Old 04-08-2018, 11:23 AM   #3179
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by justinco View Post
My Shorai has been going strong for nearly 3 years. It's been discharged, jump started, brought back from the dead with the charger, etc. I use the LFX24L3-BS12:
LFX24L3-BS12: http://amzn.to/2t8KVQp
Hard part nowadays is finding a battery mount for it.
Good reminder about the tender. I keep mine plugged in at home, this will be year 4 on the battery. I've never needed a jump, and have never had issues on road trips where we don't drive for a few days.
Its a bummer KC Machine isn't around any more, their tray is really nice.
Old 04-08-2018, 11:41 AM   #3180
justinco
justinco's Avatar
Drives: 2022 GR86
Yea, it holds a charge good. I have left the OBDII Bluetooth adapter in the car after racing, and that seems to discharge the battery.
justinco is offline   Reply With Quote
Old 04-08-2018, 11:53 AM   #3181
cjd
cjd's Avatar
Drives: 2017 BRZ
It does. I've gone below what the tender likes with dash cams in in parking mode, but never so low I needed a jump. The r/c thing has me wondering if I should be replacing mine since it was in my old car when it was crashed... Though I guess I've crashed my r/c batteries a few times too...
Old 04-08-2018, 11:57 AM   #3182
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What do you guys think about this mount for the Shorai?
http://www.ft86speedfactory.com/ft-8...l#.Wso7uH8h3Tc
smg1138 is offline   Reply With Quote
Old 04-08-2018, 12:30 PM   #3183
cjd
cjd's Avatar
Drives: 2017 BRZ
If it fits the shorai it's probably fine. Note you need the hold down to go the long way or you won't be able to plug in the tender.
Old 04-08-2018, 04:16 PM   #3184
smg1138
smg1138's Avatar
Is a battery tender necessary on a daily driver? I start my car just about every single day.
Old 04-08-2018, 06:37 PM   #3185
cjd
cjd's Avatar
Drives: 2017 BRZ
For the Shorai? Personally, I'd run it just because it does a cell balance, but I imagine you can get away without a tender. You probably won't get quite the same life-span out of the battery. Shorai has all sorts of notes that are probably worth reading through just to get a sense of what they recommend...
Old 04-08-2018, 06:37 PM   #3186
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
I don't use a tender with mine since I daily it, but if you are gone for 4+ days it can go flat (you could just disconnect the battery since it won't self-discharge, but a small parasitic drain from OBDII or other stuff will deplete it after 4-6 days without driving).
14stu is offline   Reply With Quote
Old 04-08-2018, 08:51 PM   #3187
bslate3
Drives: 2015 CWP BRZ
As for the 245 vs 255 debate, I prefer the 255 RE71 over the 245 RE71. The overall grip seems to be a bit better and can handle heat better than the 245. Also the 245 had much quicker shoulder wear.
With that said, I’d like to try a 245 Rival S 1.5 to see how it works out with the heat and shoulder wear.
bslate3 is offline   Reply With Quote
Old 04-09-2018, 09:54 AM   #3188
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Originally Posted by CoolHandMoss View Post
Thanks for the responses on the 245/255 question. I think I'll probably go with 245's this year.
The right choice
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 04-09-2018, 10:45 AM   #3189
smg1138
smg1138's Avatar
For you guys using the Shorai battery, where did you get the brass terminals for connecting the cables? Doesn't look like the battery comes with them.
Old 04-09-2018, 11:28 AM   #3190
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
I used these.
Odyssey SAE Terminals https://www.amazon.com/dp/B004QCBM28?ref=yo_pop_ma_swf
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 04-10-2018, 09:55 AM   #3191
smg1138
smg1138's Avatar
I went ahead and ordered a Shorai LFX36L3-BS12 battery. Will keep my 35 lb Wal-Mart battery in storage until next winter. Really looking forward to removing about 30 lbs from the front end!
Old 04-10-2018, 12:50 PM   #3192
justint5387
Drives: 4 wheels
Hi Justin.
How many days did you leave the adapter? I left mine in the car before and the car started 2 weeks later. Do you have the OBDLink?
justint5387 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
