#3179 | |
Drives: 2017 BRZ
Its a bummer KC Machine isn't around any more, their tray is really nice.
#3180 | |
btr.life
Drives: 2022 GR86
#3181 |
Drives: 2017 BRZ
It does. I've gone below what the tender likes with dash cams in in parking mode, but never so low I needed a jump. The r/c thing has me wondering if I should be replacing mine since it was in my old car when it was crashed... Though I guess I've crashed my r/c batteries a few times too...
#3182 |
Drives: 2013 Raven FR-S
What do you guys think about this mount for the Shorai?
http://www.ft86speedfactory.com/ft-8...l#.Wso7uH8h3Tc |
#3183 | |
Drives: 2017 BRZ
| The Following User Says Thank You to cjd For This Useful Post: | smg1138 (04-08-2018) |
#3184 |
#3185 |
Drives: 2017 BRZ
For the Shorai? Personally, I'd run it just because it does a cell balance, but I imagine you can get away without a tender. You probably won't get quite the same life-span out of the battery. Shorai has all sorts of notes that are probably worth reading through just to get a sense of what they recommend...
#3186 |
Drives: 2014 Subaru BRZ
I don't use a tender with mine since I daily it, but if you are gone for 4+ days it can go flat (you could just disconnect the battery since it won't self-discharge, but a small parasitic drain from OBDII or other stuff will deplete it after 4-6 days without driving).
#3187 |
Drives: 2015 CWP BRZ
As for the 245 vs 255 debate, I prefer the 255 RE71 over the 245 RE71. The overall grip seems to be a bit better and can handle heat better than the 245. Also the 245 had much quicker shoulder wear.
With that said, I’d like to try a 245 Rival S 1.5 to see how it works out with the heat and shoulder wear. |
#3188 |
Drives: 2013 Satin White Pearl BRZ
#3189 |
For you guys using the Shorai battery, where did you get the brass terminals for connecting the cables? Doesn't look like the battery comes with them.
#3190 | |
Drives: 2013 FRS
Odyssey SAE Terminals https://www.amazon.com/dp/B004QCBM28?ref=yo_pop_ma_swf Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
| The Following 2 Users Say Thank You to bmacfrs For This Useful Post: | smg1138 (04-09-2018), strat61caster (04-10-2018) |
#3191 |
I went ahead and ordered a Shorai LFX36L3-BS12 battery. Will keep my 35 lb Wal-Mart battery in storage until next winter. Really looking forward to removing about 30 lbs from the front end!
#3192 | |
Drives: 4 wheels
How many days did you leave the adapter? I left mine in the car before and the car started 2 weeks later. Do you have the OBDLink? |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
