| FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
#351 |
hashiryu
Drives: Mk4 Supra
#352 |
Kuruma Otaku
Ok, I'll add these caveats as well: Also if it was made by Toyota and 500 to 1000 lbs lighter.
Because titanium. |
#353 |
Feeling Iffy?
Drives: it like I stole it
#354 |
Kuruma Otaku
I'm still holding out for my GT5 weight +10% guess (which would be about 2420 lbs) for the FT86. 370Z is around 3300 lbs? That's about 900 lbs lighter... See where I was going there?
Because titanium. |
#355 |
Feeling Iffy?
Definitely, but the ft86 has a much better chance of being under 2500lbs than a Z. For me, I don't really care about the weight, but rather for the performance specs than anything else.
#356 | |
Kuruma Otaku
Going back to the original topic, comparing the two makes little sense. I want this car to be as light as possible, and we're talking about a potential of $10k-$15k cheaper. I can see a potential Z buyer cross-shopping the cheaper FT86/FR-S but not the other way, mainly on price. But if it comes in under 2500lbs, when people start modding them for more power they will be more than a match for Zs. Lotus founder Colin Chapman has pointed out that, all things being equal, a 200 hp 2000 lbs car will out-lap a 300 hp 3000 lbs car. So it's even more than just power to weight. Lighter is better. At 2500 lbs with 200 hp, it would only need a 50-60 hp bump to match the Z's ratio.
Because titanium. |
#357 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I love the Z but I would choose a FR-S over it even though the Z is faster in the straights. With high gas prices I don't care about big power anymore unless it's a ecotec-like 2.0 liter boxer turbo. I only want more power if it comes with a 35 mpg highway.
#358 |
Registered you sir
Drives: 99 impreza coupe
Sorry to burst your bubble but this is going to be a performance car... I hope. Im not sure why people expect the best of both worlds, either the tech is in performance or its in fuel efficiency , the two rarely mix. The more the compromise the performance the less I will like it.
#359 | |
Drives: '06 AM V8V Coupe
Technological advances aside, even K20 and 2ZZ powered cars get pretty good gas mileage despite being performance oriented, there's no reason to expect any less in the fuel economy department, especially with such a small car (low aerodynamic drag!), although some of the higher mpg numbers might not be feasible due to cost constraints. This is Toyota afterall, the company that sells the most on fuel efficiency. |
#360 |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
To add - Toyota have said they could aim for (and reach) 230ps, but they would lose a lot of the efficiency of the engine. That they have said it will be around 200hp means it shoud have very good efficiency for a performance car.
And, that said, the restrictions will most likely be intake/exhaust/maybe cams ones... So, swap them out and you should be able to make a lot more power (for the people that want to )
#361 | |
3S-GTE Junky
Drives: Toyota Celica GT-Four ST205
Very easy to get hold of good donor cars. There are off the shelf manual bellhousing conversion kits for both the W58 and the R154 gearboxes. I've personally had experience of doing this swap as i was the first person (Possibly still the only person) in Europe to put a 1UZ into an MA61 (MK2 Celica Supra) with an R154 from an MA70. With a stock Rev2 engine (265bhp in the Lexus LS400), just a set of headers and a Link Ecu i was destorying brand new 350z's on the 1/4 mile.... until the diff exploded...
#362 |
hashiryu
Drives: Mk4 Supra
#363 | |
#364 |
Drives: Ms. Daisy
Eh, that used to be the base MSRP for the 350Z before they jacked up the prices for the 370Z. My 06 was a base and my 08 is an enthusiast, definitely like the 08 better (plus it wasn't a lemon!).
| Tags |
| fanboi, lame |
| Nissan 370Z thread | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 116 | 04-07-2017 11:40 PM |
| FT 86 & 370Z similarities | blur | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 10-05-2010 01:39 AM |
