Old 01-03-2021, 12:25 PM   #309
bfrank1972
Drives: 2013 FR-S Argento
Bpbs make a difference, I had them. I didn't run e85 but I don't see why they shouldn't affect the torque curve in the same way. I think perhaps the difference is in the tuning options. In any scenario bpbs will basically compress the torque curve, shifting everything down and narrowing the torque dip if you have one. Effectively fattens up your upper midrange by a noticeable amount, at the expense of some top-end. Shiv demonstrated however that some of the top end loss can be mitigated with increasing timing advance on pump gas - you can push it a bit more at the top end with the blocks since they reduce VE in that upper range. With e85, I don't think there is any room to recover since you are never knock limited on e85 with a NA setup. But you should still see the advantages in the midrange with bpbs and e85. Will be interesting to see what the dynos say.
Sent from my SM-G965U using Tapatalk
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
jflogerzi (01-03-2021), Stonehorsw (02-11-2021)
Old 01-03-2021, 12:54 PM   #310
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Originally Posted by Mike_ZN6 View Post
I hope we see some feedback on the BPB sooner than later. I am waiting on JDL to build my 4-2-1 now so I should be getting tuned in the next month or 2. If 949 gets the BPB to show real gains I will install a set along with the headers.
x2. Basically waiting for 949 to pave the way and then I'll make the switch the JDL 4-2-1 and maybe the power blocks if things play out well.
We can guess that there's gonna be a power loss up top, but the question is just how much? Hopefully with E85, and William Knose's platform knowledge we'll see some solid area under the curve gains without much top end loss.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
Old 01-03-2021, 01:47 PM   #311
PulsarBeeerz
Drives: JRSC BRZ SOLD
x3. Maybe 949 Racing will get curious about the RacerX IM next and we'll finally see a custom tune for it. I know Delicious Tuning wouldn't mind taking a stab at it. I can dream...
PulsarBeeerz is offline   Reply With Quote
Old 01-03-2021, 05:34 PM   #312
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
This sounds promising because I will be tuning for 93 octane pump gas.
Mike_ZN6 is offline   Reply With Quote
Old 01-03-2021, 06:39 PM   #313
bfrank1972
By themselves it isn't earth shattering(as if any NA mod on these cars is ), but think of them as an additive way to tune your midrange after adding a set of high flow headers. As with any modification to intake or exhaust flow characteristics, tuning needs to be done, ignition, fuel, cam timing. As a package, I think it could be pretty cool, especially if a really good tuner puts the hours in that they did for the Ace headers. The tune for those is really superbly vetted.
Old 01-06-2021, 04:43 PM   #314
gpvecchi
gpvecchi's Avatar
Can you confirm that pipes diameter in mm are 45-50-63.5? Thanks!
Old 01-06-2021, 05:31 PM   #315
PulsarBeeerz
Have you tried their website?
Old 01-06-2021, 06:41 PM   #316
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
It should have. The BPB's shift the curve down regardless of fuel. That is why 949 is testing them, trying to get more at lower RPM and willing to sacrifice some on top.
The nameless header seems to already have that effect without manifold spacer. A bit more torque in the middle but seems to taper off more past 7K rpm.
You might be familiar with it.
Intent > Content
Old 01-07-2021, 06:03 PM   #317
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My tune isn't optimized for the nameless header It is coming off my car soon anyway.
Old 01-08-2021, 04:49 AM   #318
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC nameless headers in fashion like for ace ones benefited from more specific optimisations in tune a lot, and was not that good with generic OTS EL or UEL tunes. I'd search for long tube headers tune info around.
Old 01-08-2021, 05:23 AM   #319
solidONE
solidONE's Avatar
Get it optimized then? What’s the issue? If I’m not mistaken cosworth uses this header.
Intent > Content
Old 01-08-2021, 06:34 AM   #320
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
What MY are they using? I've been trying to find out if the BPB are useful with the 2017+ IM, but not finding any data. Crawford stopped answering my emails.
Cephas is offline   Reply With Quote
Old 01-08-2021, 08:56 AM   #321
Mike_ZN6
Mike_ZN6's Avatar
949 is using a 2013 FR-S for their project car. Here is their build thread: https://www.ft86club.com/forums/showthread.php?t=131052
I would think if the BPB can work for the black manifold, they would work the same for the red manifold. The manifolds perform essentially the same at NA horsepower levels. The black manifold actually has a larger plenum. I don't think there is even much data to show the red manifold can make more power with FI.
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Cephas (01-08-2021)
Old 01-08-2021, 10:57 AM   #322
Cephas
Cephas's Avatar
I would think so as well, was just hoping somebody else already spent the money to find out.
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
