#3599 |
Drives: 2014 BRZ Limited 6MT
Does anyone know if the crawford AOS will work with the jackson racing c30 supercharger set up and if so will there be any instruction changes durring the install?
#3600 |
Drives: 2015 Series.Blue BRZ
It fits. I dunno about works. I have one and I'm still getting oil in the intake.
#3601 |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Does anyone have a MAF scale for a JR kit that are willing to share. I would like to compare numbers that I am getting tuning my friends car. The numbers seem very low compared to my vortech kit which worries me there is still a boost leak. This car has had boost leaks in the past but was leak tested to be ok.
#3602 | |
#3603 |
Calle Atun
Whats your max g/s setting at 5V? I am at 270 g/s and still rich. I am guessing some where in the 250-260 g/s blended down will do it if I get more time to log and rescale. My Vortach is about 330 g/s and the stock NA is around 300 g/s. 250-260 g/s as a max seem really low to me.
#3604 |
Drives: 2014 Monogram Scion FRS Whiteout
Guy, I need help.
I just got the kit and seems like my car is stalling a lot when I'm crusing and I clutch in to go to neutral and stop. It just stalls when rpm drops below 1000. And when I try to turn it on it doesn't turn on well. |
#3605 | |
Drives: 2014 Argento FRS
Do you have an aftermarket Clutch and/or Lightweight Flywheel? Sent from my iPhone using Tapatalk |
#3606 |
#3607 | |
Interesting, I have aftermarket clutch and LW flywheel and it sometimes does the exact thing you're referring to. I'm sure others on here will chime in with more info. Sent from my iPhone using Tapatalk |
#3608 |
Have you asked your tuner?
#3609 |
#3610 | |
#3611 | |
#3612 | |
This link will show you how to log. http://blog.perrinperformance.com/ho...cuteks-proecu/ Also, log 'custom map p result' to get the ethanol content. Delicious Tuning will also want this parameter. |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
