Old 02-05-2014, 04:26 PM   #3361
fenton
Originally Posted by krulux View Post
Ok.. color me interested. I admit to being skeptical, given the only thing I knew of "electric superchargers" previously were the tiny gimmick ones found on ebay for less than $100...
I've spent the last couple/three hours reading this thread and the numbers don't lie. I already own the OFT and soon to own the OFH... and I've seen the results Shiv has posted. Impressive.
Up until today, I was only considering a rotrex or vortech solution (depending on what Vishnu has up their sleeve)... but now I will weight the Phantom SC as an option in the very near future.
Couple of questions...
What is the expected life-span of the ceramic bearings?
Can the bearings/unit be serviced?
Also, I suppose this applies to all FI applications... in a failure type situation, I worry about the supercharge and its motor parts or blade/impellers disintegrating. Is there to a way keep parts/pieces from being sucked through the engine? Maybe a fine steel mesh in the ducting that would not effect flow terribly?
Ill have to let Rob answer the question about the bearings however i think because he spins the comp so slow they last a very very long time.
This is machined with the same precision and tolerances as your standard compressor used on any centri sc or turbo. It is more of a hazard to try and place a screen in between the comp and the throttle body.
There is almost no possible way these things can explode at the RPM they are spinning(45k) unless you start bashing it with a hammer, even then the impeller would never disintegrate and go into the engine(realistically a bearing would fail and the SC would seize).
Good question though because i know i asked the same one to Rob about 6 months ago when we got started
fenton is offline   Reply With Quote
Old 02-05-2014, 07:27 PM   #3362
Robftss
Drives: VW
Originally Posted by mid_life_crisis View Post
@Robftss
Curse you for releasing this the same month my property taxes are due.
You must have a big house.
Robftss is offline   Reply With Quote
The Following 2 Users Say Thank You to Robftss For This Useful Post:
Mr. (02-06-2014), raven1231 (02-05-2014)
Old 02-05-2014, 07:34 PM   #3363
Robftss
Drives: VW
Myself and others (drivers) have been beating on the shop test vehicle since Jan 2013, on the same compressor.
It is now being subjected to a twin dump pack set-up.
So, I don't know when the bearings will time out.
Servicing: Just replace the motor/impeller cartridge with a new one.
Old 02-05-2014, 10:03 PM   #3364
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by fenton View Post
Updated first page with release information. I dont know if it is necessary to create a release thread itself? Thoughts?
I know that we could create a owners thread however there is a lot of good information in this thread as well.
To add to that, Fenton, Rob and I have been driving in some very cold temps, like today for example I think we hit - 24 and about - 30 with windchill, still not a single bearing issue
Sent from my SGH-I337M using Tapatalk
Bu-Tang is offline   Reply With Quote
Old 02-05-2014, 10:23 PM   #3365
bfrank1972
Drives: 2013 FR-S Argento
Holy crap, I'll never complain about cold weather again...
bfrank1972 is offline   Reply With Quote
Old 02-05-2014, 10:25 PM   #3366
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Btw- not sure if you guys saw but shiv will be doing a direct comparison of the vortech sc vs the phantom next weekend. Should be a fun shoot out.
Installed Mods:
The Following 5 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (02-06-2014), drewbot (02-06-2014), Jive Turkey (02-06-2014), normancw (02-05-2014), zc06_kisstherain (02-06-2014)
Old 02-05-2014, 11:19 PM   #3367
fenton
Awesome well we know the vortech will make more HP but I wonder what rpm it will cross the esc Hp.
Very interested to see results hopefully someone drives them both....maybe side by side ??
Sent from my HTC One using Tapatalk
Old 02-05-2014, 11:20 PM   #3368
Sojhinn
Sojhinn's Avatar
If he brings it down I'm willing to drive.
Installed Mods:
Old 02-06-2014, 12:11 AM   #3369
mid_life_crisis
Drives: FR-S 10 #103 AT
That's below freezing (centigrade) not below zero. Still too freaking cold for me, but not as bad as it sounds at first.
Old 02-06-2014, 12:20 AM   #3370
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
-24C is -11F according to the Googles.
Luckrider is offline   Reply With Quote
Old 02-06-2014, 01:37 AM   #3371
cuddefred
Drives: Black 86 GT
It's f@#%&!g cold according to my Goolies as well.
cuddefred is offline   Reply With Quote
Old 02-06-2014, 09:42 AM   #3372
raven1231
My ESC is on the way! Thanks ROB! @ Shiv will you have dynos anytime soon with the OFT, OFH and TQ250 on pump or E85? I am going to order an OFT and want to know if I should order the OFH as well.
Old 02-06-2014, 10:39 AM   #3373
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Here's me on USPS.com
SloS14 is offline   Reply With Quote
The Following 4 Users Say Thank You to SloS14 For This Useful Post:
Luckrider (02-06-2014), nlowell (02-06-2014), raven1231 (02-06-2014), VR46 (02-06-2014)
Old 02-06-2014, 10:43 AM   #3374
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
at Last!!!!! product is available. mad propb to Rob and Fenton and other beta testers!
now i gotta save my money!
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
