Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-25-2022, 04:29 PM   #337
Petah78
Drives: 2022 BRZ sport-tech
Originally Posted by drift86 View Post
Based on my experience with the 2.0, it's pretty normal for these engines to knock a bit in low rpm high load situations.
I used to set an alert on the knock channels on the OFT and it almost always detects a bit of knock if you floor it at less than around 3500rpm unless you are on e85.
If you do it a lot, then the IAM will drop below 1.0, pulling timing across the whole rev range which reduces your power. It takes a bit of knock free driving to bring it back up to 1.0.
So it's best to downshift if you need to pick up some speed if you aren't in the powerband.
Thank you! This is excellent info. I have always noted the unpleasant sound at low revs and have learned not to load up the engine at low revs. I rather downshift. This confirmed my suspicions.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 07-29-2022, 02:24 PM   #338
Squirrely
Drives: 2023 BRZ, LTD, MT
Originally Posted by otter View Post
Couple things I've been noticing lately.
  • The seat will gradually raise itself up a bit over the course of a day or two. About 1 full pump of the height adjustment thing to get it back to fully lowered.
Ha, this has been happening to me too. I thought I was losing my mind. I wish these seats would go lower.
Squirrely is offline   Reply With Quote
Old 07-29-2022, 03:00 PM   #339
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Weird - I am pumped all the way up and have to give it an extra half pump every week or so.
CincyJohn is offline   Reply With Quote
Old 07-29-2022, 05:39 PM   #340
otter
Drives: 22 BRZ
It seriously feels like somebody is fucking with me. Just after a bit I think "why are my knees closer to the steering column?" then realize the seat has raised itself up a bit. Nobody else drives the car, does it all on its own.
otter is offline   Reply With Quote
Old 07-29-2022, 08:28 PM   #341
Shub Deetle
Large Member
Shub Deetle's Avatar
Drives: 2022 Subaru BRZ
Gremlins
Baby, you can drive my car
Shub Deetle is offline   Reply With Quote
Old 08-03-2022, 05:11 AM   #342
diga
Drives: 2022 Subaru BRZ Limited 6MT
I sometimes have a metal clang sound coming from rear when going over a sharp bump, I'm guessing it's rear brake dust shields? I'm relatively new to these cars, is this a common issue?
diga is offline   Reply With Quote
Old 08-03-2022, 08:50 AM   #343
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
I mean, how fast were you going? How high was the bump? As far as I can tell from mine, no, it should not clang. Are you sure it wasn't the car bottoming and the "bump" bouncing off your exhaust?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 08-03-2022, 10:31 AM   #344
mr.whiskers
Drives: '22 BRZ
I noticed this too. I did put a spare tire in the trunk instead of that foam organizer and inside the spare tire I put the tire fix kit and some tools/nuts from winter tires. I tried taking the stuff out and the noise seemed to be much less, so I am convinced it was the stuff bouncing in my trunk.
I think the jack in the trunk also could be making a bit of noise because its pretty loose in its location
mr.whiskers is offline   Reply With Quote
The Following User Says Thank You to mr.whiskers For This Useful Post:
diga (08-03-2022)
Old 08-03-2022, 01:43 PM   #345
diga
this isn't a one time issue, I've heard it occasionally since early on, around 25 mph on uneven/bumpy road sections. The car is stock except for HKS Spec L2 catback, it's not lowered.
Old 08-03-2022, 09:23 PM   #346
Frost
Frost's Avatar
Has the noise coincided with the installation of the L2? There's a good indicator and clue to investigate.
Old 08-03-2022, 11:51 PM   #347
mycrors7
mycrors7's Avatar
Drives: zd8 brz
Check for clearance between the rear subframe and the exhaust pipe
Or better yet, get under the rear and push the exhaust upward as hard as you can near the rear subframe/diff
Exhaust might be making contact
mycrors7 is offline   Reply With Quote
Old 08-04-2022, 04:12 AM   #348
diga
nope it was happening before the new exhaust but I'll double check clearances again
Old 08-05-2022, 06:59 PM   #349
Liquidsnake
Drives: "I drives like a Porsche"
How worried are you all about RTV and silicone in the oil pick up?
Liquidsnake is offline   Reply With Quote
Old 08-05-2022, 09:13 PM   #350
joemysterio
Drives: Mini
10 being extreme worry, like a 4. I just ordered an endoscope so I'm going to check when I do my oil change next weekend. If no excess, then in my head, likely everywhere else has correct amount and no longer need to worry. And I can continue adding my STI pieces, short throw, etc and finally ceramic coat the car.
joemysterio is offline   Reply With Quote
Anyone not buying to avoid early issues like 1st gen FRS? stocktc1 GR86 General Topics (2nd Gen 2022+ Toyota 86) 203 09-23-2021 10:11 PM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 09:56 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 05:42 AM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 05:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 11:21 PM
