Angle Normal AVCS
I find it quite hard to compare the new stage 2 map with my current one because Shiv states that those should only be edited with their supplied XMLs, and usually I use Kodename's template. Therefore a lot of tables are missing or placed somewhere else...
Hope somebody can help me
Did you got it working on the A00G rom? because i'm on that rom too.
If so , can you send it to me?
otherwise i have a go myself.
ST-A is offline   Reply With Quote
Old 04-16-2016, 02:30 AM   #356
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
Feel bad about asking this here but this thread has lots of activity. My Gruppe S header is sitting on my coffee table, begging to be bolted on. Problem is Ft86speed factory took 5 days to ship my OFT and now it won't get Here till Monday/Tuesday. If I go ahead with the install tomorrow, will it mess with the stock tune and thus the OFT will save a sort of ill-running stock tune when I plug her in upon recepit? Or should it all be fine and I just go ahead and install header and flash when my OFT arrives?
Thanks for any answers and sorry for asking here....
ajaxthebetter is offline   Reply With Quote
Old 04-16-2016, 02:35 AM   #357
FRSBRZGT86FAN
Nothing "messes" with the stock tune so don't be afraid you can go ahead and install it. You'll just get a CEL after install which will be easily cleared when the OFT arrives.
To prep for your OFT however download the openflash manager:
http://www.openflashtablet.com/downloads/
and also those other two things below
Old 04-16-2016, 07:39 AM   #358
elBarto
elBarto's Avatar
Drives: Toyota GT86
I already run it on my A00G Euro GT86, you open the B01C rom with the correct definitions, open your AxxG rom and copy the tables mentioned above.
Flash and go
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 04-16-2016, 07:49 AM   #359
steve99
Flash and go
Guys just be careful @ST-A is using tactrix so his A00G rom is a real A00G rom @elBarto is using an OFT A00G rom which is rearly an A01G rom calid hacked to look like an A00G.
now with those two rom is ok as defs are compatible from memory but just be careful , its not always the case :-)
Old 04-16-2016, 09:37 AM   #360
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
Originally Posted by oldgunfan View Post
When you log make sure you tell your OFT to log AFR and command AFR throttle, RPM, MAF volt and so on. When your LTFT's start running below 5-ish maybe 3 do a 3rd gear pull at WOT and watch your command AFR. You want your AFR to match as close as u can.
I think something happened when i transitioned from e85 to the new ofh tunes. I took the car for a spirited drive to burn the rest of the e85 and it may have killed my o2 sensor. My STFT are 0 while my afr is between 12.5-13.5 while idle or cruising. When the car is cold it is normal but as the car warms up it goes rich and stft go zero no matter what throttle input.
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 04-16-2016, 11:15 AM   #361
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Ok, that doesn't sound right. like what others have said at idle and just off idle(just putting around) it should be in the high to mid 14's. I don't know why just flashing a tune would kill your O2 sensor but hope you can fix it.
oldgunfan is offline   Reply With Quote
Old 04-16-2016, 04:26 PM   #362
oldgunfan
oldgunfan's Avatar
Just did a 3rd and 4th grear pull. feels good and data looks close maybe just a little tweeking. Tell me what you think. http://datazap.me/u/oldgunfan/new-of...a=1-2-3-5-9-14
Old 04-16-2016, 04:42 PM   #363
FRSBRZGT86FAN
It looks fine on the safety front, you're IAM is steady at 1 and you have 0 knock correction throughout the entire log. AFR is getting close to 11 under load but I think it's fine because the rest of the time it goes above 12
Old 04-16-2016, 06:27 PM   #364
Dru670
Drives: 2016 Scion FR-S
I wonder if this tune would be produce less lower in temps above 80F compared to the older tune...I live in Vegas and it is almost 100F+ time in the summer.
Dru670 is offline   Reply With Quote
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
