#351 |
Drives: Seibu Shinjuku Line
Hmmm, I still think the headlights/tails are what we'll see on the Subaru variant. Both seem too different from the Toyota/Scion concepts and remind me more of Subaru styling. Oh well, I'll see what version looks best and go with that.
#352 | ||
Site Moderator
Drives: ichi 86 Project
edit: add to that SCION VP stated Quote:
#353 | |
Drives: 2006 Mazda RX-8
The Scion tC has a heavy FWD architecture. The RX-8 has a heavier than usual body because of the giant gapping hole in the center from the suicide doors. The engineers have needed to reinforce other areas to get back the stiffness. I believe that Toyota has too much riding on their lightweight marketing to release a pig heavy car. Also, other components of the car can be engineered to be lighter since the car doesn't have a lot of power compared to other modern sports cars. In my opinion, the car will not weigh more than 2800 pounds. One of the best correlations with sports car weight is front brake size. The front rotors on the prototype look like they're about 11.5". The NC Miata has a 11.4" front rotor and is about 2500 pounds (in softtop guise). The S2000, which was a little over 2800, had 11.8" rotors, but was relatively underbraked for a modern sports car. The RX-8, 370Z, Genesis etc. all have rotors in the 12.6"+ range. |
#354 |
Drives: ZZT231 Celica
2000-2005 Celica had 10.8" front rotors (275mm) and weighed 2470lb (1120kg)...
#355 | |
Turbo Mafia Presidente
Drives: U Mad?
11' Fiesta @ ~2550lbs wheelbase 98 length 160.1 Width 66.8 height 58 I know you really can't compare a Fiesta to it but that's one heavy car regardless for it's size. You add to the above bigger body panels/flares, bigger engine, bigger brakes, bigger wheels, bigger exhaust, 6spd, driveshaft, rear end. That's 300+lbs Unless they are using hallow sways, aluminum driveshaft, alum. suspension arms(not stamped steel), aluminum hood, trunk and roof skin than I don't see how it's possible. |
#356 | ||
Mr. Detail
Drives: 2003 Celica GT-S
If anything, the FT-86 is a RWD Celica. Now, with your expert experience, how much weight do you think a RW drive train will add if you took a Celica base of 2500 lbs?
#357 |
#358 |
Mr. Detail
Interesting, but the front bumper seems to have FR-S lines too.
#359 | |
Feeling Iffy?
Drives: it like I stole it
#360 | |
Is a Monster
Drives: AE86, MA70
FYI, typical Subbies are understeering pushers because of the AWD system, with the bulk of the weight in the front sitting ahead of the front axle. Edit: Researched myself and found myself wrong(concerning the FT-86's front weight). That being said, this chassis is specifically designed for an FR setup, and the majority bulk of the front weight is not so far forward to make it front heavy. They can't state that the engine sits far back near the middle and then do the opposite....ok they could, but they won't. I would think 10 years in the biz and you'd be able to ascertain that much. http://www.ft86club.com/forums/showthread.php?t=982 there's the link to the thread concerning the chassis Last edited by OldSkoolToys; 05-21-2011 at 02:03 AM. |
#361 |
Is a Monster
Drives: AE86, MA70
As lionzoo stated earlier about Rotor Size and vehicle weight...can anymore guesstimate the rotor size there? I'm well aware this is just a 'skeletal' promotion display, but hell, it doesn't hurt to try. Those are probably the same 17in Enkei's on the current prototype. |
#362 | |
Drives: '91 MR2
#363 |
Drives: Honda POS
Is this the rear wheel? The rear rotor would obviously be smaller.
#364 | |
Elite Padawan
| First Video of Scion FR-S / Toyota FT-86 / Subaru BRZ | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 35 | 11-15-2011 09:21 PM |
| Any predictions on how Subaru will differ from Toyota/Scion | tranzformer | BRZ First-Gen (2012+) — General Topics | 65 | 07-26-2011 06:31 PM |
| Im confused... Scion FR-S in US. But what will Toyota/Subaru name be? | Spencer Strayer | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 04-26-2011 03:08 PM |
| If there is no Toyota will you go with Scion or Subaru | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 91 | 04-25-2011 11:53 PM |
| Which version would you buy? Toyota, Scion, Subaru, or Lexus | SOB | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 04-05-2011 09:56 PM |
