01-03-2021, 11:29 AM | #309 | |
Drives: 2016 Toyota 86
I hope we see some feedback on the BPB sooner than later. I am waiting on JDL to build my 4-2-1 now so I should be getting tuned in the next month or 2. If 949 gets the BPB to show real gains I will install a set along with the headers. |
The Following User Says Thank You to Mike_ZN6 For This Useful Post: | jflogerzi (01-03-2021) |
01-03-2021, 12:03 PM | #310 | |
2013 Series 10 FRS #553
01-03-2021, 12:25 PM | #311 |
Drives: 2013 FR-S Argento
Bpbs make a difference, I had them. I didn't run e85 but I don't see why they shouldn't affect the torque curve in the same way. I think perhaps the difference is in the tuning options. In any scenario bpbs will basically compress the torque curve, shifting everything down and narrowing the torque dip if you have one. Effectively fattens up your upper midrange by a noticeable amount, at the expense of some top-end. Shiv demonstrated however that some of the top end loss can be mitigated with increasing timing advance on pump gas - you can push it a bit more at the top end with the blocks since they reduce VE in that upper range. With e85, I don't think there is any room to recover since you are never knock limited on e85 with a NA setup. But you should still see the advantages in the midrange with bpbs and e85. Will be interesting to see what the dynos say.
Sent from my SM-G965U using Tapatalk |
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post: | jflogerzi (01-03-2021), Stonehorsw (02-11-2021) |
01-03-2021, 12:54 PM | #312 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
We can guess that there's gonna be a power loss up top, but the question is just how much? Hopefully with E85, and William Knose's platform knowledge we'll see some solid area under the curve gains without much top end loss.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
The Following User Says Thank You to Goingnowherefast For This Useful Post: | jflogerzi (01-03-2021) |
01-03-2021, 01:47 PM | #313 | |
Drives: JRSC BRZ SOLD
x3. Maybe 949 Racing will get curious about the RacerX IM next and we'll finally see a custom tune for it. I know Delicious Tuning wouldn't mind taking a stab at it. I can dream... |
01-03-2021, 05:34 PM | #314 | |
This sounds promising because I will be tuning for 93 octane pump gas. |
01-03-2021, 06:39 PM | #315 | |
01-06-2021, 04:43 PM | #316 |
Can you confirm that pipes diameter in mm are 45-50-63.5? Thanks!
01-06-2021, 05:31 PM | #317 |
01-06-2021, 06:41 PM | #318 | |
Drives: FR-S Whiteout
The nameless header seems to already have that effect without manifold spacer. A bit more torque in the middle but seems to taper off more past 7K rpm. You might be familiar with it.
Intent > Content
cowardice is the mother of cruelty. |
01-07-2021, 06:03 PM | #319 |
Drives: Crapcan
My tune isn't optimized for the nameless header It is coming off my car soon anyway.
01-08-2021, 04:49 AM | #320 |
Drives: 2014 GT86
IIRC nameless headers in fashion like for ace ones benefited from more specific optimisations in tune a lot, and was not that good with generic OTS EL or UEL tunes. I'd search for long tube headers tune info around.
01-08-2021, 05:23 AM | #321 |
Get it optimized then? What’s the issue? If I’m not mistaken cosworth uses this header.
Intent > Content
01-08-2021, 06:34 AM | #322 |
Drives: 2017 Toyota 86 (860 SE)
What MY are they using? I've been trying to find out if the BPB are useful with the 2017+ IM, but not finding any data. Crawford stopped answering my emails.
Similar Threads | ||||
JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
