#323 | |
Drives: Subaru Legacy
Most likely they will be introduced over the next year or two in different models. EJ will be replaced fully when the FB has proven its self and any faults sorted out. Last edited by [es vi: eks]; 04-05-2011 at 03:41 AM. |
#324 |
Kuruma Otaku
EJ is like a quarter century old, like ^ said, FB will replace it soon.
I'm not sure of what the cost/benefit of something like Valvematic would be in a performance role. No need for it in the LFA (or any lift control for that matter...) so it likely is better in emissions/economy control.
Because titanium. |
#325 |
Drives: '06 AM V8V Coupe
Valvematic I think would give a slight max torque increase over cam switching with probably a good amount more near the profile switching point and at very high rpm, but the main benefit would be fuel economy probably...which does matter for a low end car doesn't it? It does add cost to the car, but the US has finally adopted the stricter fuel efficiency standards, and it'll make it easier to hit emissions requirements, plus add some "green" image to the company lol.
LFA is a pure performance/exotic car hence no need for fuel economy enhancements. |
#326 |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
^ I've said from the beginning that this car should have valvematic
I just hope it actually happens, even though it will make the car cost more...
#327 | |
Mr. Detail
Drives: 2003 Celica GT-S
I'm fine with paying more for things I can't make up for with easy mods, if you know what I mean.
#328 | |
Drives: 2000 Celica Gts
I agree with above. I'd prefer to pay quite a bit more for a better/more powerful/more efficient engine. Honestly I'll probably just do intake exhaust and maybe flywheel/clutch and a drop depending on what stock height/ride comfort(roads here are shit) are.
The less I have to buy to make the car "right" the better.
#329 | |
Supra Owner
![]() Things like Valvematic, ABS Brakes, a good Trac Control system (among many other things) are all near impossible to add without spending a shitload more than what the parts are worth... so those sorts of things I don't mind paying more for.. however, things like a good stock exhaust, are a lot lower on the list, because they can easily be replaced with aftermarket parts that are usually, lighter, and overall better than the stock parts.
#330 | |
Mr. Detail
#331 | |
Kuruma Otaku
But light, rigid chassis should be the MOST IMPORTANT thing on everybody's list. It makes the handling people happy, the speed people happy, and even the tree hugging hippies happy.
Because titanium. |
#332 | |
hashiryu
Drives: Mk4 Supra
Not disagreeing, I'm totally on your side, just saying. |
#333 | |
Drives: Miata
This is all stuff you can do on your own for basically nothing. |
#334 |
Delights in pure handling
Drives: Zoom Zoom
If you are going that far, might as well take out rear seats plus front passenger seat. Take out stereo. Take out power steering.
#335 | |
Lude Dude
Drives: 1998 Honda Prelude
By contrast, my 540 had TONS of torque, and while it made driving a little more exciting, it was no better or worse for commuting. With that said, I like my engines to have power up there in the rev range, like the F20C in the S2000, the H22A in my Prelude, etc... That way, I can drive like a granny on my day to day grind, and when I want performance, downshift and open the taps. The only "problem" I see is that when I want to pass I have to downshift to get on the power. I personally don't see that as a problem, but people don't like to feel like they are making the engine struggle. What they may not understand is that these engines are made for that, and sound great at high RPMs. I hope the FT-86 has similar driving characteristics to the S2000, engine wise at least. One can dream... |
#336 |
Drives: Miata
If you read the post I was quoting...Dimman stated:"cutting weight (without gutting your car) is REALLY hard." I simply added a couple of things that could be done to lighten the car without gutting it.
| Project Engineer hints at weight of roughly 2700lbs | zigzagz94 | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 03-09-2011 06:20 AM |
