Old 09-27-2021, 11:58 PM   #337
cjd
cjd's Avatar
Drives: 2017 BRZ
I have the Thermal. It's a few lbs lighter than stock (weighed in at 37lbs), and while I can't compare fairly to stock (it went on with the Ace 350) it is quiet enough to be comfortable on road trips (also running a 3" FP with hfc and resonator), has no noticeable drone (well designed Helmholtz doing its job), and a surprisingly small build. Tire noise or diff noise (I have all the diff mount bits) are louder usually.
Old 09-28-2021, 12:31 AM   #338
bslate3
Drives: 2015 CWP BRZ
I have the gruppe S header, Tomei overpipe, Motive front pipe and CSG touring 86 cat back. It’s pretty darn quiet.
My friend and I have been looking at building a light weight replacement muffler option that will fit onto the CSG cat back. We found a Hushmuffler that fits up pretty well with just 2 90’ bends and sounds pretty damn good without being crazy loud and is half the weight as the CSG muffler.
Is it worth the hassle so save about 8lbs? Who knows lol
bslate3 is offline   Reply With Quote
Old 09-28-2021, 09:44 AM   #339
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
I highly enjoy my HKS Hi-Power Spec-L
Significantly lighter, compact mufflers. It's not quiet, but it's not loud either.
I'll have to double check on clearance around the sway bar and endlinks. But it should be pretty good.
Breezio is offline   Reply With Quote
Old 09-28-2021, 10:55 AM   #340
steverife
Drives: 2016 Scion FRS
The HKS looks like it wouldn't rub driving interstate exits in Missouri. But might be worse for getting to end links with the car on the ground for a quick nut check under load.
steverife is offline   Reply With Quote
Old 09-28-2021, 12:36 PM   #341
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Thermal R&D exhaust is the best exhaust, hands down. Zero drone and a refined sound.
Lincoln Logs is offline   Reply With Quote
The Following User Says Thank You to Lincoln Logs For This Useful Post:
cjd (09-28-2021)
Old 09-29-2021, 06:01 PM   #342
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Since my season is basically done for Solo, what are everyone's thoughts on tire size? I ran RT660's in 255/40/17 and I thought they were fine but as the season progressed I always felt like I was a little off from others in BRZ/FRS/86 cars. At first I just chalked it up to my skill level but I ran a Track Event at Mid-Ohio in September and the car was definitely slower than last year when I ran 245/40/17's and no tune or header or any of the significant STX prep I did.
So, I feel like the verdict is that the 255's are actually a detriment but I am wondering what everyone else has experienced or thinks.
RT-BRZ is offline   Reply With Quote
Old 09-29-2021, 06:57 PM   #343
strat61caster
strat61caster's Avatar
Haven't tried 255s, never felt like the early cars needed taller gearing that comes with that tire, never did any maths or anything just a gut feeling that's the bigger impact then width or mass.
ineedyourdiddly
RT-BRZ (09-29-2021)
Old 09-29-2021, 09:30 PM   #344
Breezio
Breezio's Avatar
In general people don't run them on the 13-16 cars. I run 255's on my 2017 and it helps a little bit. Otherwise 2nd gear is just way too short. Heck, even with the 255's I top out at 55mph.
Off handedly I would chalk up being a little bit behind because of your tire choice, not your tire size. If you aren't running Yoks on a twin in STX, you aren't trying to win. Second best would be the Nankang CR1.
Old 09-29-2021, 09:38 PM   #345
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I ran the Nankangs for a bit when Yoks weren’t available, there honestly isn’t really any reason to run the Nanakngs over them other than that. They’re both about the same price once you pay for shipping from PTS. I was curious about what everyone was running at nats and looked at all the cars and pretty much 95% of the cars were on 245’s
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 09-29-2021, 09:54 PM   #346
renfield90
The Stig's German cousin
I've tried. I don't feel like it worked that well, here's my mental model for how they fare.
255s are a bonus on speed maintenance courses that also have a sustained high speed section at around 63mph. You're slightly faster than everyone on 245s there. So, like 10% of courses.
On pure speed maintenance courses (zero digs) with top speed <= 62mph (245s not bothered by the rev limiter) or with top speed > 64mph (everyone deep into third), there is no advantage either way. This is maybe 30-40% of courses.
If there is even one or two big digs (so all other courses), you get destroyed by everyone on 245s. Generally speaking our cars are thrust-limited coming out of digs, not traction-limited, and you are reducing thrust.
Bottom line is wider rubber should help in theory, but the gearing changes add a course dependency factor that is much larger than any extra grip you might get.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
Kelse92 (09-29-2021), RT-BRZ (09-29-2021)
Old 09-30-2021, 09:27 AM   #347
Autoxer62
Is anyone running the Borla Type S exhaust? I was thinking that one ticks all the boxes - a little lighter (10 pounds as I recall), not too loud, and from the looks of it should have really good clearance since the muffler's in the center of the car. Any first hand experience?
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 09-30-2021, 10:36 AM   #348
RT-BRZ
RT-BRZ's Avatar
Here's a video of a course that's short and tight:
In reviewing the run I felt like the car just didn't stay in the RPM range I would have preferred and that tires causing a taller effective gear ratio is the real problem. I was only about one second off the fastest cars of the day (Supra and '16 M2) but it still didn't feel like I was getting the most out of my setup.
(side note; I know I have a lot of opportunity to improve my driving. I'm just demonstrating what I'm seeing.)
Old 09-30-2021, 03:03 PM   #349
racingfool
racingfool's Avatar
Drives: Miata
At 7000 rpm?
racingfool is offline   Reply With Quote
Old 09-30-2021, 09:25 PM   #350
Breezio
Breezio's Avatar
Originally Posted by racingfool View Post
At 7000 rpm?
Just reviewed my data, 56mph, barely touching 57mph at 7500 rpm.
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 03:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
