Old 06-27-2018, 05:37 PM   #3389
CoolHandMoss
Drives: 2013 FRS
Originally Posted by ka-t_240 View Post
any tire should be scrubbed/heat cycled before compition use to help clear the mold release off the tire.
They do get scrubbed on the first two runs for sure! I was just wondering whether there is any notable improvement in grip after they've been scrubbed and allowed to rest again.
CoolHandMoss is offline   Reply With Quote
Old 06-27-2018, 06:12 PM   #3390
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by smg1138 View Post
For those of you guys running RE-71R's this season, how much camber are you running? I'm currently at -2.8 front -2 rear and think I need more.
I'm no benchmark but -4 & -3 right now, fronts were showing outer edge wear but I'll be stiffening the front before increasing camber.
Rear I'm likely dropping to -2.5
Suspension setup and site will have a notable impact, maybe to the tune of half a degree? (super soft like off the shelf KW vs. super stiff Tein SRC, slick asphalt vs. grippy concrete) Not sure, but figured I'd pitch in some numbers. I've heard as high as more than -5 up front a few years ago. I stopped using the pyrometer, it was leading me to think that I was doing ok when I wasn't, I've borked tire pressures and camber because 'the pyrometer is where I want it'
ineedyourdiddly
smg1138 (06-27-2018)
Old 06-27-2018, 06:47 PM   #3391
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by tony_r View Post
There is no reason to spray the BFG.
Two drivers and near 100F on a small crowd needed spraying. Not 3 minutes between runs. I think it was the sixth run that started to go. And we went to ten each heat that day.
Old 06-27-2018, 07:38 PM   #3392
tony_r
tony_r's Avatar
Drives: '15 STX
Had two drivers and 95-100 this past weekend on high grip concrete. Zero issues. Dropped time every run. Tires are down to the wear bars.
tony_r is offline   Reply With Quote
Old 06-28-2018, 08:01 AM   #3393
cjd
cjd's Avatar
Drives: 2017 BRZ
Honestly not surprised.
I had near full tread. At a guess it was the really short intervals and the number of runs, and more squirm probably adds heat. I wish I had a codriver this year for the tires, but can't bring myself to hand over the keys on the new car after losing the last one that way.
Old 06-29-2018, 10:17 AM   #3394
ka-t_240
A propper scrubbing/heat cycle should be done prior to competitive driving. It allows the tire to be brought up to temp, get cleaned off, and then fully cooled. This results in happy tires!
ka-t_240 is offline   Reply With Quote
Old 06-30-2018, 03:59 AM   #3395
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Any particular procedure that you use for this?
BR-ZED is offline   Reply With Quote
Old 07-01-2018, 09:32 AM   #3396
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
My diff is toast and I'm leaning towards purchasing the Quaife ATB. Done a few days of searching for info and there isn't much feedback on it. Does it really perform as well as the advertisement claims or is there something I'm missing? Any downsides to this I haven't read about?
https://shop.quaife.co.uk/subaru-br-...d-differential
“Has Anyone Really Been Far Even as Decided to Use Even Go Want to do Look More Like?”
BE4VER is offline   Reply With Quote
Old 07-01-2018, 10:01 AM   #3397
CoolHandMoss
Drives: 2013 FRS
What kind of use did you put it through to kill the diff? Just curious.
Old 07-01-2018, 10:07 AM   #3398
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
Not too much, zero power added.. hard launching for a Pro Solo back in 2015, running whiteline diff kit lock out, and having 235 wide 200 treadwear tires on the car since 2014.
Old 07-01-2018, 05:57 PM   #3399
kinghurl
Drives: BlueBurz
First diff death I've heard of. Fluid change interval?
Sent from my SM-G930V using Tapatalk
kinghurl is offline   Reply With Quote
Old 07-01-2018, 08:36 PM   #3400
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
Just swapped in Motul gear 300 at 18k for the first change.
but now im a little more knowledgable and now realize my original question was kind of dumb. I realize the drawbacks to this quaife atb would be the exact same as the original torsen in the car, but now Im wondering what benefits you'd see from one of these quaife atb diffs v.s. just rebuilding my stock torsen? I know its a tq bias system but wondering if it had any mechanical advantages as in... are you paying for a better tq biasing system than stock? Also asking if this unit would be a strength upgrade handling abuse better than the stock torsen?
I know all about why I should just buy a clutch type and why I shouldn't, but it's not something I really want for this car being just a pleasure vehicle that hits a bunch of autocross each summer.
TL;DR if i was already in need of a diff would this quaife atb plug and play replacement be worth the extra money?
Old 07-01-2018, 08:54 PM   #3401
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
Find a parking lot with enough room to safely slalom about or a lightly traveled road to get some heat in the tires. no need for anything overly aggressive or sliding about. just keep the temps up for a half hour or more. then let it sit for 24hrs to cure.
The Following User Says Thank You to BE4VER For This Useful Post:
BR-ZED (07-06-2018)
Old 07-02-2018, 10:39 AM   #3402
CoolHandMoss
Drives: 2013 FRS
I'm curious about this as well. I have no doubt that there is room for improvement but I have had no problems with inside wheel spin or anything with the factory diff. I find it hard to believe that there's enough improvement to justify the cost of an upgrade. So I'm curious to hear from someone who has one.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
