Old 02-06-2021, 06:31 AM   #337
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
Hello
"I remember that im usging google translator, sorry"
I will rate my experience with this system.
I installed this audio system a year and a half ago.
- 5 stars
Sound quality and balance in all musical genres especially epic / trailer music, soul and rock very good at decent volume levels. In some genres and especially some artists it lacks a bit of that bass that gives more base to a double pedal rhythm, although this would not say that it is a specific problem of OEM audio (black, death, grindcore metal etc).
- 5 stars
Customer service (at first), very friendly, competent and quick to respond. No complaints.
- 5 stars
Installation now are ok.
- 5 Stars
Customer service after a year and a half.
I edit the last review.
After a few months I decided to send the amplifier to technical service, for whatever reason they could not replicate the device I had at high volume. They sent me another totally new amp with a connector for my old wiring, because something must have gone wrong or I did wrong and the amp burned out. I quickly commented on my problem and how could it be otherwise they helped me as much as possible, because in the end after waiting a few months I received new wiring with another totally new amplifier. I honestly have to say that few companies have that detail with the client and I totally appreciate it.
Thank you so much OEM audio team.
Alastor is offline   Reply With Quote
Old 07-27-2021, 10:47 AM   #338
Alastor
Alastor's Avatar
my last entry was edited
Old 07-27-2021, 11:53 PM   #339
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
So did you ever get your Pioneer Auto EQ/TA working properly in your system?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 08-08-2021, 04:50 AM   #340
snk828
snk828's Avatar
Drives: raven FRS
Hello
- 5 stars
- 5 stars
- 5 stars
- 5 Stars
Did they charge you anything for a new AMP and Wires?
snk828 is offline   Reply With Quote
Old 08-14-2021, 05:54 AM   #341
Alastor
Alastor's Avatar
warranty
Even so, I also had to pay for shipping and customs.
Yes, but now is the same. OEM audio system working
Old 02-12-2022, 09:42 AM   #342
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
oem audio+ is abysmal to deal with on the phone, very cryptic and arrogant so I am here to ask the same question looking for a clear answer can an OEM audio+ kit from a 13-14 frs (13-16 frs/86/brz without touch screen) work with a 17+ car? Specifically a 2020 with touch screen and backup camera.
SON1C is offline   Reply With Quote
Old 02-12-2022, 10:21 AM   #343
soundman98
ProCrastinationConsultant
soundman98's Avatar
it ought to. the speaker/amp wiring is a separate harness from the backup camera stuff.
Old 02-12-2022, 10:52 AM   #344
SON1C
SON1C's Avatar
that's what I'm thinking and I couldn't dig up any reason it would not... but I also could not find confirmation that yes it definitely works.. hoping to dig up someone here who's used an old kit in a newer car lol
Old 03-02-2022, 07:26 PM   #345
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I’m having a problem that popped up. All of the speakers are making a static sound like I am listening to a radio station with poor reception, and it gets worse the louder the volume. At low volume it isn’t there, but at medium to high volume it is progressively worse. I don’t know if it is the ground because the bolt came loose or where to start looking. Any help?
Old 03-02-2022, 09:30 PM   #346
soundman98
soundman98's Avatar
generally a connection/power problem that usually causes symptoms like that.
so best-first troubleshooting is to check/re-seat connections.
Old 03-02-2022, 10:16 PM   #347
Irace86.2.0
So I was thinking it was probably a headunit connection, so I took the headunit out and unplugged and plugged in wires, and I jiggled things around, but nothing worked or made a difference. I guess I will take apart the side plastic molding to get to the ground, and I will try to double check on the connections to the amp/subwoofer, but outside of that, I don't know what else it could be. I have a lot of small vibrations because of my engine swap, so I am wondering if something came loose, but I don't want to tear apart the car if someone has had the same experience.
Old 03-03-2022, 02:48 PM   #348
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You're in that realm of major modifications to the car that most of us have not stepped into, but we'll try to help as best we can:
1) I believe you replaced your ECU with an aftermarket unit, correct? Where did that get mounted, and did you use shielded cables?
2) Is it possible that ignition noise could be the cause?
3) Any new circuits run from the front of the car along the driver's side in parallel with the signal wires from the head unit to the stock amplifier?
Old 03-03-2022, 03:01 PM   #349
Irace86.2.0
So everything was working fine at one point. I disconnected the Haltech and nothing changes, as the Haltech is only for the engine. I’ve been working on the car often, so I couldn’t really say, but it happened after I installed an oil pressure sensor. All of the wires pin into the Haltech and not anything else. It could just be coincidence that the symptoms started near this time, but I ran a wire parallel to the power wire of the OEM Audio system that runs along the firewall. It went into the passenger side engine harness grommet into the cabin and to the Haltech. Nothing too odd or anything.
Old 03-03-2022, 05:26 PM   #350
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Let's try to narrow it down a bit more:
1) Does the noise appear when the key switch is in ACC position?
2) Does the noise appear when the key switch is in the ON position, with the engine NOT running?
3) Does the noise appear when the key switch is in the ON position, while the engine IS running?
amp, audio, music, radio, subwoofer
Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! CamryDS Audio/Visual, Electronics, Infotainment, NAV 25 10-23-2015 09:10 AM
Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 slicktop Miscellaneous 1 07-11-2014 08:58 AM
WTB: berk dual delete/perrin exhaust. JDL El headers. BBK kit. OEM Audio+/JL Audio YEAHdams Want-To-Buy Requests 0 07-01-2014 11:37 AM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
