#351 |
Drives: 86 GT
Was posted in another thread but more relevant here, does anyone know the RAM address for the second 02 sensor on an A01G rom?
#352 |
Drives: 2013 ultramarine Scion FR-S
I noticed the 'load' value for B01C Roms is in g/s whereas the ECU tables are in g/rev. I've made a script to produce a new load value based on MAF and RPM, but am curious if the ECU has an address for load in g/rev.
#353 |
Drives: UK GT86
All load is g/rev. It's probably just a type error.
.: Stealth 86 :.
#354 |
Drives: Toyota 86
#355 | |
Drives: 86 GT
paramname = AFR2 paramid = 0xFFF8D274 isfloat = 1 scalingrpn = x,14.7,* paramname = AFR3 paramid = 0xFFF8D278 isfloat = 1 scalingrpn = x,14.7,* |
#356 |
Drives: Toyota 86
Off OBD Mode 01, PID 15, I'd expect D274 to be sensor volts reading between 0-1V (scaling rpn=x); 1V is rich, 0V is lean. Expect D278 to be AF3 trim (scalingrpn=x).
#357 |
From the logs it looks to be similar in magnitude and value as the MAF logging, so I assumed the issue was related to that.
I'd much rather have a log of load than be calculating it. I guess doing the math with someone else's log could help me determine if my math is right. Where would I start looking to fix this? |
#358 | |
Drives: UK GT86
What file are you using for logging? Plenty of info on here to check the correct load parameter.
.: Stealth 86 :.
#359 |
I got addresses from the 'b01c' addresses file. I can't remember which of the other files I started with, but there were a few things which needed to come over from the addresses file.
#360 | |
Drives: 86 GT
paramname = AFR2 paramid = 0xFFF8D274 isfloat = 1 scalingrpn = x paramname = AFR3 paramid = 0xFFF8D278 isfloat = 1 scalingrpn = x http://www.datazap.me/u/dave/rear-o2...g=0&data=29-30 |
#361 |
Here's my current log config: http://pastebin.com/tNTbKqzK
#362 | |
paramid = 0xFFF8DB84 isfloat = 1 assuming that ram address is correct for your rom type your reading the "load" from the ECU it calculated by the ECU and not scaled by the tactrix ie no scaling is applied to value read from ECU. The values you should range from almost 0 at idle to about 1.3 full throttle under load |
#363 |
#364 | |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
