07-02-2014, 12:13 PM | #351 |
Single and Loud
What was the labor cost at the dealership? They want 8+ hours here in Austin...
2013 FR-S, Enkei RPF-1s, Geforce Sports, Berk Track Pipe, etc.
07-02-2014, 02:13 PM | #352 |
Drives: 2018 BMW M240i
I got a quote of $550 in labor and $265 in parts at Toyota of Fort Worth.
The Following User Says Thank You to tennisfreak For This Useful Post: | JonAvalon (07-02-2014) |
07-02-2014, 02:59 PM | #353 | |
Drives: Raven FR-S
07-03-2014, 12:07 AM | #354 |
Drives: Asphalt grey, manual Fr-S
Would these springs work with these tires:
Front- 225/35-19 Rear- 255/30-19 |
07-03-2014, 10:48 AM | #355 | |
The Following User Says Thank You to tennisfreak For This Useful Post: | nosi9frs (07-03-2014) |
07-03-2014, 11:20 AM | #356 | |
Seņor Member
07-03-2014, 01:00 PM | #357 |
Drives: Raven FR-S
07-03-2014, 02:00 PM | #358 |
Seņor Member
07-03-2014, 03:38 PM | #359 |
Unwashed Heathen
Drives: 2014 Scion FR-S
I just installed the TRD springs and swaybars, and trust me, its a big improvement in ride quality as well as handling. It handles rough roads better, which I suspect is due to the progressive nature of the TRD springs as opposed to a static rate on the stock springs. If you drive normally, you won't really feel much difference aside from a smoother ride (imo) but when you push the car harder, the changes really become apparent. The car is much more predictable, more planted and neutral in a turn, and cosmetically, the ride height looks much better.
I have extensive experience with Porsches and plenty of track experience over the last two decades. The TRD springs/sways are in no way a replacement for a properly dialed in coil-over set up if you are planning on tracking your car, but they are absolutely perfect, imo, for a street car. Everything I complained about with respect to the stock handling, which was fun for what it is but a good bit less than perfect from my perspective, was resolved by making this change. I would strongly suggest changing the sway bars if you are going to run these springs, they complement each other very well. For what its worth, I am running stock tires/wheels on my '14 FR-S. If you are doing the work yourself, make sure you get the car aligned after the install. The install took me around 6 hours total, but I was mostly enjoying some garage time to myself rather than trying to hurry through an install, or I expect I could have come close to cutting the time in half. Last edited by Sh944; 07-03-2014 at 03:54 PM. |
The Following 8 Users Say Thank You to Sh944 For This Useful Post: | BabaYaga (02-16-2015), Createddeleted (07-03-2014), Evil Jesus (07-03-2014), gonzo (07-07-2014), newports (07-10-2014), nosi9frs (07-03-2014), number1Tango (07-25-2015), STV3 (07-03-2014) |
07-03-2014, 09:49 PM | #360 |
Drives: '13 10 Series FRS #1203
Can the TRD springs be used with the factory struts?
07-03-2014, 11:02 PM | #361 |
Unwashed Heathen
Yes, in fact, they are designed to work with them according to the Toyota rep I talked with before I bought mine.
07-06-2014, 08:24 PM | #362 | |
i kill cones.
Drives: around cones in a parking lot
2013 SSM BRZ Limited 6MT
07-07-2014, 06:58 PM | #363 |
i am selling a set of TRD lowering springs, brand new in box, never open or used for $210 obo if anyone is interested. Thanks
07-07-2014, 07:06 PM | #364 |
Drives: FRS
ive been asking for some for a while
Similar Threads | ||||
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
ST Suspensions Lowering Springs & Anti-Sway Bars Now Available @ BMS! | Boston Motorsports | Brakes, Suspension, Chassis | 84 | 07-23-2013 11:42 PM |
Stock springs and sway bars | Spencer | Brakes, Suspension, Chassis | 3 | 04-25-2013 09:41 AM |
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive | Pure Automotive | Brakes, Suspension, Chassis | 1 | 02-06-2013 02:32 PM |
