Old 10-17-2013, 01:50 PM   #337
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Originally Posted by elopez View Post
this is a bit disheartening for me, as an OFT early adopter.
translation is the tuning solution i've chosen (was planning on purchasing optional tuning package) is currently useless once i receive my kraftwerks kit.
maybe you should note this to potential buyers, that *you* will not furnish any FI maps for the foreseeable future and that 3rd party tuners must be sourced.
Buying the OFT isn't buying a tune. It's buying the hardware that can be used to tune your car with. Whether you do it yourself, get free maps from Shiv, or take it to a local tuner and have them tune your car with it. If you can't find a local tuner willing to tune your car using the OFT... well, how is that Shiv's fault?
Hanni_0176 is offline   Reply With Quote
Old 10-17-2013, 02:05 PM   #338
Hanni_0176
Hanni_0176's Avatar
Ah I see. My mistake.
Old 10-17-2013, 02:34 PM   #339
Millions
Millions's Avatar
Drives: Ultramarine FR-S
Hey guys, I'm running the 1.2 OTS map. I have a Borla UEL on the car and today I threw the P0171 (Bank 1 lean) code without running the car hard. I didn't bring it up past 4k rpm. Just wanted to see if anyone has had the same issue.
Millions is offline   Reply With Quote
Old 10-17-2013, 02:39 PM   #340
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That code is caused by the header. To get rid if it, you only need to disable it in the rom. When I get to the office I'll check to see if that diagnostic toggle is available in the XDF file. If not, I'll add it today.
The Stivo EL header in our car triggered the same code so it's pretty common. That code is disabled in the Stg2 OTS map that we are about to release.
Old 10-17-2013, 02:43 PM   #341
Millions
Millions's Avatar
Great! Thanks!
Old 10-17-2013, 03:02 PM   #342
mike the snake
Is Open Flash Tablet capable of controlling Methanol Injection?
For my soon-to-be turboed car, it's now between the Hydra system with their Hydramist WMI, which is quite a bit more money, but also seems to have a lot of advantages, although I'm not sure if I can or would appreciate them, and the OFT which seems really good as well.
I basically have 91 gas and I want some higher HP so I need to also run WMI.
Old 10-17-2013, 03:09 PM   #343
Shiv@Openflash
Drives: 2013 FRS
The OFT is not able to control a methanol injection system. Currently, it's functionality is limited only to ecu rom read/writing, diagnostics and soon data logging/displays. It does not have the auxiliary I/O to control methanol injectors/pumps. For those things, a standalone like the Hydra is better suited IMHO.
Old 10-17-2013, 03:41 PM   #344
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Shiv,
Why is the header causing the lean code? P0171 is based on the fuel trim being considerably out of spec on the LEAN side.
Please explain... Isn't it usually best to try to avoid disabling system checks unless absolutely necessary?
uspspro is offline   Reply With Quote
Old 10-17-2013, 03:59 PM   #345
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by uspspro View Post
Shiv,
From what I've seen the P0171 code is caused by the o2 sensor spacer in some headers that is intended to eliminate the cat inefficiency code (P0420). But what it also does is muddle the size and make it slow to respond. I have not seen fuel trims go out of spec considerably with the header installed. But I have seen this code get triggered during sustained highway cruise. So disabling this code isn't a big deal IMHO.
In our Stage 2 map however, we did rescale the MAF a bit to shift trims closer to 0 during cruise/light throttle. But this was mainly to avoid additive and unwanted long term fuel trim that would otherwise make the car run too rich (for max power) over time. I can turn the P0171 diagnostic back on to see if the code comes back or not.
Cheers
shiv
Old 10-17-2013, 04:03 PM   #346
Shiv@Openflash
Drives: 2013 FRS
Great! Thanks!
I have just confirmed that the diagnostic toggle for that code is available in the current XDF file. To disable it, just turn it off (input 0) here:
Old 10-17-2013, 04:28 PM   #347
RaLo
RaLo's Avatar
Drives: 2013 FRS
Originally Posted by Rombinhood@OpenFlash View Post
You can rescale all the sensors in the engine. I know Shiv rescaled the front o2 sensor to allow it to read a richer nominal AFR value instead of bottoming out. A MAF scaling table is also defined. Along with various others. I'll check the defs to see if one of them is MAP.
Has any information on whether this can be configured for MAP been discovered yet?
RaLo is offline   Reply With Quote
Old 10-17-2013, 04:31 PM   #348
Shiv@Openflash
Drives: 2013 FRS
Picture is worth a thousand words...
Old 10-17-2013, 04:42 PM   #349
RaLo
RaLo's Avatar
Drives: 2013 FRS
Shiv, you are the man... thank you for solidifying my decision
Old 10-17-2013, 08:17 PM   #350
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
wish those a,b,c tables had labels so id know what i was changing lol
IG-Joey_Soul
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
