#323 |
Drives: 2015 Scion FRS Release Series 1.0
Yes RCC SS1s come with camber plates.
Also I thought 5mm spacers don’t need stud replacements? Or is that a myth |
#324 | |
Drives: '23 BRZ Limited
#325 |
Drives: 22 BRZ limited
Wouldn't ET38 poke more than ET42?
| The Following 3 Users Say Thank You to dragoontwo For This Useful Post: |
#326 |
Drives: 2022 GR86
The threads on the stock studs on the first gen are known to be pretty weak, and have just enough engagement when not using any spacers. I would strongly advise against running 5 mm spacers with stock length studs.
#327 | |
Drives: 19 86, 22 BRZ
From what I remember, the tab that protrudes inwards needed to be shaved pretty significantly and some of the inner fender liner was cut in that area as well. I had someone that specializes in fender rolling in the socal area handle the cutting/shaving process. |
| The Following User Says Thank You to jongers For This Useful Post: | OkieSnuffBox (01-29-2022) |
#328 |
Drives: 2022 crystal white BRZ
It would, but he's looking at an 8.5 instead of a 9 in wheel width, so it should have almost the same poke as my setup does in ET38.
| The Following User Says Thank You to CZ6T For This Useful Post: | dragoontwo (01-30-2022) |
#329 | |
Drives: 2022 BRZ Limited
I noted that the front studs seemed quite short and did not appear to offer sufficient length for any sort of spacer. |
#330 | |
Drives: ‘22 CWP
#331 | |
Drives: Frs
+45 on kw’s no issues plenty of clearance. +45 on kw”s -2.2 camber no rubbing anywhere up front or out back with not too much drop.
Ridiculous!
#332 |
Drives: 2022 GR86
Interesting info in this post:
https://www.instagram.com/p/CZUVYYrJwM8/ 19x9.5 et44 wrapped into ADVAN NEOVA AD09 245/35R19
| The Following User Says Thank You to timurrrr For This Useful Post: | dsc_pat (01-30-2022) |
#333 | |
Drives: GR86
#334 |
That's actually pretty good. I think a little forward rake is appropriate. Front of mine is about 3/8 lower than rear.
#335 | |
Drives: 1996 Turbo Miata
#336 | |
Drives: ‘22 CWP
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 11:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 07:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 08:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 05:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 04:34 PM |
