Old 04-14-2016, 08:01 PM   #309
steve99
Originally Posted by FRSBRZGT86FAN View Post
OK I fixed it, so I removed/uninstalled romraider then ONLY added the definitions for the new OFH tunes and did not add the ones for the normal ots stage 2 tunes and its fine now and perfectly editable.
Ok
This is a trap in due to way oft tunes work.
if you have more than one definition in romraider , romraider will use the first definition starting from the top that matches the calid of the rom you open.
as oft guys alter calids to make say A01C roms look like B01C roms and also alter their defs , you need to exceeding carefull if editing multiple roms and using multiple oft defs.
You have just found this out.
its because older oft tunes may have been based on say A01C rom but now they updated to B01C rom internally but both defs will be labeled A01C in oft defs
if you want to have two roms open with same calid but different defs required due internal changes by oft guys then you need to switch the order of the defs in romraider so romraider uses the correct cdef to open each rom. This practice is dangereous and you need to be very aware and carefull with what your doing.
If tables in either rom ie the one you are copying from or the one your pasting to look weird STOP. always check both the source and target tables before you transfer data or its bricked ecu.
Old 04-14-2016, 08:16 PM   #310
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Ok
Thanks I was adding the quiet cold start edit and realized the numbers stock were extremely wonky and was like did I do something wrong?
So now I know in this case only use one cal id per rom specific to that rom.
Also I noticed the new definitions are missing Maf Correction After Start(in Gear) and Maf correction after start(in neutral). Would it be safe to edit the xml to add those in?
Old 04-14-2016, 08:40 PM   #311
Vmax911
Drives: WRB BRZ
Do people just not read? It's been stressed in over 12 pages that its specifically for 91 and 93 and only OFH
Oh sorry forum grand master, I read the thread title, "New Stage 2 UEL (91-93 and E85) OTS tune files" and by reading that I thought there may be something new to the E85 tune.
My bad.
Vmax911 is offline   Reply With Quote
Old 04-14-2016, 08:45 PM   #312
FRSBRZGT86FAN
My bad.
Thats not reading. That is reading the title then not reading the actual post or shivs comments, then asking a question that could've been answered yourself if you read the entire post and one of shivs comments. Doing that especially in the software tuning section is a nice way to destroy an engine.
Old 04-14-2016, 10:04 PM   #313
steve99
yes all tables are in roms the defs just point romraider to the correct location
or use wayno,s defs
Old 04-14-2016, 11:06 PM   #314
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
did anybody tried it with crawford BPB? should we make the same modification as in other tunes?
i'm willing to try it out, but if somebody already know the answer I would appreciate it!
Walla Walla is offline   Reply With Quote
Old 04-14-2016, 11:19 PM   #315
Ixz
Drives: 2014 WRB Subaru BRZ
So here is some updated data logs from night cruising around. The only thing that bothers me is mixed driving datalog that show a bit of knock. Could you please look at it? Thanks
There is 3 data logs in link below.
http://www.datazap.me/u/ixz/new-oft-...og=0&data=1-12
Ixz is offline   Reply With Quote
Old 04-15-2016, 12:15 AM   #316
phrosty
Very small and inconsistent, wouldn't worry about it.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 04-15-2016, 02:41 AM   #317
Kodename47
Kodename47's Avatar
Drives: UK GT86
or use wayno,s defs
....or mine that I posted a page or 2 back
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-15-2016, 04:29 AM   #318
FRSBRZGT86FAN
I'm with phrosty here that's perfectly fine, it seems almost like a random fluke. Also nothing else that helps point to knock being detected didn't change one bit. Do it again and see if it appears again, I think it's a non issue.
Old 04-15-2016, 09:34 AM   #319
Ixz
Thank you guys for help and thanks Shiv for the new update, the car feels more lively now and sound a bit beefy.
Old 04-15-2016, 01:01 PM   #320
Tbor
Drives: Firestorm FR-S
Just drove 300+ plus miles(philly to Pittsburgh and on one tank!) with no issues at all. I'm loving the new tune.
Tbor is offline   Reply With Quote
Old 04-15-2016, 01:10 PM   #321
FRSBRZGT86FAN
Do you have OFH?
Old 04-15-2016, 01:28 PM   #322
Tbor
Do you have OFH?
I do. First gen.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
