Old 08-31-2010, 08:24 PM   #309
BoostJunkie
RaggedEdge Autosports
BoostJunkie's Avatar
Drives: 97 APU Supra
I'm thinking this will allow for more aggressive (lean) AFR's safely, right?
You should go single with a quick spool valve, they are seeing kick ass numbers with it, here's a thread on it's performance
http://www.supraforums.com/forum/sho...d.php?t=597012
Red JZA80 APU Supra 800whp
White 07 Turbo Si 411whp *RIP*
BoostJunkie is offline   Reply With Quote
Old 08-31-2010, 08:35 PM   #310
Dimman
Kuruma Otaku
Dimman's Avatar
Buddy's got one on a 7M pushing a GT35R with a custom billet compressor wheel. (Tekdeus on SF) It spools fast and pulls hard but I'm still partial to the words 'Twin Turbo'... I was thinking twin GT2560R's. I heard they can put down 10psi by 2800 on a stock 1JZGTE and 20-something psi by 3500ish.
Because titanium.
Old 08-31-2010, 09:52 PM   #311
BoostJunkie
Yeah but I'm not to familiar with the 1jz's block, how strong is it?
Old 08-31-2010, 10:18 PM   #312
Dimman
Kuruma Otaku
Dimman's Avatar
Think same as a 2JZ with shorter rods so it revs better, but doesn't spool big turbos as well or put down low torque. Weak point stock is the rod bolts, same as the 2JZ. 500 whp without worrying about anything. Couple local guys are running 600 whp without problems (keeping in mind that a 1JZ will be either running more rpm or more boost for the same power as a 2JZ putting the same power down).
Because titanium.
Old 09-01-2010, 07:33 AM   #313
BoostJunkie
Oh I see, is the exterior of the 1jz bottom end bigger, probably so, but if not just upgrade to a 2jz bottom end, then I'd have no worries, lol but seriously do u have a build thread?
Old 09-01-2010, 08:19 AM   #314
Matador
hashiryu
Drives: Mk4 Supra
Think of the 1JZ as a smaller displacement 2JZ with parallel/single turbos and a slightly worse flowing head.
Matador is offline   Reply With Quote
Old 09-01-2010, 08:27 AM   #315
BoostJunkie
Ok, so relatively same size exterior? Or smaller?
Old 09-01-2010, 04:08 PM   #316
stevens8
stevens8's Avatar
Drives: '12 WRX
Originally Posted by Dixie Normous View Post
Only problem I see with a NA 200ish hp is it will be like the f20/22c in the s2000. What I mean is it will be difficult to get extra power out of them (with out going forced induction) because the motor is already almost as good as it can get NA. You know what i mean?
No mention of k20 huh? The k20 comes stock at 200hp 2.0L and picks up crazy gains from just bolt on mods.
stevens8 is offline   Reply With Quote
Old 09-01-2010, 06:36 PM   #317
Abflug
Abflug's Avatar
Drives: MR2
why doesn´t Toyota put a Porsche engine in it?! hell of fun wouldn´t it?! j/k
Abflug is offline   Reply With Quote
Old 09-01-2010, 06:37 PM   #318
Abflug
Abflug's Avatar
Drives: MR2
argh.. enough of that humor...
Old 09-01-2010, 07:50 PM   #319
Dimman
Kuruma Otaku
Dimman's Avatar
Pretty much the same. I can pull the 1JZ out of my car and drop in a 2JZ, everything bolts up, transmission, mounts, etc... heads interchange, most of the stuff I may need to get replaced I can get from SC300 components.
For some reason there is a circle of thought out there that the 1JZ outflows the 2JZ, however every flowbench test shows that the 2JZ is about 10% better. There is a difference between the ports of the early twin turbo 1JZ and the later single turbo VVT-i 1JZ, and the myth may come from the newer 1JZs.
However I'm hoping the later VVT-i 2JZGE heads out-flow the early twin-turbo 2JZGTE heads. But it may not matter if I do (or get done) a porting job.
As for why not 2JZ bottom end? The 1JZ is pretty much just as strong, but there is more stress on it to make the same power because it is smaller. I'm only looking for a high 400 to low 500 to the wheels with a HIGH redline. The shorter stroke allows this with less stress on the rods and their bolts. And there is nothing like the sound of a high-revving 1JZ.
Because titanium.
Old 09-01-2010, 08:04 PM   #320
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
400hp or so 1JZ are awesome. Here are some swapped 1JZ vids
[u2b]g60OaQnlzuY[/u2b]
[u2b]Bs6qD7Gt3qw[/u2b]
Old 09-02-2010, 06:59 AM   #321
Matador
hashiryu
Drives: Mk4 Supra
Old 09-02-2010, 08:01 AM   #322
BoostJunkie
I'd def go with the porting on a 2jz-gte head, either way, I know I love my I-vetc on the civic and with tuning you could change the rpm in which it kicked in, and once I turbo'd it and the I-vtec was fixed it was like an extra 30-40 whp after 5400 it was pretty cool
FT-86 Concept to be unveiled at Toyota Metapolis on 10/23 ahead of Tokyo Motor Show! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 8 12-15-2011 11:19 PM
Live pics and videos of Toyota FT-86 from Tokyo Motor Show (compilation)! Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 67 10-31-2011 08:09 PM
