Old 01-19-2017, 06:05 PM   #351
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by SHWNBRZ View Post
I'd say that the lip of the wheel is pretty flush. The top of the tires tuck into the fenders. Some people would say that the setting sits flush. I say otherwise. There's a sidewall poke...though the tire treads tuck into the wheel well.
Edit:
My steering wheel was straight when I took the photo so there shouldn't be any more/less poking going on in the shot(s).
I have the same wheel spec with 255/40 Conti DWS. Definitely pokes a bit, but I like it. Tiny bit of poke with some camber gives the car a slightly wider and more aggressive stance (in my opinion).
Definitely like it better than the +45 offset wheels though.
PandaSPUR is offline   Reply With Quote
Old 01-19-2017, 08:30 PM   #352
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
I knew I wasn't going with wider tires (wider than 245's) before getting the set of +35's. I've seen the minimal poke of the same wheel setup that I have last summer and I thought it's acceptable.
If I were to go with wider tires, I'd have gone with the +45 and added a 3mm spacer to avoid tie rod rub.
I was torn between the RPF1's and the MachV Awesomes in 17x9 +42.
I decided to go with the RPF1 17x9 +35's for a few reasons.
I wanted to see what having a lighter wheel/tire setup would feel like.
Was pretty dead set on MPSS' and they don't come in 255/40's...
I didn't want to have to deal with spacers (so I didn't get the +45) to avoid tie rod rub on full lock.
No extra holes on the wheel from a different bolt pattern.
If the Mach V awesomes didn't have the extra holes for the 5x114....it'd have made things a lil more tougher to pick between the two. I may have gone with it cause it'll keep the tires from poking out better...plus the ability to fit a BBK. If I get bored of the RPF1's, I may get a set of awesomes along with some DWS06's or P Zero AS.
SHWNBRZ is offline   Reply With Quote
The Following User Says Thank You to SHWNBRZ For This Useful Post:
smg1138 (01-22-2017)
Old 01-19-2017, 08:47 PM   #353
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Size: 17 x 9
Offset: +35
Color: Bronze
Tires: Continental ExtremeContact DW
Tire Size: 245/40/17
Drop: H&R Super Sports
FatFree is offline   Reply With Quote
The Following User Says Thank You to FatFree For This Useful Post:
korhun (06-16-2019)
Old 01-22-2017, 02:59 PM   #354
BOEING
Drives: GT86
Originally Posted by BOEING View Post
Hi, I am looking to get the most of performance out of my car and would use some recommendation, around what wheel and tyre specs would give the most of it? Considering of buying rpf1 17x8, but not sure whether to go for +35 or +45 ET. First one definitely looks better, but does it handle better and will it put more wearing on the suspension? I am currently running on stock height.
Anyone?
HKS UEL manifold
Milltek overpipe
Berk frontpipe with 200 cell cat
iNvidia Q300 catback exhaust
JBL OEM sound system
BOEING is offline   Reply With Quote
Old 01-22-2017, 03:17 PM   #355
Blucifer
Blucifer's Avatar
Drives: 2013 Ultramarine FR-S
Anyone?
For +45 17x8 is pretty much identical to stock wheels. Stock is 17x7+48? At +35 it should make you sit more "flush" as it pokes your wheels out more fitting the space better imo. 17x9+35 is the way to go though. There should not be any additional wear of any kind on stock height.
Blucifer is offline   Reply With Quote
Old 01-23-2017, 10:49 PM   #356
SHWNBRZ
For those wondering what having the 17x9 +35 with 245/40's on -2.0 camber up front....0 toe. Steering wheel was straight for the shot. I'm dropped about 1.2" from Tein Flex Z's. Everything else is stock. No additional camber bolts and what not.
Note the angles of the shot. The fender doesn't go straight down...it's angled...you can see how the tire tucks in relative to the angle of the fender's flat part.
FatFree (01-24-2017)
Old 01-24-2017, 01:12 AM   #357
FatFree
FatFree's Avatar
Awesome, thanks for this man. That looks good.
Old 01-24-2017, 01:18 AM   #358
SHWNBRZ
Thanks! I'm glad my posts here are of some help....on the Facebook enthusiast page...not so much. Lol!
Old 01-28-2017, 06:43 AM   #359
isuckatusernames
isuckatusernames's Avatar
Drives: 2013 Pearl FR-S
Looks like a complete 5axis kit.
That is correct. I love it...minus the fact that even re-applying it with 3M tape, it doesn't stick 100%. :/
isuckatusernames is offline   Reply With Quote
Old 01-29-2017, 02:47 AM   #360
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
Where can we source Enkei GOLD touch up paint for the RPF1s ?
(tried searching, no luck yet)
anyone got a source or a color code ?
canyons is offline   Reply With Quote
Old 02-04-2017, 07:15 PM   #361
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Tried searching but anyone on 245/45R17 MPSS?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 02-04-2017, 08:38 PM   #362
canyons
canyons's Avatar
Smile FOUND: Touch up paint for gold RPF1s
Enkei refuses to sell customers touch-up paint in its "secret recipe" colors. This is a lost revenue opportunity and pisses off their customers.
So I searched around and found this touch-up pen in a 99% match for Enkei Gold, see pics below. It's an old Subaru OEM color. Pen costs about $20 shipped. It's crazy how much enkei's paint color appears to shift based on lighting conditions.
Every paint vendor has their own blends, some match better than others. This particular one is really close. YMMV!
link: http://www.2-tip.com/products/2tip-1308-35681
UPDATE: Second source, 99.9% match !! http://www.ebay.com/itm/172311854193
Old 02-04-2017, 08:42 PM   #363
canyons
canyons's Avatar
Yes, running 245/45R17 MPSS on 9 inch rear wheels. Fronts are 225/45 R17 8" wheels.
here's another angle: http://imgur.com/szaFody
Old 02-04-2017, 10:13 PM   #364
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
I've been looking for bronze for almost a year now
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question Victor Draken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-19-2013 02:28 PM
Track wheel Enkei RPF1 in 16" ?? stockysnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-07-2013 10:13 AM
