Old 02-06-2014, 10:18 PM   #3249
olorin
olorin's Avatar
Drives: GBS Premium
Looks great, I'm going to do mine tomorrow.
olorin is offline   Reply With Quote
Old 02-06-2014, 10:33 PM   #3250
Powersfrs
Drives: Frs
Hey guys I got some question.. I'll be getting my kit soon (intercooled)and I want to run e85(deliciuos tunning flex fuel kit) but just wanna know what u guys opinion on. E85 is? Is it safe? It's my dd n I'm thinking I'll be running e85 all the time should I run pump91once in a while? Do I run a risk catching the engine on fire? (I know Visconti had a problem with his flex fuel kit n idk what was the cause that's y I ask..Does it really rust the internal parts in the fuel lines/engine?...I know deliciuos tuning is one of/or the best at tuning this kit (and many others) so I'm not worried bout his tune just wondering what the cons of e85 are
Thanks for the help
Powersfrs is offline   Reply With Quote
Old 02-06-2014, 10:38 PM   #3251
xjohnx
Grip>Slip
xjohnx's Avatar
i'd run E85 every day if it were available closer to my home.
Old 02-07-2014, 09:26 AM   #3252
swift996
swift996's Avatar
Originally Posted by DriftEm View Post
@xjohnx
Was it too hard to reach the nozzle on the crankcase? Looks like you just inserted the hose into the existing hose?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-07-2014, 09:28 AM   #3253
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by swift996 View Post
@xjohnx
Didn't even try to reach it, the hose that innovate used that connected to the intake pipe was long enough to reach the input on the passenger side Radium.
Old 02-07-2014, 09:33 AM   #3254
xjohnx
Grip>Slip
xjohnx's Avatar
@xjohnx
also, the only suggestion i would make before installing this kit is to apply a little lube to the hose barb fittings before trying to fit the hoses to them. It will make your life much easier.
Old 02-07-2014, 09:38 AM   #3255
swift996
swift996's Avatar
I'm talking about the one that routes from the rear of the engine up to the blower. That seems to be causing the most oil blow by for me.
EDIT - I think the PCV line.
Old 02-07-2014, 09:38 AM   #3256
DriftEm
DriftEm's Avatar
@xjohnx
No, it was easy reaching in, plenty of room to work in.
DriftEm is offline   Reply With Quote
Old 02-07-2014, 09:55 AM   #3257
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Thanks for the help
+1 I run E85 100% of the time due to the fact there are 4 gas stations within 5-10min of where I live. I also feel a lot safer running on the corn
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-07-2014, 10:00 AM   #3258
swift996
swift996's Avatar
@Powersfrs I run e85 about 10-15% of the time just because it's about 20 miles from me. So I get it when I can. I'd run it more if it was closer. I still like to cycle a tank or two of regular 93 pump through just in case. e85 hasn't been around long enough to know of all the effects. It can be linked to corroding lines over time. It's extremely knock resistant (comparable to 105/106 octane). There's not a lot of evidence to it's long-term effects but I suspect with 10% of gas now being ethanol, it's already in the system enough to cause any effects.
Bottom line for me is I'm a little conservative with using it but it's super simple. Just pull up, fill up, switch maps, and you're good to go. It's crazy easy to live with.
Old 02-07-2014, 10:01 AM   #3259
xjohnx
Grip>Slip
xjohnx's Avatar
Oh that one, not hard at all, you pull it hose off the middle fitting, insert the coupler, attach the supplied hose to the other end of the coupler and run it to the can, then you run the can to the the now vacant middle port.
Old 02-07-2014, 10:05 AM   #3260
swift996
swift996's Avatar
Yeah, my bad, my terms are all off. So the radium supplied hose just inserts to the factory hose? I guess my question is can you remove the OEM hose so you don't have hoses disconnecting.
Old 02-07-2014, 10:06 AM   #3261
xjohnx
Grip>Slip
xjohnx's Avatar
you might be able to, i didn't want to try. the connections using the coupler seemed plenty secure.
Old 02-07-2014, 10:09 AM   #3262
evo4g63
evo4g63's Avatar
Pulling up and filling the vehicle up to drive it normally is okay. To get the full ethanol content of E85 it needs a few tanks to be ran through when switching from 91/93 to E85. I wouldn't just fill up with E85 after having pump in the car and than go all out WOT. This has been tested using a ethanol content reader on various vehicles before on many platforms. No bashing towards you I just wanna clear that up for the OP asking questions. I don't wanna see another car blow up on this forum for a while.
-2016 Subaru WRX
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
