10-13-2014, 06:16 PM | #337 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
RR_ZA1JA01C is missing, not out of order or whatever..and no B01C def. RR_ZA1JA01A RR_ZA1JA01E RR_ZA1JA01F |
10-13-2014, 06:37 PM | #338 | |
Best to confirm this with the OFT guts though. email them or call. always use the definitions from the oft website when editing the OFT tunes and always use the definitions for your tune revision ie V2 or V1.5. Use definitions from the OFT web site that come with the V2 tunes for editing OFT V2 tunes If you wanted to edit a STOCK tune you pulled from your car DO NOT use the definitions from the OFT site use the ROMRAIDER definitions from the romraider site. Again always check some known tables to see everything looks good. Unfortunately the naming of the defs has overlapped causing a bit of confusion. |
10-13-2014, 06:40 PM | #339 |
Ok so I am to use OFT_ def files in Rom Raider for OFT ROMs. I should only use the RR_ def files for a stock ROM (pulled from ECU)?
Edit: Ok I think this right because the tables look ok and I can finally see LC\FFS. |
10-13-2014, 06:44 PM | #340 | |
Always use the defs downloaded from the github site for STOCK ROMs pulled directly from a brz/86 Use the OFT defs matching the OFT tune revision Use the matching def for calid Always check some known tables in the tune/rom to make sure it looks ok, if it looks wrong calid/rom does not match = bricked ecu |
10-13-2014, 06:53 PM | #341 |
Ok yes that was just confusing seeing the RR_ defs in the same ZIP as their ROMs, and similarly named. It suggested to me I should use the RR def with Rom Raider, and the OFT def for the tablet or something. Thanks again for the help.
10-14-2014, 02:33 AM | #342 | |
2013 Lightning Red - 6MT Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler |
10-14-2014, 02:37 AM | #343 |
Pretty sure its because oft people are running the most up to date ROM even if they have a lower cal ID.
10-14-2014, 03:07 AM | #344 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
10-17-2014, 11:46 AM | #345 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
http://www.datazap.me/u/boofneenee/9...=1-4&mark=4686
Hi, did a long log yesterday with most of the drive on the highway . I did manage to get a couple of good pulls and I do not (with my limited tuner knowledge) see any issues. No flkc and knock correction, ignition adv held to 25. However, I did get kncok correction adjustments while cruising the highway. At one point you will see knock correction of 1.4. I remeber @steve99 saying anything over .7 could be an issue. But i also understand their are other variables i.e. kc learned to look at to help determine if its bad kr good knock (if their is such a thing) Would you recommend I post more logs or flash back to 91 tune. Thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels Last edited by Boofneenee; 10-17-2014 at 02:24 PM. |
10-17-2014, 05:30 PM | #346 | |
The Following User Says Thank You to steve99 For This Useful Post: | Boofneenee (10-17-2014) |
10-17-2014, 06:09 PM | #347 |
Drives: '13 6MT Raven FRS
Quick question as I never got an email back from the OFT guys.
Been using OFT for a while ago, simply got it and used the tunes that were preloaded on it (think it was 2 version before the 2.06 maps). The maps currently on there are listed as the A01C. Recently wanted to upgrade to the 2.06 OTS maps and when i went to add the A01C Stage 2 EL 91 map its giving me errors saying its not the right type versus my stock tune. Tried a couple different types and found that it will let me put the A00C tunes on there. Just want to make sure that I should be using that A00C tune, even though what I loaded before was just the A01C that came with the tablet preloaded and its not a bug that I can't load the new 2.06 A01C tunes on there. Thanks. |
10-17-2014, 06:11 PM | #348 | |
Go-Kart Enthusiast
I may have to go with a custom tune here to fix this issue. I will also try 93 from a different station thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
10-17-2014, 06:24 PM | #349 |
Where can I get the Original Stock Tunes?
Mine uses D00C.bin |
10-17-2014, 06:57 PM | #350 |
Go-Kart Enthusiast
in order for you to use the OFT you had to copy u your stock tune onto the tablet. its there. just look
FRS
Similar Threads | ||||
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 09:26 PM |
iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 08:17 PM |
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 12:23 PM |
OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 03:17 PM |
Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 09:02 PM |
