#351 |
STREET MOD. My wallet now hates me....
#352 | |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
#353 |
Drives: Pavement MT GR86
Anyone have a good idea on how much time difference there is between our stock nearly all season tires and a good set of max or extreme summer tires?
GR86 MT premium
#354 |
Drives: Firestorm FR-S
The Strano bar is 22mm hollow.
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
#355 |
Conedancer
Drives: 2013 Subaru BRZ SWP
2-3 seconds
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#356 |
I noticed load ranges on racing or extreme performance tires tend to be lower than standard....is this a problem? what kind of minimum range could we run on an otherwise stock car?
GR86 MT premium
#357 | |
#358 |
Conedancer
You failed to mention what other mods you have. Yes a rear sway will help balance the car out a bit. Is it completely stock other than the front Bar. what is your alignment settings?? Camber???? There are lots of other variables other than just throwing bars on...
.. but all the other stuff plays just as important roles to the balance of the car...and there is other ways, in combination, to achieve the overall goals.. Hope that makes sense to you. My first thoughts are, to throw a set of Koni's on it.. Then play with the rear bar.Bill
#359 |
Sure I thought I was clear in what I outlined, sorry if I caused confusion. Stock suspension is fully stock, including camber, etc. That is on the list of things to do as well. At this point, Koni's are also on the list, but that is a price challenge that may have to wait until next season. I guess my question is more in the sense of will changing to that slightly stiffer rear bar dial some of that understeer back out? Sound like it will and I have been thinking that it would. I need some guidance on tire pressure as well. As mentioned I have been playing with it, and just cant find something I am fully happy with. I am thinking going with the rear bar and sticking with my square setup might be the way to go, but I am open to suggestions!
#360 |
I was told square or slightly lower in the rear starting at approx 38psi hot and going down from there....i'm sure it's dependent on the tires your using though.
GR86 MT premium
#361 | |
If the car is understeering, you want to make the front end of the car work better - putting a rear bar on is a band-aid at best, and in most situations, is not advisable, regardless of prep level.
#362 |
Drives: 2013 Ultramarine Scion FR-S
For those asking about SP class, per the 2013 rulebook, under CSP is the following statement:
Sports cars under 2.0L not otherwise classified. Per the owners manual, our engine is 1,998 cm3 < 2.0 L Therefore, the FR-S/BR-Z is in CSP. |
#363 |
Grip>Drift
Drives: FRS
I want to ask the lamest question in the thread...
I really wanna put a lip spoiler on the trunk, we all know this does nothing for aero performance but is someone going to protest this? I got thinking this because I saw an STR Miata this weekend with one.
#364 |
AutoX-10/10ths every run
They could if you win, or just beat them.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
