Old 04-25-2015, 02:02 PM   #3277
jflogerzi
jflogerzi's Avatar
Sweet! Really like this kit and it being carb legal....
Old 04-26-2015, 11:53 AM   #3278
Barbas
Drives: 2013 whiteout Frs
Sorry, sure its been asked a few time but don't want to go through all the thread. I have the c38, 550cc injectors, and running e85. My question is to get to 350whp what will it take. Everything else in car is stock. Have yet to dyno it.
Barbas is offline   Reply With Quote
Old 04-26-2015, 12:07 PM   #3279
SPCorBUST
SPCorBUST's Avatar
You should be able to hit that easily
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-26-2015, 12:09 PM   #3280
SPCorBUST
SPCorBUST's Avatar
Originally Posted by KraftWerks View Post
GREAT NEWS Coming VERY SOON.
It's taken far too long but the wait is coming to an end!
(Orange Exhaust tip covers are so the CARB techs can connect to the sampling system as well as extract the fumes, gases out of the building. Also have the hooks installed to keep the vehicle firmly planted on the dyno during the testing.)
We've been hearing this for over a year. When is very soon exactly?
Old 04-27-2015, 10:46 AM   #3281
jflogerzi
jflogerzi's Avatar
New clutch and a good tuner.
2013 Series 10 FRS #553
Old 04-27-2015, 11:21 AM   #3282
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@tahdizzle who loves CARB.
The Following User Says Thank You to King Tut For This Useful Post:
tahdizzle (04-27-2015)
Old 04-27-2015, 01:01 PM   #3283
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Another KW belt shredded by a Facebook user. Apparently in 1.5 months and 3k miles. Not affiliated just making sure yall are aware of the issues.
Old 04-27-2015, 01:04 PM   #3284
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Hmm I have 1k miles on mine now after installing it last month. I'm assuming the belt was not tensioned properly.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 04-27-2015, 01:15 PM   #3285
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Ian, he had over tightened it. Thank you for your concern for kraftwerks owners.
Freeman is offline   Reply With Quote
The Following 3 Users Say Thank You to Freeman For This Useful Post:
Billion (04-27-2015), glamcem (04-27-2015), kombatlion (04-29-2015)
Old 04-27-2015, 01:21 PM   #3286
Triumphrider
Lol I'm in the garage snugging mine now as I was getting a bit of belt slap at start up
Old 04-27-2015, 01:22 PM   #3287
ATL BRZ
ATL BRZ's Avatar
The owner is only guessing that it was too tight. He never mentioned where he had it or if he used the app to confirm it was within spec.
The owner just admitted he was not given a recommended belt tension by KW with the 90mm pulley he purchased from them directly. This makes me think KW didn't do enough (any?) track testing on their product to determine the recommended tension OR maybe KW's cogged pulley/belt design is fundamentally flawed due to the increasing number of broken belts as evidence.
No play = something has to take the force when you do a hard shift. Normal belt systems are intentionally designed to momentarily slip to release the energy. With KW, the belt has to take all that load, and it can only do it so many times...
Old 04-27-2015, 01:27 PM   #3288
Billion
Drives: 2013 Toyota 86
I would assume the required belt tension would be the same no matter what size pulley you ran? Also if Rotrex themselves say cogged belts shouldnt be used with their blowers why do they warrant them through Kraftwerks?
Billion is offline   Reply With Quote
Old 04-27-2015, 01:30 PM   #3289
Triumphrider
I started out with using recommended measurements, frequency, etc. Now I just snug enough so that I don't get belt slap at low rpm and call it good.
The Following 2 Users Say Thank You to Triumphrider For This Useful Post:
Billion (04-27-2015), zoth (04-30-2015)
Old 04-27-2015, 01:57 PM   #3290
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I haven't seen too many cog belt designs for superchargers. I figure a 6 rib belt is sufficient for all the other accessories on the vehicle, including A/C. If the drive system were a dedicated 6 rib design, would it be able to handle the stress? All of the other systems utilize a standard serp-belt and operate just fine up to 300whp. After that, and I would probably carry an extra belt in the trunk.
I think it's strange the other KW supercharger kits use serpentine belts as well. Is there a possibility of a design revision down the road? On that would utilize a standard belt? Or even a timing-belt design that would be a little bit more available should a belt break?
Anyway, of all the kits I've seen I like this one the best overall. But I do have concerns about this belt drive system.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
