Old 02-07-2014, 10:37 AM   #3263
DriftEm
DriftEm's Avatar
Originally Posted by evo4g63 View Post
+1 I run E85 100% of the time due to the fact there are 4 gas stations within 5-10min of where I live. I also feel a lot safer running on the corn
The extra power doesn't hurt either
Sent from my SAMSUNG-SM-N900A using Tapatalk
DriftEm is offline   Reply With Quote
Old 02-07-2014, 10:43 AM   #3264
swift996
swift996's Avatar
Pulling up and filling the vehicle up to drive it normally is okay. To get the full ethanol content of E85 it needs a few tanks to be ran through when switching from 91/93 to E85. I wouldn't just fill up with E85 after having pump in the car and than go all out WOT. This has been tested using a ethanol content reader on various vehicles before on many platforms. No bashing towards you I just wanna clear that up for the OP asking questions. I don't wanna see another car blow up on this forum for a while.
I literally time it so my car is running on 93 fumes as it's pulling up to the pump and drive it conservatively for the first 2-3 gallons. I'll usually cycle a couple tanks too. That's the only annoying part for me other than the distance, is having to calculate the perfect time to go get e85. I don't like mixing fuels too often.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-07-2014, 10:51 AM   #3265
xxscaxx
Drives: 2013 SWP BRZ
That is the exact reason why I picked up a flex fuel kit.
I have one station for e85 by me. Just easier to run it whenever I want and not even have to worry about how much is left over in the tank, whether it be e85 or 93.
xxscaxx is offline   Reply With Quote
Old 02-07-2014, 11:08 AM   #3266
phloozy
phloozy's Avatar
Drives: Scion FR-S
I need to pick one up. Right now I am on e85 98% of the time but will put $10 of 93 if I'm not near a station. Its pretty annoying that I have to plan on being at a station when I hit empty to put in 93 then again for when I am ready for e85 again. It's very rare that this happens to me though.
phloozy is offline   Reply With Quote
Old 02-07-2014, 11:15 AM   #3267
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Originally Posted by swift996 View Post
Yeah, my bad, my terms are all off. So the radium supplied hose just inserts to the factory hose? I guess my question is can you remove the OEM hose so you don't have hoses disconnecting.
It is possible to replace the existing hose but it is NOT easy.. I replaced it because that was where my vacuum leak was coming from. The factory hose does not have any clamps on it. The only way to replace it is to take the throttle body off. Pulling the existing hose off is the easy part but getting the new hose on is a pain. I ended up taping the hose to the end of a socket extension. I made sure to leave a long tail on the tape so once I fished the hose onto the fitting I could unwrap the tape securing the hose to the extension. It isn't too hard to get a long screw driver down there to secure the hose clamp either. Just go in under the the the charger from the passenger side parallel to the ground..
The fitting on the block is a 9mm fitting. The factory hose goes from 9mm to 15 mm so you will have to either get a different sized nipple for the catch can or find a way to step up the size. I just used a 9mm fitting on the catch can.
For those of you who are running a dual catch can setup. Could you please report back in a little while and let us know how much oil you are catching in the NON PCV can? I haven't seen much residue coming from that hose and would like to see how much it catches. THANKS
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 02-07-2014, 11:20 AM   #3268
xxscaxx
Yeah this is what I wanted to avoid. I picked up @PrimeMotoring 's flex fuel kit, hoping it comes in today (think it was shipped yesterday) so i'll be installing it this weekend/week. Can report back on it, but a bunch of other cars are using it and they seem to be great so i'm not expecting anything negative from the kit
Old 02-07-2014, 11:28 AM   #3269
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
This is true, after having ethanol in the car I wouldn't want any loss in power by having to run pump gas.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-07-2014, 02:58 PM   #3270
ntaphse
Drives: beater
What?? Where do you live? I'm in North Phx and to my knowledge there isn't any E85 up here. Wish I could make the switch but it has to be convenient.
ntaphse is offline   Reply With Quote
Old 02-07-2014, 03:34 PM   #3271
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I'll soon be part of the Innovate Supercharger Owners Club, lol. Over the past week I've gone through all 150 pages to try and find out any tips or problems, yada yada and get an idea of what I will be doing. Today I got in touch with Mike over at Counter Space Garage and ordered my Stg.2 kit. He's a great guy to deal with. I plan on getting a few more items together before installing the kit and get everything over with all at once. Looking forward to this kit!!
Dustin is offline   Reply With Quote
Old 02-07-2014, 03:36 PM   #3272
xjohnx
Grip>Slip
xjohnx's Avatar
You're about to be a very happy man.
Old 02-07-2014, 03:37 PM   #3273
Powersfrs
Drives: Frs
Thanks for the answers...I'll be running a flex fuel kit meaning let's say I have one gallon left of 91 than i go fill the the tank up with e85 do I have to do anything or those the flex fuel kit do everything like switch the maps?... Would I be able to go wot after I feel up ?
Powersfrs is offline   Reply With Quote
Old 02-07-2014, 03:54 PM   #3274
olorin
olorin's Avatar
Drives: GBS Premium
Nice, what tune planning on running?
olorin is offline   Reply With Quote
Old 02-07-2014, 04:19 PM   #3275
Dustin
Twin Screw You
Dustin's Avatar
Yes sir. Been looking forward to this kit ever since it was first released.
Old 02-07-2014, 04:20 PM   #3276
Dustin
Twin Screw You
Dustin's Avatar
Bill @ Delicious is the front runner. There is someone here locally that I'm considering but given what Bill has accomplished with this kit, I'll probably go with his.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
