Old 09-14-2015, 06:49 PM   #323
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Oops, no copy the one labelled jdl. The car that's from actually has revworks. That's my bad.
Old 09-14-2015, 06:54 PM   #324
cawith
Drives: Toyota GT86 6M/T
I downloaded your zip from the first post with all the A01I files and copied from there so no worries.
But do you have a ZIP with all the A01G files from your screenshots, or do you only publish the A01I now?
cawith is offline   Reply With Quote
Old 09-14-2015, 07:05 PM   #325
Wayno
Wayno's Avatar
Now that I wrote the guide and AT and MT have consistent load limits there's no point, not without getting paid anyway
Old 09-14-2015, 07:07 PM   #326
cawith
Alright, no worries then.
Old 09-21-2015, 03:24 AM   #327
Wayno
Wayno's Avatar
Logs of v86 on track.
AFR log
http://datazap.me/u/wayne/v86at2-8-q...o=5&zoom=0-154
Another AFR log (different track)
http://datazap.me/u/wayne/v86at2-10-...rk=11927-12137
Knock log.
< 1 FLKC is fine. From experience you have to pull -1.4 to stop knock in some of the areas this happens, such as 3600/0.6-0.8. There's no point retarding timing further than the ecu does.
http://datazap.me/u/wayne/v86at2-10-...=2-4-5-9-13-14
Old 09-21-2015, 06:00 PM   #328
Chimera
Drives: FRS
did a search, didn't see anything specific to this,
Making my own e85 map based on your work, I see differences in these tables
Input A Rising Load Activation ECT Load 1
Input A Rising Load Activation ECT Load 2
Input A Rising Load Activation ECT Load 3
Input A Rising Load Activation ECT Load 8
What do these tables do (something with enrichment?), and should I use the values from the B01C original Roms or from your A01G & A01I examples?
Old 09-21-2015, 08:10 PM   #329
Wayno
Wayno's Avatar
Anything not mentioned is region/calibration specific and shouldn't be touched.
Old 09-21-2015, 08:37 PM   #330
Chimera
Drives: FRS
Good to know.. (goes to reflash car).
Anyways, it appears as if the difference between the two would lean out my tune in the middle temperatures if I am reading, and understanding correctly
Old 09-22-2015, 10:41 AM   #331
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I dont think the Load limit B and C is defined in the OFT tunes. How are you accessing these tables?
Intent > Content
Old 09-22-2015, 11:10 AM   #332
JB86'd
JB86'd's Avatar
Drives: JAWS
You need to use Wayno's definitions
Old 09-23-2015, 01:22 PM   #333
Chimera
Drives: FRS
just because I'm curious now,
what do these tables do really, and how would using the values from another rom effect my vehicle? (if these questions are unanswerable I would accept that answer, I'm just curious now)
Old 09-23-2015, 05:57 PM   #334
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Those tables, in older roms at least, are called Tau - namely, wall wetting specifically with Port injectors. They allow control of how rich or lean AFR is in rapid load transition conditions.
There are many more of these in the BRZ roms than in the older roms - I did not go through the logic thoroughly, but recognised them as I was going through the first round of defining these roms, so plugged them in. I suspect they are in play, but the interplay is much more complex given the hybrid injection system.
I would not mess with them - they can cause a real headache in low load situations if not properly tuned. The only reason these were dug out (by NSFW on the RR forums) in the first place was due to the rich condition on rapid load increase that people who had installed FMICs were experiencing.
Td-d is offline   Reply With Quote
Old 09-25-2015, 12:53 PM   #335
tomaszjanczak
Drives: Silver Subaru BRZ
I don't know if I'm just stupid but I have been reading all these threads and still can't answer these questions:
1. Is there a MT rom to compare the tables like MAF Sensor Scaling, Engine Load Limiter B Maximum, Engine Load Limiter C Maximum?
2. What to do for tables that the table axis are rescaled? Just copy/paste the whole table with the new axis?
tomaszjanczak is offline   Reply With Quote
Old 09-25-2015, 02:57 PM   #336
solidONE
solidONE's Avatar
1. You can either use your stock rom or OFT roms to compare changes
2. Si, or you can change each cell one at a time in romraider
Intent > Content
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
