Old 12-26-2011, 10:42 PM   #351
igorot
Sneakerhead
igorot's Avatar
Drives: 2003 Honda Civic Si
For daily driving, running knocks off will work just fine for me. the story behind most of the broken rotas and other knock offs have been falsified through the grapevine. I've seen rally cars running rotas for whole seasons with no problems in person. For daily driving, id rather curb a rota than other wheels. Dont get me wrong, I'll probably have a set of brand wheels laying around for shows.
Btw, this is an OEM Toyota wheel manufactured by Rota
igorot is offline   Reply With Quote
Old 12-26-2011, 10:51 PM   #352
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Uhhh.. Weds Sport makes a lot of their wheels in 5x100.
Ahh my bad I only enquired about the SA60M and those only come in 5x114
Good to know those SA70 come in 5x100 but I stil really really want SA60M
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 12-26-2011, 11:06 PM   #353
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
What wheel is that? Where does it state made by ROTA?
Just curious is all
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-26-2011, 11:11 PM   #354
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Just curious is all
toyOTA
rOTA
duhh!!!
I keed I keed
Snoopyalien24 is offline   Reply With Quote
Old 12-26-2011, 11:16 PM   #355
JDLM
JDLM's Avatar
So I did some digging, Rota is an OEM supplier to Toyota ..but no where near the US ha ha ha (along w/ other companies)
Old 12-26-2011, 11:52 PM   #356
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
WORK Emotion Kiwami 18x9.5 Super Concave Face
poormans_LFA is offline   Reply With Quote
Old 12-27-2011, 01:53 AM   #357
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Originally Posted by poormans_LFA View Post
pays to up the big $$$$
http://asiangiant.wordpress.com/2011/11/14/failure/
or you can pay even more for repairs. choice is yours.
That article is
Quoting among the crap in NASIOC:
originally posted by wtwwholesaletire
I think XXR is kind of getting a bad rap here. We have sold them since they where Essenza wheel back 13 + years ago we have sold thousands.They are made by Primax wheel co and make 2.4 million wheels per year and have been in buisness since 1976.Guys they are not some fly by night junk wheel! They are also Tested to the Japanese VIA standard
Here is a brief outline of testing to JWL spec:
Cornering Fatigue Test (Drum Endurance Test)
The purpose of this test is for checking wheel rim strength and durability. Place a wheel assembly with tire on test equipment. Radial stress is then added to simulate vehicle weight.
Test run 500,000 cycles
After 500,000 cycles inspect for cracks, deformation and any nut loosening.
Radial Load Fatigue Test (Rotary Bending Test)
JWL pass criteria: 100,000 cycles
The purpose of this test is for checking durability of the wheel disc. The spokes and the hub are the first point of weight distribution from the vehicle and spoke strength is gauged by this test.
Place a wheel on testing equipment and by adding bending stress to center of disc –
Test run 100,000 cycles
After 100,000 cycles, inspect for cracks, deformation and any nut loosening.
13 Degree Impact Test
JWL pass criteria: 594 kg
The main purpose of test is for checking strength between rim and disc cross section. The “joint” or the area where the spoke and the rim meet is an important structural area that is subject to great stress. The horizontal weight of the rim and the vertical stress of the spokes meet at this joint and proper structural stability is crucial for a proper wheel.
The wheel assembly is placed with tire tilted 13 degrees from horizontal plane on testing equipment.
A preset weight is dropped on the outer sidewall of tire, thus giving impact to the wheel/tire. Then inspect for cracks, deformation and air leak.
This test is very important for the recent trend of a larger/wider wheel with lower profile tire combination, because there is less air volume than OE wheel/tire and more stress to inner rim section. This test simulates actual usage condition such as hitting corner curb or objects from side.
In Chicagoland we have the nations worst potholes and these have held up as good as any and better then alot of light weight high dollar stuff.Are they top of the line/? no, but they are much better quality then some of you seem to think...
and for the rota haters, check out quotes from race companies that run them:
Originally Posted by GST Motorsports
You're right, they hardly ever see abuse (offs at 130mph, jumping curbing), never see more than 2-3 laps (Thunderhill 25hr Enduro and NASA weekends) and we go through them like water (Haven't bent one yet). Damn. I guess we picked the wrong wheels.
Please don't buy any.
-Bryan
Originally Posted by Turn in Concepts
Money no object for road racing? Forgelines.
We have been using Rotas for 8 year on track and have never had a break or issue. We ran them for the 25 hours of Thunderhill last year and had no issues. Even after getting hit by a Honda (hit was wheel to wheel) the wheel survived and ran for another 2 hours. It wasn't until we came in to pit and change wheels that we saw the damage.
Tony
Originally Posted by LICmotorsports
I must say we have had zero issues with our Rota's...in fact www.wheeldude.com is more than helpful with any and all of our requests. We have yet to have a broken wheel or bend a wheel, typically we don't need a lot of weights, in the rare instance we do need what I would consider more than usual; in all fairness that can be the yahoo who doesn't mount the tire in the appropriate spot. <-- most often the case.
we run Rota DPT 18x10 +35 5x100/114.3 and I believe if I'm not mistaken the weight is 22lbs (I'm sure dan can chime in and say otherwise but thats the number I recall when weighing them). A Enkei RPF1 in that respective size is just about 20lbs. Yes 2lbs of unsprung weight per corner is A LOT when it comes to motorsports (as it effects braking, response, etc...) but dollar for dollar would you say they are that much better or Rota's are that much less? I for sure don't have the answer to that for everyone, we have either run Volk's or Rota's and currently we run Rota's. Best quality/value dollar for dollar in my opinion.
-Noah
chulooz is offline   Reply With Quote
Old 12-27-2011, 02:16 AM   #358
igorot
Sneakerhead
igorot's Avatar
Just curious is all
http://forums.evolutionm.net/9169070-post56.html
Old 12-27-2011, 09:03 AM   #359
JDLM
JDLM's Avatar
I already uncovered it and it isn't a US market wheel
Old 12-27-2011, 09:10 AM   #360
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by chulooz View Post
That article is
I've run Rota's since 2002? or so, have tracked them, have gotten into a wreck with them (road surface was wet, changed from asphalt to cobblestones, I was too tired to realize the lack of traction I'd have.. doh. lesson learned.. resulting in slamming both left wheels over a curb at 35mph), have hit potholes enough to blow a tire, etc.. none of my slipstreams were bent.
I run slips on the ITR too. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-27-2011, 12:22 PM   #361
madfast
Drives: 2010 Evo X MR-T
rotas are fine, as fine as any other quality low pressure cast wheel. that's not the problem. the main problem is the design. they are, and always will be, known for their knockoff designs. to some that's just unforgivable. a knockoff is a knockoff no matter how good the quality. secondly, you can get high quality enkeis for not that much more. the enkeis would be lighter, stronger (MAT process), and above all else not a knockoff design.
madfast is offline   Reply With Quote
Old 12-27-2011, 12:30 PM   #362
igorot
Sneakerhead
igorot's Avatar
yehp, but for people without the same financial opportunities as others, they will be fine for use. personally, ill rock them to beat up and not feel so bad when i accidentally curb or hit a pothole.
ultimate goal: bbs rs
Old 12-27-2011, 12:31 PM   #363
poormans_LFA
FT86Club.com O.G.
after taking a good look @ the WORK line I'm thinking that's a really good brand to consider.
Old 12-27-2011, 12:34 PM   #364
JDLM
JDLM's Avatar
I did notice you posted a few of them (always like the line up) I got a car sponsored by them back in the day and ran Work Emotions awesome wheel
How to embed a YouTube video in a post ichitaka05 Site Announcements / Questions / Issues 71 03-21-2021 03:47 AM
Post your Workspace. Ricepuddin Off-Topic Lounge [WARNING: NO POLITICS] 10 11-25-2014 10:15 AM
Post your Desktop Ricepuddin Off-Topic Lounge [WARNING: NO POLITICS] 125 10-10-2013 02:38 PM
Any news or updates for Oz post here Calais AUSTRALIA 92 07-28-2011 06:55 AM
