Old 08-11-2016, 09:09 PM   #3599
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Does anyone know if the crawford AOS will work with the jackson racing c30 supercharger set up and if so will there be any instruction changes durring the install?
tofurun is offline   Reply With Quote
Old 08-11-2016, 09:25 PM   #3600
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
It fits. I dunno about works. I have one and I'm still getting oil in the intake.
ScionOfHorus is offline   Reply With Quote
Old 08-12-2016, 02:37 PM   #3601
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Does anyone have a MAF scale for a JR kit that are willing to share. I would like to compare numbers that I am getting tuning my friends car. The numbers seem very low compared to my vortech kit which worries me there is still a boost leak. This car has had boost leaks in the past but was leak tested to be ok.
Toyota John is offline   Reply With Quote
Old 08-12-2016, 03:33 PM   #3602
CSG Mike
CSG Mike's Avatar
You can check for boost leaks by observing the MAP; you can extrapolate boost by observing when the stock MAP maxes out. Small boost leaks are exceedingly rare with this kit due to the piping design and hose overlap. You either lose all the boost (charge pipe blown off) or none.
Old 08-12-2016, 04:09 PM   #3603
Toyota John
Calle Atun
Whats your max g/s setting at 5V? I am at 270 g/s and still rich. I am guessing some where in the 250-260 g/s blended down will do it if I get more time to log and rescale. My Vortach is about 330 g/s and the stock NA is around 300 g/s. 250-260 g/s as a max seem really low to me.
Old 08-12-2016, 07:24 PM   #3604
jainish007
Drives: 2014 Monogram Scion FRS Whiteout
Guy, I need help.
I just got the kit and seems like my car is stalling a lot when I'm crusing and I clutch in to go to neutral and stop.
It just stalls when rpm drops below 1000. And when I try to turn it on it doesn't turn on well.
jainish007 is offline   Reply With Quote
Old 08-12-2016, 07:27 PM   #3605
SoCalArgento
Drives: 2014 Argento FRS
Originally Posted by jainish007 View Post
Guy, I need help.
Do you have an aftermarket Clutch and/or Lightweight Flywheel?
SoCalArgento is offline   Reply With Quote
Old 08-12-2016, 07:30 PM   #3606
jainish007
No I don't. It just stalls when lets say Im driving and I see a red light. When I clutch in and go to neutral, instead of idle it just stalls.
Old 08-12-2016, 07:35 PM   #3607
SoCalArgento
Interesting, I have aftermarket clutch and LW flywheel and it sometimes does the exact thing you're referring to.
I'm sure others on here will chime in with more info.
Old 08-12-2016, 07:44 PM   #3608
ScionOfHorus
Have you asked your tuner?
Old 08-12-2016, 08:03 PM   #3609
jainish007
I just got it installed yesterday and I have delicious tune for flex fuel. I have emailed David and Mike at CSG regarding issue. Hopefully just a tune is the issue.
Old 08-12-2016, 09:19 PM   #3610
dj2020
Sounds more like a tune issue. Send 30 second idle log and 30 sec cruise log (65-70 mph) to sales@delicioustuning.com. With a little back and forth on the logs and map adjustments, I was good to go. A pure speed density tune can sometimes be a little tricky when the rpms drop too quickly when clutching in and stalls as I understand it.
dj2020 is offline   Reply With Quote
Old 08-12-2016, 09:28 PM   #3611
jainish007
Can anyone direct me in a direction on how I get the logs. Im a noob
Old 08-12-2016, 11:31 PM   #3612
dj2020
This link will show you how to log.
http://blog.perrinperformance.com/ho...cuteks-proecu/
Also, log 'custom map p result' to get the ethanol content. Delicious Tuning will also want this parameter.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
