Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 01-09-2014, 12:03 AM   #309
pansontw
Drives: Subaru Legacy
Bump...
Both USDM spec and JDM spec are in stock for direct plug and play no matter you are local or in UK
Sincerely,
Panson
pansontw is offline   Reply With Quote
Old 01-09-2014, 02:42 PM   #310
pansontw
Bump...
We offer the best price on forum for Valenti items!
Sincerely,
Panson
Old 01-10-2014, 03:20 AM   #311
pansontw
BumP~~~
Panson
Old 01-10-2014, 11:09 AM   #312
pansontw
To the top
Sincerely
Panson
Old 01-11-2014, 02:44 AM   #313
pansontw
All pm replied
Sincerely,
Panson
Old 01-12-2014, 11:37 AM   #314
fx35s
Drives: 2013 Subaru BRZ
Questions.
1) What's the difference between USDM and JDM specs for reverse/fog light unit?
2) I've seen from youtube that Valenti reverse/fog light can blink 3 times when I put on a brake. Is there a setting to make that happen (like relays/resistors or what not)?
Thanks in advance!
fx35s is offline   Reply With Quote
Old 01-13-2014, 12:07 AM   #315
pansontw
Sir,
Here are the Answers
1) Fog unit only comes w/ JDM spec. Since we don't have rear fog function, we'll need to wire the rear fog to parking light.
2) There is a separate wire coming out of reverse lamp. If you like the blink-3-times thing, just attach the wire to your brake wire at the back to tail lamps (Red color).
This way, whenever you step on brake, it will activate the blinking effect.
Sincerely,
Panson
Originally Posted by fx35s View Post
Questions.
Thanks in advance!
The Following User Says Thank You to pansontw For This Useful Post:
fx35s (01-13-2014)
Old 01-13-2014, 12:10 AM   #316
Birquah
KCCO
Birquah's Avatar
Drives: 2015 Galaxy Blue Pearl WRX
Valenti LED Tail Lamps /Reverse Lamp~Lowest Price and full 1year warranty
Panson,
I have yet to install my fog but is there a way to wire it to have the red not on steadily? As in, can it be set up to be off normally and then flash 3x and stay on when the brake is applied and then turn back off when the brake is released?
Also, is that video I posted correct installation procedure?
Birquah
strat61caster's official recommended plan for FR-S ownership and mawds:
Step 1) Drive it.
Step 2) Replace the things that wear out.
Step 3) When not performing Step 2 perform Step 1 as much as possible.
Birquah is offline   Reply With Quote
The Following User Says Thank You to Birquah For This Useful Post:
fx35s (01-13-2014)
Old 01-13-2014, 12:35 AM   #317
t.chk
Drives: Subaru BRZ Limited
Originally Posted by Birquah View Post
Panson,
Birquah
If panson has better walk through he can post them, but the link below is pretty on target. It shows you the 5 different types on configuration and how to wire it up.
I did not review your video on how to install them, no youtube at work
http: //www. 86forums.com .au /index.php?/topic/1892-diy-modifying-the-valenti-to-for-parking-v-and-brake-flasher-f1-race-style/
It kept killing my link to another forum...so get rid of the spaces and it will take you there
cheers
t.chk is offline   Reply With Quote
Old 01-13-2014, 12:48 AM   #318
pansontw
Sir,
Do you mean the triangle area? This is doable. However, it requires custom wiring. Lamp needs to be open (I mean disassemble), and wires need to be spliced from the core.
Just sent you a pm for all the detail!
Sincerely,
Panson
Panson,
Birquah
Old 01-13-2014, 12:14 PM   #319
pansontw
Bump~~
Sincerely,
Panson
Old 01-13-2014, 01:23 PM   #320
fx35s
Panson,
Birquah
Actually think is exactly how I want mine to be done.
Will this cause any electrical problems?
I would like to know the procedure as well!
Thanks guys
Might be buying this valenti reverse light in few weeks
Old 01-13-2014, 02:05 PM   #321
mrshwll
Drives: 2014 Subaru BRZ Limited - White
Hey Panson, that link isn't working. Is there another link or can you update it please sir? Thanks!
Originally Posted by pansontw View Post
Here is the DIY quoted from an Australian 86forum.
DIY here: http://*****************************...f1-race-style/
Sincerely
Panson
mrshwll is offline   Reply With Quote
Old 01-13-2014, 03:06 PM   #322
Birquah
KCCO
Birquah's Avatar
www. 86forums.com .au/index.php?/topic/1892-diy-modifying-the-valenti-to-for-parking-v-and-brake-flasher-f1-race-style/
Remove the spaces before and after the www and au.
Step 1) Drive it.
Valenti Japan Full LED Tail Lights pornflakes AUSTRALIA 4 11-07-2015 09:56 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 01:14 PM
Valenti Tails & Reverse Lamp JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 16 04-27-2013 11:06 AM
Gauging Interest Valenti Japan Full LED Tail Lights pansontw Cosmetic Modification (Interior/Exterior/Lighting) 95 03-10-2013 05:29 AM
