Old 08-26-2013, 11:14 PM   #337
mfbmike
Drives: 2013 FRS, 2008 R32
@Erza_ft86 alphards
Post more pics of your FR-S, on flat ground preferably. I'd like to see what your ride height looks like with the fronts maxed out on the zeros.
mfbmike is offline   Reply With Quote
Old 08-27-2013, 04:40 AM   #338
Erza_ft86
Drives: the raven frs
@mfbmike loved the alphards lol but yea ill try to post a pic up tomorrow after i get off work i feel the fronts have settled a little bit
Erza_ft86 is offline   Reply With Quote
Old 08-27-2013, 09:13 PM   #339
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Quick question. The conical washer, which way does it go in? And it goes between the factory bucket and the upper spring perch correct?
Overland'n'5thGEN is offline   Reply With Quote
The Following User Says Thank You to Overland'n'5thGEN For This Useful Post:
altezza280t (08-28-2013)
Old 08-28-2013, 11:42 AM   #340
Racecomp Engineering
The conical washer should be right on top of the upper spring perch and below the top hat. Wider side down. Call or email if you need a pic.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 08-28-2013, 03:09 PM   #341
altezza280t
altezza280t's Avatar
Drives: Ultramarine FR-S
when will your website be back up?
altezza280t is offline   Reply With Quote
Old 08-28-2013, 03:40 PM   #342
Blerg....it better be up soon!
- Andy
Old 08-28-2013, 09:47 PM   #343
its back up.
sorry had to make MAJOR server changes.
mw
altezza280t (08-30-2013)
Old 09-03-2013, 07:41 AM   #344
FR-S Matt
Well, I fixed my brake issue... kinked line. I'm such a noob! Glad it was easy though. I'll post pictures when I get her cleaned up this weekend. Pretty hefty drop, nice flush look. Only small issue left is the light clicking noise when going over a small hill and the weight adjusts on the rear coils. I checked the tightness yesterday and both rear coils were really tight on the perch. I'm assuming this might be due to how new they are? Either way, not a big enough issue for me to take them off completely and mess with them right now. The ride is very nice, and my handling feels like it picked up drastically along with the wide rims and tires.
Thanks for the recommendation @Sportsguy83 on the open end ratchets. Those kickass for the top hats!
I'll be installing SPC LCA's next to adjust my rear camber and toe a little bit. I splurged and also got Hawk's ceramic brake pads and the Goodridge SS lines. Should be all the braking + more that I need. I'll get it realigned and get the balance sheet this time.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Sportsguy83 (09-03-2013)
Old 09-03-2013, 10:12 AM   #345
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Good to hear it wasn't something terrible.
Also - i see a lot of people with the Fuelly apps - up there in the high 20's like you. I must drive like an A-hole, cause my avg mpg is 22.5 lol.
Then again, maybe it's because i track...
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 09-03-2013, 01:45 PM   #346
djdnz
1337
Drives: 2013 BRZ WRB S/C
The computer on my car tells me I'm averaging 31.4mpg. I have a feeling it's slightly off, but not too badly.
Here's a pic of my baby after most of the issues have been sorted out with this whole ordeal.
Still don't have a straight steering wheel.
Some daily driver comments on the RCE T0 coilovers with 225/280
Note:some of my impression is coloured by new tires and wheels, as well as alignment difference from stock
Ride - Firmer than stock no doubt at all, noticed this the most when I had them first put on. Undulations in the road are much more noticeable, which is not my favourite aspect. For aftermarket suspension, they are still relatively comfortable, and definitely liveable day to day. Hard bumps are harsher than stock but actually very tame as far as aftermarket suspensions go. My wife says "a bit more rough, not bad". For me, stock ride is about a 7.5/10, and ride comfort with RCE's is about a 6-6.5/10.
Handling - This is hard to judge, I've made a lot of changes so it's hard to isolate the coilovers themselves between the alignment and the new tires. My main observations are that roll is reduced slightly, more speed can be carried through turns, but confidence at the upper threshold is not as inspiring as stock felt (given at a lower threshold). The car is able to rotate under cornering even with my big 245 summer tires on the rear and stock power. It feels very neutral, which is exactly what I was after.
Build quality - Top notch, very easy to rotate the collars, plating looks very nice and uniform, they feel very sturdy (a little on the heavy side). I have not had clunking or strange noises from the coilovers, huge thumbs up for that. I used stock mounts.
Service - Had many issues, but at least RCE sorted them out eventually. Overall I think this could be improved.
For the price, they are very good coilovers. The ST coilovers sound promising, and at a lower price point, but only have galvanized coating. I would say these are the main competition at this point to the RCE T0.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
chanomatik (09-04-2013)
Old 09-04-2013, 07:29 AM   #347
FR-S Matt
Definitely because you track. I can easily make the MPG drop each time I floor it.
I think my clicking/clunking noises in the rear are due to tightening issues. I may have to re-adjust them this weekend. When I brake slightly or the weight adjusts on the rear just a bit at very low speeds, I can hear the click of the top hats in the rear.
Would you guys recommend compressing the springs then tightening or is it possible to do this while they are mounted since weight is already distributed? They felt extremely tight when I tried to tighten them while on the car, but the rears need a long open ended socket in order to tighten. I'll be putting on the SPC LCA's so that will be a good opportunity to remove them off the car again to do some tightening. Fronts seem to be just fine.
Old 09-04-2013, 12:26 PM   #348
mfbmike
Your review makes it sound like these are the coils for me, particularly the handling aspects you mention considering I also intend on running 245 tires.
Can you go lower than this on these coils? If so, how much lower? Just trying to get an idea of how much flexibility I'll have with ride height with these.
Thanks.
Old 09-04-2013, 01:31 PM   #349
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
Thanks.
The lowest setting I believe is right around 1.5"
UnOvertime is offline   Reply With Quote
Old 09-04-2013, 01:36 PM   #350
mfbmike
Yes, I've seen that in posts.
I'm trying to get a "visual" idea of just how much of a drop that is on these cars. Or at the very least, someone who is dropped 1.25" for example, so I can get an idea of what another quarter of an inch would look like i.e. maxed out on these.
I was maxed out on my previous H&R street coils on my VW R32 and ride quality was perfect and I was just low enough to where I wasn't scraping but was still able to drive the piss out of it. That's what I'm trying to accomplish here. Low enough to aesthetically please myself while maintaining drivability.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-14-2013 12:26 AM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 09:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 02:44 AM
