Old 05-30-2013, 10:39 PM   #351
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by JordanInnovations View Post
The last kits we've gotten have all had the new aluminum BOV's. I'll see if I have a pic, they're really nice - machined look, black finish, looks a lot like that Turbosmart one but with no branding on it. Certainly no need to buy a replacement.
Thats odd, I always thought they included the plastic BPV on all of their kits
Do you think its a permanent change in valve styles?
2013 FRS
Vortech V3 11psi
Old 05-30-2013, 10:55 PM   #352
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
My kit didn't come with a plastic one, it actually came with this turbo smart one http://www.turbosmartusa.com/product...-universal-fit
I received my kit just after they switched to the new blower so I don't know if they might have switched this as well.
reyruiz191 is offline   Reply With Quote
Old 05-30-2013, 11:16 PM   #353
DJCarbine
Thupercharged
DJCarbine's Avatar
I have the plastic valve in the upper left
Its gotta cost more for the turbosmart valve, I wonder why some kits come with them instead of the plastic...
2013 FRS
Vortech V3 11psi
Old 05-30-2013, 11:55 PM   #354
Foobar
SLO NO MO
Foobar's Avatar
I have the plastic Bosch one. Ordered after the upgraded compressor came out.
Old 05-31-2013, 12:37 AM   #355
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Mine is plastic too. Got the kit at the beginning of May.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-31-2013, 02:06 AM   #356
Dezoris
Dezoris's Avatar
It was probably a alternate sourced part when they had a backorder on the Bosch part just to keep shipping.
Old 05-31-2013, 03:03 AM   #357
JordanInnovations
Drives: Forced Induction and LSx Swaps!
You guys should know it's not a like a turbo BOV, which has to seal and open at certain times in order to protect the compressor ~ since the blower's compressor speed doesn't drop as fast as a turbo (tied to RPM's) you never get the surge like you would on a turbo.
That bypass valve lazily opens using cruise to vent the extra air the blower is moving but the engine isn't using, then closes pretty quickly once you step on the gas. I didn't have any problem with either unit, and liked how light the plastic one is. I certainly don't think there's any reason to think you'd have to upgrade, just wanted to note that the black aluminum one looks nice haha.
JordanInnovations is offline   Reply With Quote
Old 05-31-2013, 08:33 AM   #358
DJCarbine
Thupercharged
DJCarbine's Avatar
Both the bypass valve and this blowoff valve are open and venting until you give enough throttle for the manifold to see zero/positive pressure, in which case it is closed and you begin to see positive pressure
A blowoff valve like the greddy type-RS would work in the same fashion as it is simply a push type valve. An HKS style SSQV would not work properly as it is a pull type, and it would likely be sealed at idle/cruise and cause issues as it will not let the excess air bleed off.
I would not say that you never get compressor surge with a centrifugal, in fact I would say its very easy to get surge... just remove the bypass valve. Of course, don't do that....
2013 FRS
Vortech V3 11psi
Old 05-31-2013, 09:27 AM   #359
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
The blower speed being tied to the crank shaft speed would only make the surge harder on the Vortech compressor than in the turbo since it can't slow the Vortech compressor perceptibly.
Sellout is offline   Reply With Quote
Old 05-31-2013, 11:59 AM   #360
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by draggin_az View Post
$200!?!?!?!?!?!?!?!?!
with all due respect, fuck that
You gotta love this forum. He did say with all due respect. With all due respect, I would say that if you think $200 is too much than forced induction might not have been the way to go on your car.
Old 05-31-2013, 01:06 PM   #361
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Bingo! That was exactly what it was so once again hats off to Vortech for getting kits out there even if it cost them a little extra to do so. Spoke to them earlier and this was exactly what had happened so they did this to continue completing orders.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
Brian@Vortech (05-31-2013)
Old 05-31-2013, 01:51 PM   #362
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
^^This. Smart man.
Brian@Vortech is offline   Reply With Quote
Old 05-31-2013, 03:48 PM   #363
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Brian@Vortech View Post
^^This. Smart man.
Thats awesome. Many other companies would just wait for stock and hold the kits until they got it in
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
Old 05-31-2013, 04:47 PM   #364
Brian@Vortech
Well, to be fair...if it was a part we made ourselves and we needed materials, it would have to wait. That is the case with discharge ducting and why some of the kits have taken longer than we would like to get out the door. Since the valves are a purchased part though, it is a little easier solution to handle in a pinch.
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
