Old 06-09-2015, 02:15 AM   #3235
markw
Drives: 2014 FR-S
Originally Posted by ryan t View Post
ive been reading this thread and thinking of trying cs. the set up im thinking of is 225/45 re71r on stock wheels,camber bolts, and trd springs. should i go with trd sways or just the strano front bar? is this starting set up that far off?
Here's my thoughts. Get the full TRD package, it's very well setup. You can run stock shocks with it, or go with some off the shelf Koni's. The car will handle extremely well with those RE71R's and camber bolts + alignment. 1/8 out in front and 1/8 in in the rear. There are a few cars setup like this and doing very well at the national level.
The other thing is, if you need a bigger rear bar, you have to buy the pair as they don't sell them separately. So even if you get the strano bar and decide you need a stiffer rear bar, you're going to have a strano or TRD front bar sitting in your garage.
Mark
markw is offline   Reply With Quote
Old 06-09-2015, 07:01 PM   #3236
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
My video from the Mineral Wells ProSolo
Left:
[ame="https://www.youtube.com/watch?v=ajZJ5mMTJMI"]2015 Mineral Wells ProSolo Left Side - Dave Ogburn C-Street FR-S - YouTube[/ame]
Right:
[ame="https://www.youtube.com/watch?v=l9PMnVN7dYs"]2015 Mineral Wells ProSolo Right Side - Dave Ogburn C-Street FR-S - YouTube[/ame]
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
Old 06-09-2015, 07:02 PM   #3237
YawMomentRacing
Originally Posted by chucky12012 View Post
Congrats to Dave on another Pro Solo win this weekend at Mineral Wells and holding off those RX-8's. Fantastic event with long and fast courses that were difficult to get just right. Below are my fastest left and right course runs from the weekend. Did I mention it was hot...
Good job this past weekend...and thanks!
YouTube Channel
Old 06-10-2015, 10:53 AM   #3238
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Dave, impressive win on a course against the RX8's that looked like it clearly required 3rd gear, and then a second gear down shift. Well done. I think even my tall tires would have put me in third on that course. You can see the RX8 with an edge at the start from your right course video too.
Manfred's good 60' times on the Rival-S tires have me wondering about a different setup myself. I can't tell if the Rival-S are getting more grip off the line, or if they're just getting more grip because they're 245 width monsters.
Thinking of 215/45/16 Rival S's wrapped on the $100 ea 16x7 +48 16lbs Sparco wheels on close out..... I'm kind of glad the tires are backordered though, because I need to stop spending money.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 06-10-2015, 12:03 PM   #3239
qoncept
qoncept's Avatar
The camber issue isn't anything you should or even could protest. OEM replacements are OEM replacements and there's no way a protest against unmodified Konis is going to be upheld. It's just a bummer for those of us that can't get the camber, along with being unable to run the TRD springs (presumably - I've haven't been around much and haven't seen any firm evidence that they're better). In an amateur sport that won't ever make you any money I don't see much point in nitpicking. Just go have fun.
qoncept is offline   Reply With Quote
Old 06-10-2015, 01:10 PM   #3240
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Wilmington Pro Solo, Sunday afternoon runs.
[ame="https://www.youtube.com/watch?v=Lyqd3Zef0lw"]Sean Grogan 2015 Wilmington Spring Pro Solo Sunday C-Street - YouTube[/ame]
Couldn't quite make up all the time to catch Harvey, but on a longer course I think I'd be right there. He was killing me heads up off the line when we were paired Saturday afternoon runs.
Ended up 3rd, just over half a second from the lead, out of ten cars.
Old 06-10-2015, 01:22 PM   #3241
simpleisbest
Senior Citizen
Drives: Scion FR-S
While no one is talking protest here...you should go take a look at the alignment specs others are getting in the "Suspension" section of this forum and see what combination of parts is required to hit over -2.5 degrees of front camber. You will find guys reporting "maxed" camber with lowering springs and Whiteline alignment bolts yet still under -2.0 degrees.
If you cannot achieve anywhere close to that with OEM struts, but you can with the Koni "OEM replacements" then it is obvious that the two parts are not equal and thus would not be legal for use in Street class.
I am beginning to think that either some people are getting inaccurate readings, or the production quality at Koni is subpar. I hope it is the just poor alignment equipment, though.
If someone can achieve an additional -1.0 degree of camber by using the Koni struts, then something is off. No suger coating it.
simpleisbest is offline   Reply With Quote
Old 06-10-2015, 03:23 PM   #3242
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Buy Koni's
Autocross nut
AustinTX is offline   Reply With Quote
Old 06-10-2015, 05:24 PM   #3243
Wahoo5
Drives: '13 FR-S, '06 F430
The Mineral Wells courses look so much better and longer than Wilmington. Vivek comes through again.
Wahoo5 is offline   Reply With Quote
Old 06-10-2015, 08:13 PM   #3244
renfield90
The Stig's German cousin
It's a bit of both the compound and the width IMO. And the pinching - being mushy as hell I'm sure helps at the launch since the sidewalls have a bit of drag radial attitude to them...
I could spin the wheels at Lincoln and still pull 2.2. From a launching perspective these are better than the (fairly wide) 225 Goodyear R comps I ran two years ago.
The two biggest concerns I have with the 245s: insane shoulder wear and they run cooler than 225s by 10-15 degrees F. In cold conditions it will be very hard to work enough heat into them as a single driver in the standard 3-run format.
Old 06-10-2015, 09:06 PM   #3245
bslate3
Drives: 2015 CWP BRZ
Congrats to Dave on the win at the Mineral Wells Pro Solo. Also great job to Chris on 3rd place! Nice driving!
Here's my videos. Not nearly as fast as y'all but I'll catch up eventual!
Right side, I over cooked the last 180 and came out at a turtle's pace.
Left side could have been faster bit wasn't, boo!
Driving tips appreciated. I know I was sawing at the wheel a lot. I gotta be smoother on my inputs.
bslate3 is offline   Reply With Quote
Old 06-11-2015, 12:21 AM   #3246
markw
Drives: 2014 FR-S
It just takes time, keep looking ahead. 1:19 on that first video looks like you weren't looking where you needed to look, it's almost like you knew you screwed it up and looked at that inside cone instead of where the car was going.
Have you done any of the driving schools, outside of that quickie evo school they do before nationals? I did the phase 1 and phase 2 back in March and figured out a few things, which has helped immensely. Went from mid pack to top 3 at my last few events. Haven't gotten a first yet, but last event I was second, and I've paxed in San Diego as high as 9th out of 171. San Diego is a tough region, but we have good drivers that are always willing to give feedback.
Here's my 2nd place run from the last San Diego local event, 11 cars in class, 1 novice, 2nd-6th covered by .8 seconds. 1st place went to the local alien.
[ame="https://www.youtube.com/watch?v=FmiSGF5pRwg"]mark 2nd place run 5 31 15 - YouTube[/ame]
Mark
Old 06-11-2015, 08:12 AM   #3247
bslate3
I haven't done any EVO schools. I have a couple super fast local drivers coach me a lot, that helps a lot.
I want to do an EVO school but there are none anywhere near me.
Thanks for the tips.
Old 06-11-2015, 11:44 AM   #3248
markw
Drives: 2014 FR-S
Yeah, I came over from motorcycles, and taught the motorcycle safety school for 5 years. Looking ahead is probably the biggest skill that you constantly have to work on. Looking ahead makes you proactive and lets you get the car in the right spot, which makes everything go smoother.
The evo schools are good, the one I went to was 8 hours away, so I had school, gas, hotel. I consider it money well spent, as I've been applying and practicing the things they told me to work on, which have improved my local standings.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
