Old 07-11-2015, 11:49 PM   #3501
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Originally Posted by mit_peid View Post
Yeah I have an extra belt... How did you heat up the bolt.... one of my buddies suggested getting a pulley puller?
I just used a small hand held butane torch and held it over the bolt for about 15-30 seconds. Definitely not more than that though, I accidentally over heated one bolt and stripped it pretty bad.
I've never used a pulley puller, so I'm not sure
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
The Following User Says Thank You to Rulin For This Useful Post:
mit_peid (07-19-2015)
Old 07-11-2015, 11:58 PM   #3502
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Yeah, I also stripped one of my crank pulley bolts trying to go from the 100mm crank pulley to the newer 128mm crank pulley. So I guess at some point after my initial install the KW C30-94 kit now uses 128mm crank and 100mm supercharger pulleys instead of the previous 100mm crank and 75mm s/c.
mit_peid is offline   Reply With Quote
Old 07-13-2015, 08:59 PM   #3503
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
If you guys are removing the blower from the car, you could always take it down to a local shop and have one of the techs zip it out with a 3/8" drive pneumatic impact, i have a battery powered one i use to remove the bolts during pulley changes. Throw the tech enough for lunch and its done in 2-3 minutes
-Thomas
86SPEED is offline   Reply With Quote
Old 07-14-2015, 01:00 AM   #3504
mit_peid
Boosted Noob
mit_peid's Avatar
I think I'm just going to bring my Rotrex into a local shop (TechnoSquare) to get the pulley off. This is all I can find from the internet on the matter.
Old 07-14-2015, 02:07 AM   #3505
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by Jcl View Post
Could maybe do something like this? Use the kw sandwich run the lines to this then the setrab oil cooler.
http://www.summitracing.com/int/part...5792/overview/
hmm.. interesting. I'd have to take a look. i need to also find a way to data log on the track lol. all these places say nothing in car is allowed. I might have to take my yoga 2 and put it into tablet mode and lay it underneath my seat or something haha that way i can actually check my oil temps. unless someone else has any ideas?
otherwise i got one vote for the forester oil cooler lol anything else?
pgranberg11 is offline   Reply With Quote
Old 07-15-2015, 04:24 PM   #3506
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
I am considering getting a UEL catted header.
Is it worth it? Performance gains? Running pump gas.
English is my 2. language. Typos might occur.
2013 BRZ, kraftwerks supercharged.
Skunk2 Ultra radiator with oilcooler
KW v3 - enkei 17x9 with PSS
Andreas83 is offline   Reply With Quote
Old 07-18-2015, 01:56 PM   #3507
BRZ.PTY
Drives: BRZ limited 2013
Guys, does somebody know what is the easiest way to change a broken belt? I have a new belt but don't what is the best approach to change it. Thanks for any help
BRZ.PTY is offline   Reply With Quote
Old 07-18-2015, 02:07 PM   #3508
beemer
Drives: '13 FRS
who has the Kraftwerks c30, tuned, and has gotten a time slip. I'm running tuned at 281whp with the SC and isis over pipe back (with resonator).
last night I ran it 5 times, and my best time was a 14.05.
and this is on factory tires, so I know I could have cut my time down with better tires.
let me know what you have done!
Sent from my SM-N900P using Tapatalk
beemer is offline   Reply With Quote
Old 07-19-2015, 12:39 AM   #3509
mit_peid
Boosted Noob
mit_peid's Avatar
These are the steps I took:
1) remove the pipe going into the intake manifold to make room
2) take the cover off of the KW plate
3) disconnect the inlet/outlet of the Rotrex traction lines (tie them together out of the way temporarily with an adapter so they don't leak)
4) loosen fasteners going into and out of the Rotrex blower
5) remove tensioner pulley
6) remove 4 bolts (2 on the Y, and 2 small ones on the bottom right) from the KW plate, keeping the single large bolt on the left
Now you can rotate the Rotrex assembly counterclockwise on that single large bolt, dislodging from the urethane charger piping, and replace your belt.
Old 07-20-2015, 09:59 AM   #3510
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I know it doesn't really matter but has anyone found a place where we can order stainless steel hardware for mounting the plate to the car? The rusting hardware looks terrible. Specifically looking for replacements for the socket head machine screws called for in the manual:
4. M6x1.0x30MM
7. M8x1.25x30MM
8. M10x1.25x25
9. M10x1.25x45MM
Everywhere I know needs large quantity orders.
industrial is offline   Reply With Quote
Old 07-20-2015, 12:42 PM   #3511
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
4. M6x1.0x30MM
7. M8x1.25x30MM
8. M10x1.25x25
9. M10x1.25x45MM
Maybe mcmaster-carr? Sometimes, even my local ace hardware would have stainless steel hardware, but most likely would have to trim them to length.
The Following User Says Thank You to BigFatFlip For This Useful Post:
CSG Mike (07-20-2015)
Old 07-20-2015, 01:46 PM   #3512
FirestormFRS
Amazon
FirestormFRS is offline   Reply With Quote
Old 07-20-2015, 01:51 PM   #3513
Andreas83
Andreas83's Avatar
4. M6x1.0x30MM
7. M8x1.25x30MM
8. M10x1.25x25
9. M10x1.25x45MM
I would not use stainless bolts for it. You might end up having galvanic corrosion on all the alu parts when you mix in stainless steel.
It might not become an issue in this setup, but it can happen.
Old 07-20-2015, 09:43 PM   #3514
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
D-749
Full Press-Release will drop soon!
KraftWerks is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
