Old 05-25-2016, 06:33 PM   #3473
DHitHim
Drives: 2015 CWP Limited BRZ
anyone on here running the greddy oil cooler and ducting with this kit?
DHitHim is offline   Reply With Quote
Old 05-25-2016, 07:27 PM   #3474
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Just answered in the other thread you posted in. Recently had a customer ask if I could fit his Blitz(basically the same as the greddy) oil cooler with his JRSC, and it wasn't even a little close to fitting.
The Racers Line is offline   Reply With Quote
Old 05-25-2016, 09:11 PM   #3475
The charge piping and intercooler want to occupy the same space as the cooler and shroud. It won't work unless you HEAVILY modify it.
Old 05-25-2016, 10:24 PM   #3476
showoff3civic
Drives: 2015 BRZ
Are you going to be running E85?
Not sure - closest E85 is 150 miles away. I've heard it can be delivered but I was thinking if need be running meth
showoff3civic is offline   Reply With Quote
Old 05-26-2016, 11:23 AM   #3477
Hicklinc
Drives: N/a
You cant use the carb tune with that header
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 05-26-2016, 11:37 AM   #3478
Originally Posted by Calum View Post
I have a ACE CS400 header. Does that change matters?
You'll need a custom tune, or a Delicious FNG (we can package it together for you).
Calum (05-26-2016), SuperDave (06-05-2016)
Old 05-26-2016, 10:48 PM   #3479
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Any tips on fitting my front bumper on? The driver's side keeps popping out feels like it is right on the bumper touching the windshield wiper tank?
Jmonty is offline   Reply With Quote
Old 05-27-2016, 01:30 AM   #3480
Try gently poking the bumper, and see if a charge pipe is touching. If the pipe is touching, then it was incorrectly installed, and needs to be repositioned (pushed ALL the way in, and wedged between the windshield wiper fluid reservoir and front crash beam, with a pad cushioning it from the beam).
If a pipe is NOT touching, then it's highly likely that the bumper was damaged (deformed) during removal; it's very easy to do this, and preserving the bumper alone can make a good professional install pay for itself.
Jmonty (05-27-2016), kasikuusi (05-27-2016)
Old 05-28-2016, 11:47 AM   #3481
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
CCV line to Catch can to breather?
Greetings gents,
Does anyone see a reason I can't pull the half-inch line vac going from the CCV to the air intake and route that line to a catch can With the outbound port of the cc going to a small breather filter?
Aside from venting to atmosphere, is there any mechanical reason this wouldn't work? Seems to me this would eliminate no chance of any vapors or aerosolized oil getting drawn back into the intake, no?
Thanks,
Canyon.
canyons is offline   Reply With Quote
Old 05-28-2016, 12:11 PM   #3482
dj2020
Originally Posted by canyons View Post
Greetings gents,
Thanks,
Canyon.
That's what I plan on doing as well, except I'm going to do it without a catch can. I'm going to fit a breather filter directly on the 1/2" tubing coming from the CCV. Over time, my MAF has been slowly fouling and causing fuel trims to go negative. It finally threw a rich code one year post Jrsc install. When running my finger inside the intake tubing and throttle body, as suggested by @CSG Mike, there is a thin film of oil. It's my understanding that under vacuum, the CCV will pull air into the crankcase but under boost, air and oil will exit out the CCV. I'm hoping the breather filter over the CCV will fit the bill.
[ame="http://www.amazon.com/62-1600RD-Vent-Air-Filter/dp/B009774GCA?ie=UTF8&psc=1&redirect=true&ref_=oh_aui _detailpage_o00_s00"]Amazon.com: K&N 62-1600RD Vent Air Filter: Automotive[/ame]
I already have a Mishimoto catch can on the PCV side with a check valve so that the can never sees boost but intake manifold vacuum still pulls vapors from the PCV (while air enters through the CCV breather).
dj2020 is offline   Reply With Quote
Old 05-28-2016, 09:23 PM   #3483
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Make sure you either replace the ccv with a barb or remove the ccv and punch out the check valve...
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-28-2016, 09:49 PM   #3484
dj2020
What is the reason behind this? The CCV is a one way valve and not just a barb? I thought "air" flows both ways. Air flows into the CCV (drivers side) during vacuum/low load/cruising while air/oil potentially flows out during boost (hence fouling the MAF and coating the intake pipe/throttle body with oil). Just trying to understand!
Old 05-28-2016, 11:29 PM   #3485
porsche550s
Drives: 2015 Subaru BRZ
Mine did the same thing. Ended up having to install a quick release system on the bumper. My car is DGM so it looks pretty good but they make the kit in many colors and it was a generally easy install just lots of patience.
porsche550s is offline   Reply With Quote
The Following 2 Users Say Thank You to porsche550s For This Useful Post:
dp1 (05-31-2016), Jmonty (05-28-2016)
Old 05-28-2016, 11:54 PM   #3486
canyons
canyons's Avatar
Sorry, not a mechanic....Could you explain this further? Because I'm thinking I want the PCV valve to continue doing its job. Are you saying the slight vacuum created by the intake restriction is necessary ? Can you say for what?
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
