Old 05-25-2015, 03:00 PM   #3389
Scracho
Drives: 2018 Subaru BRZ
Originally Posted by scionfr_s View Post
Another video in the day light, I did adjust the tension a bit but it seem doesn't make any different at all
Mine sounds the exact same, seems to be tension related I find.
When I first installed my kit the tension was far too loose and I was getting the grinding noise at idle or on initial take off. I've tightened since and the grinding noise has gone away but that noise you have is still present. Going to play with Gates App to dial it in
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
The Following User Says Thank You to Scracho For This Useful Post:
scionfr_s (05-25-2015)
Old 05-26-2015, 01:38 PM   #3390
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by zoth View Post
On this link you can hear the noise from inside my house going into my garage. Freaking nasty noise is killing me :-(
Guys, I need your opinion. I tried my best to find this annoying noise with no luck. Sent blower and idler pulley's to @KraftWerks already. They did replace the idler's, but they can only do visual inspection on the blower. They said it will void warranty if they open it up, which is fine.
No boost leak or loosed hose, those where the first thing I checked. 3 freaking weekends already I wasted i trying to find the source of the noise. Removed bumper 3x already.
It's the back ground noise that goes up and down with the RPM. It's like our cricket's but much, much louder.
I attached the link for the sound clip. Noise BTW is gone when the belt broke the 2nd time. Noise is also present from 60 HZ all the way down to where I already have a belt slap.
Opnions will be highly appreciated. Thanks in advance.
https://drive.google.com/file/d/0B75...ew?usp=sharing
Now that you guys heared it, it's really freaking annoying driving around with that noise, specially when on stop light. It's also the last sound you hear after turning of the car.
Originally Posted by SPCorBUST View Post
Someone else's blower might be on the way out, I think it was @Freeman, maybe ask him (or whoever it was) if they had a similar sound before sending it in.
Maybe search for "strange/weird Rotrex sound" or "broken Rotrex?" on YouTube there might be some comparison clips.
@KraftWerks could also say something like "As one of the top distributors of Rotrex, we know when one is failing and it does/doesn't sound like that."
That sounds like the crickets, but from what you've said it's most likely the blower. Mine sounded like a louder supercharger whine, and ended up keeping the boost from climbing.
I haven't heard back yet on the warranty claim, but I'm almost ready to just buy a replacement and get reimbursed later if the claim is approved. Lack of driving in this beautiful weather is killing me slowly.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
zoth (05-26-2015)
Old 05-27-2015, 05:55 AM   #3391
limitedblkwrx
Ultimate Member
limitedblkwrx's Avatar
Drives: 2014 Satin White BRZ
Originally Posted by FRSTRM View Post
Just picked up my Kraftwerks SC last weekend! Waiting for my FRS to get back from the shop to start my install
I want a ride when you're done.
limitedblkwrx is offline   Reply With Quote
Old 05-27-2015, 10:57 AM   #3392
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Of course
FRSTRM is offline   Reply With Quote
The Following User Says Thank You to FRSTRM For This Useful Post:
limitedblkwrx (05-27-2015)
Old 05-27-2015, 09:45 PM   #3393
BRZ'13
BRZ'13's Avatar
Drives: subaru
is there any oil cooler that are compatible with the kit beside skunk2? I would love to be able to run a thermostatic oil cooler along a Koyo rad.
BRZ'13 is offline   Reply With Quote
Old 05-27-2015, 10:17 PM   #3394
Jcl
Drives: 2014 BRZ
You can just buy their 'sandwich plate' and buy any cooler you would want. The main reason why its compatible is the extra height and its not as wide as some of the other sandwich plated adapters out there needed to clear bolt that gets in the way of the others.
Jcl is offline   Reply With Quote
The Following User Says Thank You to Jcl For This Useful Post:
BRZ'13 (05-28-2015)
Old 05-28-2015, 11:34 AM   #3395
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Couldn't take the tensioner pulley bolt off bc it was too tight, and the head of the bolt about to strip, what should I do??
scionfr_s is offline   Reply With Quote
Old 05-28-2015, 11:48 AM   #3396
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Try a long nose vise grip.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 05-28-2015, 01:06 PM   #3397
BRZ'13
BRZ'13's Avatar
Drives: subaru
thank you. always assumed that the sandwich plate was for specific to the skunk 2 cooler.
Old 05-28-2015, 07:22 PM   #3398
vgi
Drives: frs
@scionfr_s I'm just curious how you were adjusting the belt tension before?!
vgi is offline   Reply With Quote
Old 05-29-2015, 07:54 PM   #3399
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Stuff like this should go into the first post. A section for "Common Issues" and "Common Fixes" would kill a lot of the noise in this thread, especially when the exact same issues (especially belt noise/tightness/looseness related) keep popping up.
It could be something simple, like links to the post for "Reducing belt noise", just like the link for clamping hoses so they don't pop off. We should make it easier for (new) owners to absorb some of the accumulated tribal knowledge, not force them to go through 150+ pages of mostly drivel just for the few good, relevant posts to whatever issue they're having. Searching through all that is tantamount to hazing.
agreed maybe @digital_assassin can add some links to the original post so all the important information can be indexed. I will soon test a few things at the track and get some datalogs, it's the track season again
glamcem is offline   Reply With Quote
Old 05-29-2015, 08:04 PM   #3400
glamcem
glamcem's Avatar
Originally Posted by Model Citizen View Post
i'd love to try the smaller pulley or a c38,
pretty sure it will result in broken bits sooner though wether it be clutch, axles or whatever else since the car only gets driven for autox/track atm it currently sees nothing but abuse.
most of the time it still seems like the extra power wouldn't really be able to utilized fully, the c30 and stock pulley (93 oct) goes very well (for my uses) when you dig hard on it (wot in 2nd a lot for autox, wot 3rd-5th a lot on track). With 265 re71-r traction isn't a huge issue, but its far from impossible to lose it either.
ended up parked next to a worked over elise with a c38 among other mods this weekend at a test and tune using a very short configuration to the local autox venue.
he claimed to be in the low 2000lbs range and over 400 hp, far greter power to weight than the c30 and frs, let alone he was a solid 100 lbs less than my fat ass.
still put about 2 seconds on him on a 40 second course.
For auto-x and/or track use I think smaller pulley would be a better idea since the penalty of using a bigger blower is also bigger in the low-mid range torque, with the smaller pulley however we simply shift the power curve to the left without the added parasitic loss .. I will probably get the smaller pulley and test the distilled water method combined with the watter method and a custom spray for the intercooler and get before and after data and share them here..
Originally Posted by CSG David View Post
That just means you can drive better than him.
exactly
Old 06-01-2015, 12:36 PM   #3401
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
@KraftWerks, I sent you guys an email about a broken belt.
PS has anyone bought that belt that was posted on the front page and worked with a c38? I have no high boost pulley. Just all the regular ones that came with the kit.
pgranberg11 is offline   Reply With Quote
Old 06-01-2015, 01:12 PM   #3402
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Welp time to get rid of my car. Loved the kit but the car doesn't get used much.
It was fun.
BRZZZZZZZZZZ is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
