#309 | |
RaggedEdge Autosports
Drives: 97 APU Supra
http://www.supraforums.com/forum/sho...d.php?t=597012
Red JZA80 APU Supra 800whp
White 07 Turbo Si 411whp *RIP* ![]() |
#310 | |
Kuruma Otaku
Because titanium. |
#311 | |
#312 |
Kuruma Otaku
Think same as a 2JZ with shorter rods so it revs better, but doesn't spool big turbos as well or put down low torque. Weak point stock is the rod bolts, same as the 2JZ. 500 whp without worrying about anything. Couple local guys are running 600 whp without problems (keeping in mind that a 1JZ will be either running more rpm or more boost for the same power as a 2JZ putting the same power down).
Because titanium. |
#313 | |
#314 | |
hashiryu
Drives: Mk4 Supra
Think of the 1JZ as a smaller displacement 2JZ with parallel/single turbos and a slightly worse flowing head. |
#315 |
Ok, so relatively same size exterior? Or smaller?
#316 | |
Drives: '12 WRX
#317 |
Drives: MR2
why doesn´t Toyota put a Porsche engine in it?! hell of fun wouldn´t it?!
j/k
#318 |
Drives: MR2
argh.. enough of that humor...
#319 |
Kuruma Otaku
Pretty much the same. I can pull the 1JZ out of my car and drop in a 2JZ, everything bolts up, transmission, mounts, etc... heads interchange, most of the stuff I may need to get replaced I can get from SC300 components.
For some reason there is a circle of thought out there that the 1JZ outflows the 2JZ, however every flowbench test shows that the 2JZ is about 10% better. There is a difference between the ports of the early twin turbo 1JZ and the later single turbo VVT-i 1JZ, and the myth may come from the newer 1JZs. However I'm hoping the later VVT-i 2JZGE heads out-flow the early twin-turbo 2JZGTE heads. But it may not matter if I do (or get done) a porting job. As for why not 2JZ bottom end? The 1JZ is pretty much just as strong, but there is more stress on it to make the same power because it is smaller. I'm only looking for a high 400 to low 500 to the wheels with a HIGH redline. The shorter stroke allows this with less stress on the rods and their bolts. And there is nothing like the sound of a high-revving 1JZ.
Because titanium. |
#320 |
Site Moderator
Drives: ichi 86 Project
400hp or so 1JZ are awesome. Here are some swapped 1JZ vids
[u2b]g60OaQnlzuY[/u2b] [u2b]Bs6qD7Gt3qw[/u2b] |
#321 | |
hashiryu
Drives: Mk4 Supra
#322 | |
| FT-86 Concept to be unveiled at Toyota Metapolis on 10/23 ahead of Tokyo Motor Show! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-15-2011 11:19 PM |
| Live pics and videos of Toyota FT-86 from Tokyo Motor Show (compilation)! | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 67 | 10-31-2011 08:09 PM |
