Old 12-17-2015, 03:47 PM   #3319
jvincent
jvincent's Avatar
Originally Posted by RacingCanuk View Post
What's the best bang for the buck way to get enough negative camber, with stock suspension, for track days (high speed circuits)?
How about 'Crash bolts' in the front and White Line bushings in the rear? Will that be enough?
Best you will get with crash bolts is -1.5* up front. Also, if you end up going with bigger wheels/tires you start to hit the spring perch/spring at about 1.5* as well.
Camber plates are good option for getting extra.
Old 12-18-2015, 02:12 AM   #3320
troek
troek's Avatar
Drives: 2012 Toyota 86
you can run a camber bolt in each hole. im sure some will warn against it, but a couple of us on here have ran it that way for awhile. as long as you can torque the bolts to factory specs, it shouldn't be an issue.
Old 12-18-2015, 03:44 AM   #3321
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Originally Posted by MaximeT View Post
The rail is 1m after the grass. 10m is 1000€. There is 3 rails on top of each others.
If you make a mistake, you don't only loose the car, but you need to pay for track damages.
Just keep a margin. There is nothing like the Ring, everything is boring in comparison.
Old 12-18-2015, 03:51 AM   #3322
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
It's hard to decide between driving Spa at 100% or the ring at 90%
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 12-18-2015, 04:00 AM   #3323
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Being 1h drive from one another, you can totally do both on a weekend.
On the other hand, expecting to go 90% on your first visit is the first step to get your very own guardrail section.
Old 12-18-2015, 04:28 AM   #3324
MaximeT
MaximeT's Avatar
I was thinking 90% after the learning process
Old 12-18-2015, 12:44 PM   #3325
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
CSG Michelangelo what are your thoughts on foil wrapping intercoolers airbox and intake piping ?
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
Old 12-18-2015, 12:46 PM   #3326
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I did this to my TRD air box, and did some data logging, and I can say it made little to no diffrence for my intake temps for spirted street driving.
Old 12-18-2015, 12:56 PM   #3327
Icanfaptothis86
The airbox on the 86 is far from the exhaust and pulls air from a cool source under the bumper so I imagine there would be little impact
On my R53 track car I have a top mounted intercooler while the airbox is retardedly close to the headers - I suspect there may be a little to gain
I will do anything to cut down my heat soak ... at this point id give richard simmons a blowey
Celery man
Old 12-18-2015, 01:04 PM   #3328
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
If you think you have performance to gain (and safety for the engine) go for it. I'd personally use some of the woven heat tape (with foil covering) instead of the foil tape that's so popular, only because the foil tape is really only effective on radiant heat while the woven stuff is a good insulator.
Does your R53 have well sealed ducting to the top mount? I know that they weren't sealed amazingly well from the factory and can benefit from simple mods to seal and improve the ducting.
Old 12-18-2015, 01:14 PM   #3329
Icanfaptothis86
No its not a tight seal and when i upgrade to the forge motorsports IC it will be even worse.
THe woven heat tape is basically an exhaust wrap right ? I would think it would be most appropriate to wrap the exhaust and foil the airbox
My fabrication/racecar wizard guy is telling me I really need to vent the hood near the headers.
I am also thinking about routing a HVAC tube to basically take air from the front and dump it on the top of the headers to prevent the air from rising as much (not sure if that will work
but basically im not super stoked about my engine temps and i dont want to blow the motor. ... I will be getting an oil cooler on the car next month
Celery man
Old 12-18-2015, 02:57 PM   #3330
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Get one of those snazzy air diverter things.
The woven tape is essentially header wrap, yeah. The stuff I used on my GTI has a foil covering to reflect radiant heat as well.
Venting the hood at the rear will be tough because it's a high pressure zone. Might be more effective to put a NACA duct directing air down over the header.
What kind of temps are you seeing? With a proper oil cooler I've not heard of any major issues on the R53s besides IATs due to heatsoak.
Old 12-18-2015, 03:58 PM   #3331
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The only suggest I've seen regarding crash bolts above and below is that you may want to retorque them now and then.
Old 12-19-2015, 12:27 AM   #3332
LittleBlueGT
Drives: 2013 STI
FWIW I rented a car to run the ring this April, and it was $200 Euro extra for insurance that had an excess of $2500 Euro, but included recovery and Armco damages.
That was on a track prepped Swift.
I think the cost was the same for the faster cars, just that the excess (or deductible) was higher.
LittleBlueGT is offline   Reply With Quote
