#3277 | |
You're leaving out the ball joints for the LCA's, swapping over the OE is whatever labor costs (and fingers crossed you don't damage them in the process), having RacerX provide them brings it up to $743 according to their website. Shits complicated yo, just wanted to point out that the Cascams are very close to what you want as an off the shelf solution without cutting and welding on your chassis, ordering custom parts, ordering parts that you don't know if they will fit, or significantly sacrificing NVH (mine passed the gf test, nobody but me could tell I had camber plates in). And on the increased caster front: http://www.ft86club.com/forums/showthread.php?t=118314 http://www.ft86club.com/forums/showthread.php?t=74300 |
#3278 |
Drives: 2017 WRB Subaru BRZ
#3279 | |
Drives: 2013 BRZ automatic
First, thank you for the good feedback. You are right on about pricing, the NVH feedback is very helpful, and I was not aware of the potential power steering issue. I am going to stay with OE springs and I thought that meant only a small range of adjustment available from camber plates. You say you got +1 degree caster with the CasCams. Was there any gain in negative camber available at the same time? In my case, I need a degree of camber to get rid of the wheel spacers; I'm trying to understand if I can get that plus some positive caster with OE springs. I'd be interested in the same feedback on RCE (or any other) camber plates as well, although I suspect the limitations are similar on all. |
#3280 |
Drives: Track preped NA FRS
You see, this is where you are wrong. If you think a change of 1 inch in CG has no significant impact on handling, you have no business talking about handling.
#3281 | |
Edit: I think you may be confusing the cascam with camber plates that are angled such that adjusting the position changes caster & camber, that's not really common on this car, almost all camber plates for this chassis are set up to adjust camber only, caster is adjusted by shifting the mount point towards the back of the chassis, racecomp does this in a fixed way by basically offsetting their studs compared to the oe top hat, the camber slot is basically shifted back compared to a camber plate that keeps OE caster. Raceseng plate has slots in it allowing the plate to slide back and forth in the car, their website should make it pretty clear. I don't have any experience with other camber plates, sorry. |
#3282 |
Drives: runs&drives
#3283 | |
Drives: 2013 Subaru BRZ
Fitting stiffer springs without dropping the ride height will give you most of the change in weight transfer rate and reduced camber change you are actually noticing from the drop and is a more sensible decision for road use. On the other hand, reducing the ground clearance by 40% makes a huge negative difference, especially on bumpy roads. Not to mention driveways and speed bumps. And I'd be willing to test my lap times against yours any time. Each to his own. |
#3284 |
I dont need to "believe". I have data that shows a gain in lateral grip generated by being 1.5" lower, as well as lap times improvement. This isnt rocket science, if you change something in the car setup, and that change makes you go faster, its a good change. I will "believe" data and laptimes over any non sense you may say here on anywhere else. Needing softer springs... lower CG not affecting handling... how can people even take you seriously is beyond me.
#3285 | |
If you also changed the spring length or rate then you can't know what to attribute just to the CG change, now can you? |
#3286 |
Off Topic
Your lap times from... driving like a dipshit on public roads? Those lap times? You've already said that you've never had your car on a track and all of your vaunted expertise comes from driving on streets. Or did you forget that part of your story, ubersuber? What kind of lap times are you throwing down on the way to Tim Horton's?
The fact is that whether you're trolling or you genuinely believe what you're saying, no one will listen to you because you're flat out wrong about so many things that are easily proven otherwise. Especially when people go back and read your previous usernames' idiocy. |
#3287 | |
Off Topic
http://www.ft86club.com/forums/showthread.php?t=119063 |
#3288 | |
#3289 | ||
Checking Raceseng's site again they phrase the -4.5 degree claim appropriately: Quote:
#3290 | |
I am interested is the CasCam's for my BRZ. I have OE springs with Bilstein B6 struts. I have two questions: 1. If they are set to get the 1 degree of additional positive caster, what is the maximum additional negative camber (over and above stock) I can expect (again, OE springs)? 2. In the nominal position for caster and camber (same as stock), how much should I expect they will raise the front of the car? From customer service: Hi John, The Cascam is designed with a range capable of a max of -4.5 degrees negative camber and up to +1 positive. The stack height compared to the OEM top hats is less with the cascam, not by a significant amount but slightly, so it will sit just a bit lower than it would with the OEM top hats. Thanks. Ryan Because I didn't believe that camber was possible with OE springs and I was also surprised that he said it would lower the front of the car (you said it raised yours a bit) I provided this response to see if I'd get a different answer: As for camber, I didn't know there was that much room to move the OE spring inside the strut tower. And the stack height is impressive. Raceseng didn't respond to this. Bottom line: with around 2 degrees more negative camber and not much change in ride height, I'll be happy and I placed my order. That being said, I did feel like Ryan in customer service was being extremely misleading, especially given how clearly I asked the question. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
