Old 12-08-2015, 12:42 PM   #337
KoolBRZ
KoolBRZ's Avatar
With the right valve lift, valve timing, and exhaust header, you can make the peak torque line up with your shift points. This results in a strong, steady pull after each shift. Because you're NA, the exhaust will be just as critical to performance, as the intake. This would be a real measurable difference you can measure at the track. It might take some trial and error with different Final Drives to find the best gearing, but it would be worth it.
If I say yes, will that make you think I understand?
Old 12-08-2015, 12:56 PM   #338
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Would you kindly make a CAD file of the port section of the manifold for us peasants who cant afford to buy sacrificial parts?
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 12-08-2015, 01:10 PM   #339
celek
Resident Gear Head
celek's Avatar
I made that 2 years ago from the stock manifold
celek is offline   Reply With Quote
Old 12-08-2015, 01:12 PM   #340
celek
Resident Gear Head
celek's Avatar
Originally Posted by solidONE View Post
What are you planning to do with that? I sense a lot of melting aluminum in your near future.
http://www.ft86club.com/forums/showthread.php?t=98392
Old 12-09-2015, 08:32 AM   #341
celek
Resident Gear Head
celek's Avatar
Originally Posted by Tim Radley View Post
But my passenger side is your driver side
I did not label it, someone must have swapped it or thought the manifold was EJ orientation when it was scanned.
Old 12-11-2015, 08:16 PM   #342
celek
Resident Gear Head
celek's Avatar
SO I just got back from PRI in Indy Was able to sit down with the Piper guys good news they just released a newer better bigger Race cam!
That looks like the winner for the build.
Also spoke with an old time associate thats been building ITBs for 50 years. Worked out a game plan with Borla
Old 12-12-2015, 06:24 PM   #343
celek
Resident Gear Head
celek's Avatar
Here you go
Old 12-12-2015, 06:25 PM   #344
celek
Resident Gear Head
celek's Avatar
The official Catalog
Old 12-14-2015, 01:21 AM   #345
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
That sounds awesome but how streetable or daily driver friendly would those cams be? Would you have crazy idling?
cyde01 is offline   Reply With Quote
Old 12-14-2015, 02:27 PM   #346
celek
Resident Gear Head
celek's Avatar
Not with The electronic variable valve timing
Old 12-14-2015, 04:02 PM   #347
cyde01
cyde01's Avatar
so no downsides to daily street use at all? what would be the reasoning for anyone going with the fast road or ultimate road as opposed to the race cam?
Old 12-14-2015, 04:17 PM   #348
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
The race cam lift will give you more pumping loses which is bad for fuel economy.
MaximeT is offline   Reply With Quote
Old 12-14-2015, 06:15 PM   #349
celek
Resident Gear Head
celek's Avatar
Only downside is valve to piston clearance. The longer they are open more chance of interference. Stock pistons probably wont work on every cam. Even HKS says you can not use their cam with stock pistons, they say you should buy the high capacity kit.
Old 12-14-2015, 09:59 PM   #350
sato
sato's Avatar
Drives: Dodge Patitas
But don't we have chains instead of belts for timing? Maybe a noob like me can't think of interference screwing up something else (please elaborate)
Sent using tapatalk
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
