#3389 |
Drives: 2013 FRS
They do get scrubbed on the first two runs for sure! I was just wondering whether there is any notable improvement in grip after they've been scrubbed and allowed to rest again.
#3390 | |
Rear I'm likely dropping to -2.5 Suspension setup and site will have a notable impact, maybe to the tune of half a degree? (super soft like off the shelf KW vs. super stiff Tein SRC, slick asphalt vs. grippy concrete) Not sure, but figured I'd pitch in some numbers. I've heard as high as more than -5 up front a few years ago. I stopped using the pyrometer, it was leading me to think that I was doing ok when I wasn't, I've borked tire pressures and camber because 'the pyrometer is where I want it' |
| The Following User Says Thank You to strat61caster For This Useful Post: | smg1138 (06-27-2018) |
#3391 |
Drives: 2017 BRZ
Two drivers and near 100F on a small crowd needed spraying. Not 3 minutes between runs. I think it was the sixth run that started to go. And we went to ten each heat that day.
#3392 |
Drives: '15 STX
Had two drivers and 95-100 this past weekend on high grip concrete. Zero issues. Dropped time every run. Tires are down to the wear bars.
#3393 | |
Drives: 2017 BRZ
I had near full tread. At a guess it was the really short intervals and the number of runs, and more squirm probably adds heat. I wish I had a codriver this year for the tires, but can't bring myself to hand over the keys on the new car after losing the last one that way.
#3394 |
A propper scrubbing/heat cycle should be done prior to competitive driving. It allows the tire to be brought up to temp, get cleaned off, and then fully cooled. This results in happy tires!
#3395 |
Drives: 2014 WRB BRZ Limited
#3396 |
( ͡° ͜ʖ ͡°)
Drives: 14FR-S
My diff is toast and I'm leaning towards purchasing the Quaife ATB. Done a few days of searching for info and there isn't much feedback on it. Does it really perform as well as the advertisement claims or is there something I'm missing? Any downsides to this I haven't read about?
https://shop.quaife.co.uk/subaru-br-...d-differential
“Has Anyone Really Been Far Even as Decided to Use Even Go Want to do Look More Like?”
#3397 |
Drives: 2013 FRS
What kind of use did you put it through to kill the diff? Just curious.
#3398 |
( ͡° ͜ʖ ͡°)
Drives: 14FR-S
Not too much, zero power added.. hard launching for a Pro Solo back in 2015, running whiteline diff kit lock out, and having 235 wide 200 treadwear tires on the car since 2014.
#3399 |
Drives: BlueBurz
First diff death I've heard of. Fluid change interval?
Sent from my SM-G930V using Tapatalk |
#3400 | |
( ͡° ͜ʖ ͡°)
Drives: 14FR-S
but now im a little more knowledgable and now realize my original question was kind of dumb. I realize the drawbacks to this quaife atb would be the exact same as the original torsen in the car, but now Im wondering what benefits you'd see from one of these quaife atb diffs v.s. just rebuilding my stock torsen? I know its a tq bias system but wondering if it had any mechanical advantages as in... are you paying for a better tq biasing system than stock? Also asking if this unit would be a strength upgrade handling abuse better than the stock torsen? I know all about why I should just buy a clutch type and why I shouldn't, but it's not something I really want for this car being just a pleasure vehicle that hits a bunch of autocross each summer. TL;DR if i was already in need of a diff would this quaife atb plug and play replacement be worth the extra money?
#3401 |
( ͡° ͜ʖ ͡°)
Drives: 14FR-S
Find a parking lot with enough room to safely slalom about or a lightly traveled road to get some heat in the tires. no need for anything overly aggressive or sliding about. just keep the temps up for a half hour or more. then let it sit for 24hrs to cure.
| The Following User Says Thank You to BE4VER For This Useful Post: | BR-ZED (07-06-2018) |
#3402 | |
Drives: 2013 FRS
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
