Old 07-11-2012, 04:58 PM   #309
Don@Accelerated
Don@Accelerated's Avatar
Almost Every OE car on earth runs a cat before the turbo.
How about its brother car the Imprezza WRX. Cat in the uppipe. The catalytic converters these days do not degrade for hundreds of thousands of miles. Theres no concern here from my perspective.
Originally Posted by SkullWorks View Post
I would hope the airfilter wont be simply bolted to turbo inlet,
I would never run a turbo after a CAT, too often cat's degrade with turbo EGT's, Pressures, and A/F ratios, the chance to ingest a chunk of ceramic based catalyst is simply too high to make that a feasible option.
I do enjoy the thought of a no header required turbo and had considered placing my turbo there aswell,,, very smart from a business perspective, lets more people get in on the fun, and that's what this is all about right?
Don@Accelerated is offline   Reply With Quote
The Following 2 Users Say Thank You to Don@Accelerated For This Useful Post:
Gen (07-11-2012), wcbjr (07-11-2012)
Old 07-11-2012, 04:59 PM   #310
Don@Accelerated
I don't understand the concern w/ the flooding. Are you thinking it will suck in water. Explode? what?
Exhaust (07-11-2012), wcbjr (07-11-2012)
Old 07-11-2012, 05:20 PM   #311
clevrname
Drives: 2013 Firestorm FR-S 6MT
Sub'd for the awesomeness that is to come....
2013 Firestorm 6MT
2005 Corolla XRS
clevrname is offline   Reply With Quote
The Following User Says Thank You to clevrname For This Useful Post:
Old 07-11-2012, 05:44 PM   #312
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
+1. Subscribed after checking back every other day for the past week.
Patiently awaiting any video or even just audio
MannyO is offline   Reply With Quote
The Following User Says Thank You to MannyO For This Useful Post:
Old 07-11-2012, 06:53 PM   #313
slow_frs
Drives: turbo scion tc
This kit is obviously a simple bolt on , of your concerned about the cat then simply go upgrade to a nameless or Agency cat less header, this kit is obviously we thought out as far as being able to be end user friendly and upgradable
slow_frs is offline   Reply With Quote
The Following User Says Thank You to slow_frs For This Useful Post:
ImAwesome (07-11-2012)
Old 07-11-2012, 07:53 PM   #314
Boxer-Guy
Boxer-Guy's Avatar
Drives: Not Yet
What if by accident if I hit a pot hole at night that I couldn't see
or if I wanted to make the car alittle lower
would that damage the turbo ?
Boxer-Guy is offline   Reply With Quote
Old 07-11-2012, 07:54 PM   #315
ImAwesome
Drives: 99' M3, 13' SWP Brz
Originally Posted by Boxer-Guy View Post
what if by accident if I hit a pot hole at night that I couldn't see
He already said it sits higher then the subframe
ImAwesome is offline   Reply With Quote
The Following User Says Thank You to ImAwesome For This Useful Post:
armythug (07-14-2012)
Old 07-11-2012, 07:59 PM   #316
Gen
Drives: Scion FR-S
Originally Posted by ImAwesome View Post
If you don't want the compromise just buy a cat less header.
I think the way you are developing this is ingenious
It's AWESOME. I'm just hoping the price is relatively reasonable...granted, I understand it's never cheap.
Gen is offline   Reply With Quote
Old 07-11-2012, 08:22 PM   #317
Don@Accelerated
No. The car will bottom out on the front subframe first before the turbo will be affected. You will have to do something real crazy to get to it.
Don
Old 07-11-2012, 08:23 PM   #318
Don@Accelerated
My car is also 2.5" lower than stock. I've maxed the Tein Flex's as low as they will go. I've looked at it on the ground and I still don't suspect an issue.
Old 07-11-2012, 08:30 PM   #319
Don@Accelerated
Filter location is not permanent, but this is approximately where it is going. Still working on the details with the maf location, so I haven't made any brackets yet. Most likely will stay right here and have brackets fixing to the intake manifold rear.
I've switched to 3" intake piping and it makes the fitment alot trickier. I wanted to beat me head against the wall when I was making it. The car made me bleed a few times as well
The Following 9 Users Say Thank You to Don@Accelerated For This Useful Post:
Chewie4299 (07-13-2012), civicdrivr (07-12-2012), cobrabyte (07-11-2012), Guff (07-12-2012), koyv90 (07-12-2012), slaxx (07-11-2012), Spaceywilly (07-11-2012), SVTSHC (07-18-2012), Symbiont (07-11-2012)
Old 07-11-2012, 08:34 PM   #320
slow_frs
The maf the same used on most new Toyota and Lexus models it is capable of withstanding a blow-tru maf setup I say place it in the charge pipe some where before the 90 to the throttle body
Old 07-11-2012, 08:35 PM   #321
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Anxiously Awaiting Vids
I have been following this thread since it began and get more excited every day. Also been following the HKS Supercharger and it does not look promising. I plan on buying this eventually, just wanna see dyno and other people test it first haha.
Unleashed is offline   Reply With Quote
Old 07-11-2012, 08:48 PM   #322
Boxer-Guy
Boxer-Guy's Avatar
Drives: Not Yet
Thanks Don & ImAwesome for the post
It just that Im use to seeing turbos in the engine bay instead under the car.
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
