Old 01-12-2014, 09:22 PM   #309
diss7
Drives: AE86, 2x GT86, TE27
Originally Posted by Skidrcn View Post
What tune would you recommend for someone who is not going to be SC/Boosted anytime soon? I just have a front pipe back Exhaust. Sorry for the noob question. I came from the Subaru word and never really messed with tuning on NA cars.
All I have is a front pipe with no cat, and a track pipe. Also a panel filter.
I used FA20Club for my tune. Easy to deal with. Car has more pep, but more importantly more revs, and I'm rid of the stock rev limit death feature.
diss7 is offline   Reply With Quote
Old 01-13-2014, 10:53 AM   #310
allmotorrex
allmotorrex's Avatar
Drives: 08 4x4 offroad tacoma/ raven fr-s
Originally Posted by executivekoala View Post
Stopped by Parts shop Max today, Solid diff Risers and Weld in solid diff mounts are in stock now! No word on when subframe risers at the moment
You talk to them about the steering kit at all?
allmotorrex is offline   Reply With Quote
Old 01-13-2014, 01:25 PM   #311
executivekoala
executivekoala's Avatar
Drives: fr-s
Thats down the line-like awhile. They are really busy with new shop and its just taking a bit to get stuff out.
executivekoala is offline   Reply With Quote
Old 01-13-2014, 02:27 PM   #312
chris x sway
chris x sway's Avatar
Drives: 2014 FR-S in Mayonnaise
My car feels sluggish recently. I just got my first oil change at jiffylube about 1000 miles ago, only because the dealership doesn't give you your first oil change until 5000mi. I'm wondering if it's because of the cheap tires I put on the back to drift. Anyway, car's stock, needs a lot of work done.
chris x sway is offline   Reply With Quote
Old 01-13-2014, 08:54 PM   #313
diss7
It doesnt need a lot of work. It drifts fine stock.
If you can, get a flash tune to get rid of the stock rev limit issue. And get some better tyres for the front. Run the front tyres at about 26-28psi cold (aiming for 30psi warm) and put heaps in the rears. Ive put upto 55psi cold in the rears. It is super loose. Will be more than enough oversteer than you need.
As you get better, you'll want to put less air in the rear tyres, for more grip. 45psi for example gives noticeably more grip.
Old 01-16-2014, 02:54 AM   #314
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
@diss7 thanks for the tire info I'll try this, I have the st 17mm rear sway bar and stock front sway. What should my rear be set too on the adjusters to get sideways easyer? Thanks
Teknian_Culprate13 is offline   Reply With Quote
Old 01-16-2014, 04:03 AM   #315
diss7
With 55 psi in the back, it'll be plenty even without the bar in at all. I'm in between rear swaybars (am waiting on new one) so last drift day I have a upgraded front and stock rear, and it still had plenty of oversteer.
Just put it on the middle setting and get some seat time.
Running the pressures I've suggested will be a good starting point. Most people forget (or simply don't know) how much tyre pressures affect handling.
Old 01-16-2014, 04:06 AM   #316
Teknian_Culprate13
Drives: Scion FR-S
@diss7 I've had plenty if time street and track on middle setting it feels good but not sure what way to adjust it for more oversteer. Keep forgetting about tire pressure going to give that a try
Old 01-16-2014, 04:22 AM   #317
diss7
Assuming its a multi point blade type sway bar, towards the tips is softer, towards the main bar is stiffer. So you want to move it further in.
Old 01-16-2014, 03:20 PM   #318
chris x sway
Thanks man. I appreciate it!
Old 01-17-2014, 09:32 AM   #319
canu_50
canu_50's Avatar
Drives: Scion fr-s
Just to give you an idea, i run 32 psi cold on 225 tires. and running stock engine!
canu_50 is offline   Reply With Quote
Old 01-17-2014, 10:55 AM   #320
chris x sway
Word. I had 215/40s with 400 treadwear. It slid out real nice.
Old 01-21-2014, 03:00 PM   #321
executivekoala
Drives: fr-s
subframe risers are in!!!!!
Old 01-21-2014, 03:02 PM   #322
gk
Drives: 2013 Raven FR-S
Speaking of pbm does anyone use their lcas and what are your opinions of them?
gk is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
