View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 12-20-2013, 11:18 AM   #3473
FR-S Matt
Originally Posted by mainstream View Post
Had my service rep order parts back in Nov, and had to call for a follow up to find out why they hadn't gotten back to me. When I called I talked to the service manager, and he looked it up, noticed that they had ordered the parts over a month ago. He checked and found out that they had the pump in stock for another customer so decided to give it to me since I was waiting longer. Net result at 11152 miles got the new pump installed all covered under warrantee.
If you are having problems getting services... make sure you do two things.
1. Take video on your phone of the chirping. (if you just drop off your car they may say... we didn't notice anything abnormal)
2. Take a copy of both TSB's Subaru and Toyota's with you
Everyone at the service department kept on saying it was a RARE problem like they had been told to say it.
I'll post updates if I notice the chirping return, you will notice the car sounds different with the new pump.
Here is a copy of my service invoice
You did exactly what I did. Things get done real fast when the customer is informed. You can put them in their place real fast. Hope you have good luck with the new pump. Otherwise, tell them you want it insulated if they come back!
Old 12-20-2013, 11:34 AM   #3474
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
After taking my car in last month for the first scheduled service i mentioned about the chirps. They were cool with it, and immediately ordered the part but it's on "back-order" at the moment. I took my car in last week for an CEL due to debris in the Oil Control Valve and without mentioning it they said they heard chirps and made sure i was on order for the new pump. But they said it's still on back-order with no time table, which i'm hoping is a good thing (maybe new revision to insulate?). Given Matt's situation with the dealer making the effort to fix it then I don't mind waiting a little longer.
JonAvalon is offline   Reply With Quote
Old 12-20-2013, 04:28 PM   #3475
mainstream
mainstream's Avatar
I hope the new pump works, not holding my breath. At least for the next 1000 miles I won't have to hear the girl at Taco Bell drive through go what's that sound? I just took a look at it, and they didn't insolate it. I was told that they were going to add this change to the TSB but I guess they didn't.
mainstream is offline   Reply With Quote
Old 12-20-2013, 05:53 PM   #3476
FR-S Matt
The insulation so far is good. They did fill my gas tank back up at no charge so I want to be sure it's working after a few tanks. They did not mention this revision would be in the TSB or not, but I bet this was their next step.
Old 12-20-2013, 06:00 PM   #3477
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Trying to impress her?
Old 12-21-2013, 05:42 PM   #3478
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
Knock on wood but no chirps since I had mine replaced almost two weeks ago.
BadMoon is offline   Reply With Quote
Old 12-23-2013, 11:46 AM   #3479
tinma
Drives: '13 BRZ
i havent been following this thread as much after i read that the insulated pump started to chirp also...was taht for you? did you get another pump again?
tinma is offline   Reply With Quote
Old 12-23-2013, 11:49 AM   #3480
FR-S Matt
This is the same 5176 part number pump that was chirping. All they did was insulate it now. I have no chirping for almost a week now, but it is still very early. After a few tanks of gas I'll report back here and to Toyota most likely to just revise a TSB to start insulating everyone's pumps. Not sure why this wasn't done in the first place.... Seems very effective.
Old 12-23-2013, 02:59 PM   #3481
strat61caster
strat61caster's Avatar
This will have the fuel pump run hotter as you're not going to get a cooling effect from air blowing over the pump. The engineers already accused your tune of making the pump hotter causing the chirps, so they add insulation which will dampen the noise but at the cost of the fuel pump increasing in temperature.
This probably wasn't done in the first place and will take time to phase out (if it does) because they had to run through the engineering to make sure that this doesn't shorten the life of the pump (notably the rubber seals inside the pump would be most susceptible to premature failure).
ineedyourdiddly
Old 12-23-2013, 09:15 PM   #3482
AznBRZer
Drives: 16 CBS WRX Limited
Had the pump replaced last Tuesday and the crickets are back. Compared to the woodpeckers, I'll take crickets anyday.
AznBRZer is offline   Reply With Quote
Old 12-23-2013, 10:28 PM   #3483
CARNZ
CHECK ENGINE
Drives: 2004 STi
I feel like they are already convinced the pump insulator will be okay since the 2014+ forester XTs come stock with the hpfp insulator. If they feel that it will be okay on those cars from the factory, I dont think we have anything to worry about.
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 12-23-2013, 11:05 PM   #3484
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
2014 BRZ with 3100 miles checking in. No chirping.
MagicBobert is offline   Reply With Quote
Old 12-24-2013, 11:10 AM   #3485
Euro7R
Drives: 2013 Subaru BRZ
Since ownership in March 2013, I've had the chirps a couple of times. Seems like hit or miss (Comes on days when it feels like it).
I do notice that sometimes, if I drive my car harder (Shift above 4000 rpm), it tends to chirp.
Euro7R is offline   Reply With Quote
Old 12-24-2013, 12:48 PM   #3486
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
2014 FRS at 2100 miles and I started getting the chirps daily now so I took it into the dealership and they ordered the new pump for me.
the new guy is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
