Sam Strano
Old 07-17-2015, 12:03 PM   #3557
renfield90
The Stig's German cousin
Originally Posted by coneracer30 View Post
I run the koni's at 1 turn from full stiff front and 1 turn from full soft rear with TRD springs.
Correct me if I'm wrong, but I'm pretty sure the Koni yellows are two turns total from full soft to full hard.
Old 07-17-2015, 12:15 PM   #3558
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I think the rears have more adjustment than the fronts, or vise-versa. They're not the same.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 07-17-2015, 12:26 PM   #3559
simpleisbest
Senior Citizen
Drives: Scion FR-S
The # of turns on Koni's is never exact. Where exactly the adjuster puts you for the in-between stuff can be different per shock. The good news is what they do at full stiff and full soft is should be pretty consistent, though
simpleisbest is offline   Reply With Quote
Old 07-17-2015, 12:45 PM   #3560
ButteR
Drives: 2015 Scion FR-S
I get full 3 turns on the rears and the fronts. I'm running the full replacements up front.
ButteR is offline   Reply With Quote
Old 07-17-2015, 01:05 PM   #3561
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I definitely do not get three full turns out of either the front or the back. It's closer to 2
Old 07-17-2015, 01:16 PM   #3562
ButteR
Weird. When did you buy them? Are your fronts inserts or full replacements?
Old 07-17-2015, 03:31 PM   #3563
TrqlessWonder
Drives: 2014 FR-S
My full replacement konis are also two turns, front and rear. Who knows when they were made, but they were bought in March.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 07-17-2015, 03:58 PM   #3564
renfield90
I have exactly two turns front and rear. Purchased April or May. Full replacement set.
Old 07-18-2015, 07:30 AM   #3565
ksconekiller
Drives: Subaru BRZ
Originally Posted by TMF View Post
Thanks for the info, appreciate the starting point! Although I thought I've heard that you're not supposed to run Koni's on full hard/stiff?
Correct. You shouldn't run Konis at full hard or full soft. It's just because if you hit that stop point even just a little too hard, it can make the adjuster stick in that position. If you are wanting to run full hard or soft, gently hit that point and then back it off just slightly (like 1/16 turn or less). As long as it's not sitting on the stop, you're good. Info directly from Lee Grimes at Koni.
ksconekiller is offline   Reply With Quote
The Following User Says Thank You to ksconekiller For This Useful Post:
TMF (07-20-2015)
Old 07-18-2015, 07:36 AM   #3566
ksconekiller
Drives: Subaru BRZ
Originally Posted by cab33 View Post
Alignment numbers for the record:
2016 FRS
TRD lowering springs and sway bars
Camber crash bolts
Front -1.1 degree(maxed out)
Back -2.06(left) 1.59(right)(non-adjustable)
Before the camber bolts, the fronts were -.15 degree.
Wow. Such variation from one car to another. Due to the suspension design of our cars, this is exactly what I had originally expected to see from cars using the TRD springs: more rear camber with little change up front. I still wonder what the manufacturing tolerances are.
Old 07-18-2015, 07:44 AM   #3567
ksconekiller
Drives: Subaru BRZ
Originally Posted by Arigh View Post
This will be the first nationals I attend and also the first time on concrete. I'm already signed up for a test and tune slot, and the evo school test and tune as well, so I know I'll have some amount of time to adjust setup, but early is a great time to ask: Any big differences between the two surfaces for setup? Do you adjust damping and pressures to compensate for the increased grip levels?
Never run on concrete?? Enjoy the grip, especially at Lincoln. I don't know that there will be any big setup change, as your balance should still be the same. I don't know what you run for air pressures, but my guess would be that you'll want to raise them a bit for the concrete.
Bring an extra pair of shoes for course walks; the surface gets tacky from all the tire rubber, and your shoes will literally stick to the ground and pick up every single rock and piece of crack filler. Seriously. And bring clothes for any kind of weather; expect it to be 50 degrees and rainy one day, then 90 degrees and sunny the next. Nationals is a blast!!
Old 07-18-2015, 03:05 PM   #3568
AFRichZC6
AFRichZC6's Avatar
I get about 2 1/4 turns from both the Koni shocks and complete strut assemblies. I've had two sets of Konis (one off-the-shelf set and one revalved set), and they both have the same number of rotations in damping adjustment.
AFRichZC6 is offline   Reply With Quote
Old 07-20-2015, 09:55 AM   #3569
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
So basically shoes you plan to throw away?
G_Ride is offline   Reply With Quote
Old 07-20-2015, 10:49 PM   #3570
ksconekiller
Drives: Subaru BRZ
Well, yeah, pretty much. It's not so bad that you have to throw them out, but you won't be using them for ballroom dancing anymore. I still have the shoes I used for last year, and there is still filler material between the tread blocks of the sole.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
