Old 05-23-2013, 08:00 AM   #323
2forme
Originally Posted by Adeets View Post
@2forme can you contact gem and find out if he's completed this yet? Have him throw me a PM.
I'm sending out his email address to you now, though make sure you have your gem filter ready. Some things ahead may be exaggerated....
Old 05-23-2013, 11:26 AM   #324
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
I know it's not going to make more power, but can this kit be set up with a turbo-style BOV like the HKS SS? Something about that sound makes me smile..
hamlet is offline   Reply With Quote
Old 05-23-2013, 01:39 PM   #325
Dezoris
Dezoris's Avatar
Can you forward me his email address too? I have a few questions for him.
Old 05-23-2013, 01:53 PM   #326
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I think I would rather run the pully to utilize e85, and clip the boost progress with an EBC when running E10 then let the car pull the timing to cope with the extra boost being shoved down its throat.
How hard could this be? And the EBC locate it on the inter cooler, so it does fuck with the throttle body flow?
can you contact gem and find out if he's completed this yet? Have him throw me a PM, also while you had your vortech did you try something like this?
You can run a what some have called a "turbo fuse" to vent the extra flow, but you're then compromising efficiency. Simple to rig with a solenoid and we can do it via ECU control.
The way I see it you can do a few things to maximize output and switch with E85. All involve using a smaller pulley to achieve higher boost:
Use higher water/meth flow in combination with reduced timing when using pump gas.
Use lower water/meth flow (or none) with more timing when using E85. No hardware stuff required. As long as you have a sensible pulley size it will manage. But if you're shooting for 20 psi then forget it. This would work for a combo of ~12 psi IMO, give or take a few. Then on pump you run higher meth, retarded timings, and make less hp for a given boost level. Then fill up with E85, turn the meth/h20 down, switch to higher timing/more fuel map and enjoy the full boost.
Boost itself doesn't kill motors, too much power or knock does. A motor pushing 200hp that knocks will generate 10x+ the force on the rod that the 200hp does. A motor pushing 400hp with no knock generates only double the force of that 200hp. We've proved this with the mx-5 running 20 psi on the stock 10.8:1 cast internals for almost 4 years now, and tons of boosted hi compression cast motors doing the same. But 12.5:1 CR, 20 psi, and pump gas--you're approaching diesel like ignition so no amount of fuel or timing retard can do this properly. But if you planned to do 8 psi on pump, 12 psi on E85, this is very easy to manage with fuel/timing.
Xero-Limit is offline   Reply With Quote
Old 05-23-2013, 02:02 PM   #327
Dezoris
Dezoris's Avatar
Here are my questions for owners:
1. What problems or issues have you had post install?
2. Did you make any mistakes or should you have done anything different?
3. How do you feel about the performance, anything strange in terms of noises sounds you hear at low RPM and higher RPM?
4. Where do you mount or hide the stainless steel drain line? Nothing in manual about it.
General Questions:
1. Is there a guide to changing SC oil?
2. What are problems or signs of problems to be looking out for?
3. Extra belts is it Gates Model: K060975? What about using Gates Green Stripe Micro-V Belt
4. Manual mentions you can't drive in temps below 25 degrees is that true, never heard that you cant drive it in winter before?
Old 05-23-2013, 02:09 PM   #328
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Brian can all the questions that were answered be moved to the first page? That way you dont have to answer the same ones, and others can skip pages in the thread. Just thought of it being a little help for you and everyone else. :happy0180:
Unless thats too much work sorry i wont be lazy
Marcoscrdo is offline   Reply With Quote
Old 05-23-2013, 03:42 PM   #329
Foobar
SLO NO MO
Foobar's Avatar
1. None so far.
2. Only thing I'd do differently would be to use progressively larger drill bits starting from a small one on the bumper support. I went straight to the required drill bit size and ended up not hitting the desired location with precision.
3. Performance is what I expected out of a centrifugal supercharger. I'm planning to put it on the dyno at some point but the butt dyno is pretty happy. At low RPM I can tell the engine isn't struggling as it did stock, at mid RPM to high RPM I can definitely feel the extra pushing back into my seat. It has no sudden onset of boost like you'd see on a turbo - so that could be a pro or a con depending on what your disposition is. No strange noises that I wasn't expecting.
4. I leave the oil drain hose coiled up in place.
General Questions:
1. I think gmookher and possibly one of the Phastek guys posted about the oil change. The takeaway was that you shouldn't use the full bottle of oil as there is still some left in the unit.
2. Until I get really used to this setup, I'm constantly checking my fittings to make sure everything is still plugged in where it should be, I check that the belt isn't rubbing up against anything, I check that the mounts are still secure, and I pay attention to any engine knock.
3. Haven't looked into a belt replacement yet.
4. I think the <25 degree engine start is targeted more towards the SQ series of Vortech superchargers, at least that's what I'm seeing from other forum discussions, but we should get Brian to weigh in on this one to be sure. In the meantime, a heated garage or block heater would be a great thing to have if your winters see temperatures < 25 degrees and those options are available to you.
The Following User Says Thank You to Foobar For This Useful Post:
Sniper2606 (05-23-2013)
Old 05-23-2013, 04:06 PM   #330
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Where'd you come from??? lol Are thinking about getting a SC kit?
Darryljr11 is offline   Reply With Quote
The Following User Says Thank You to Darryljr11 For This Useful Post:
Marcoscrdo (05-24-2013)
Old 05-23-2013, 04:09 PM   #331
2forme
Gem blew a seal on his, so I would definitely check for compressor leaks. It's a self contained system and with the shipping plug in, it should be bone dry on the outside.
Old 05-23-2013, 04:12 PM   #332
OrbitalEllipses
Drives: Attitude
Gem blew a seal
Or did he just have some vanilla ice cream?
The Following 4 Users Say Thank You to OrbitalEllipses For This Useful Post:
2forme (05-23-2013), civicdrivr (05-23-2013), King Tut (05-28-2013), Sportsguy83 (05-23-2013)
Old 05-23-2013, 04:41 PM   #333
2forme
Well, it was a Perrin seal....
The Following 4 Users Say Thank You to 2forme For This Useful Post:
civicdrivr (05-23-2013), King Tut (05-28-2013), OrbitalEllipses (05-23-2013), Sportsguy83 (05-23-2013)
Old 05-23-2013, 04:42 PM   #334
OrbitalEllipses
Drives: Attitude
OH MY GOD. Almost lost my S%&# while on the phone with a customer. Funny man.
2forme (05-23-2013)
Old 05-23-2013, 05:09 PM   #335
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Are you referring to the seal issue that took place when him and I were on the track a couple months ago?
If so he didn't actually blow a seal. The SCer just burped the over filled fluid out from heat expansion caused by over filling it. He just sent it in to Vortech for verification that was all that happened. They did however replace all the seals as a precautionary measure since it was already there and apart.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following 2 Users Say Thank You to AZFA20 For This Useful Post:
2forme (05-23-2013), Pete (05-23-2013)
Old 05-23-2013, 06:35 PM   #336
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
General Questions:
1. My oil was over filled and it spewed all over the engine through the vented plug. I drained it until it was the proper level. Since said time I drove it hard and even drove it for 12 hours in 2 days with no issues.
2. see #1
3. Performance is on point. At no time does power "kick in" but rather comes on smoothly through all ranges but you really feel it come on at around 4k rpms. I know I said this before but it now drive how it looks. I have a vibration sound that resonates around 4-5k and I'm almost positive its coming from the air filter door where it "locks down". Theres some play in those 2 lock bolts.
4. Zip tied it to the radiator fan support.
1. Unscrew dip stick and pull out slightly, undo nut at the end of drain hose, place water bottle as far down into the engine bay as possible, place drain hose into bottle, and allow to drain. Place nut back on hose, zip tie off somewhere, according to Jamie (tech at Vortech) fill until the oil is in the middle of the "cross grid" on dip stick, screw dip stick back in, and enjoy.
2. normal mechanical signs
3. idk
4. idk
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
