Old 02-03-2014, 10:49 PM   #3151
TemeCal
Drives: 86
Originally Posted by swift996 View Post
97 lb ft
Whoa...you may want to double check that! I show 12Nm, which comes to 8.8 ft lb. Where did you get 97 ft lb?
TemeCal is offline   Reply With Quote
Old 02-03-2014, 10:51 PM   #3152
TemeCal
Drives: 86
Originally Posted by xxscaxx View Post
Told ya Glad they came right out.
You were right! I actually started drilling, to use an extractor. I noticed the bolt wiggling, and swapped tools for a pick (compliments of your suggestion!). After that one, a center punch and pick worked beautifully.
Thanks!
The Following 2 Users Say Thank You to TemeCal For This Useful Post:
Ryan86 (02-03-2014), xxscaxx (02-03-2014)
Old 02-03-2014, 10:52 PM   #3153
xxscaxx
Drives: 2013 SWP BRZ
Thanks!
no problem man. Glad I saved you some trouble. I originally thought I was going to have to drill and extract, then my buddy was like "did you even check to see if its broken loose?" Then I felt like an idiot because I didn't, haha.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
TemeCal (02-03-2014)
Old 02-03-2014, 10:53 PM   #3154
wrxgoose
WUB WUB
Drives: 2013 Firestorm
they finally posted the vid of my dyno run. you can see the big black cloud. :/
https://www.facebook.com/photo.php?v...type=2&theater
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
kbogarto (02-26-2014)
Old 02-03-2014, 10:59 PM   #3155
swift996
swift996's Avatar
That's what innovate wrote on my bag. I only torqued to 27 i think.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-03-2014, 11:01 PM   #3156
TemeCal
Drives: 86
Interesting. Sounds like we need to get to the bottom of this. Page 18 of the manual shows 8.8 ft lbs, which is quite a bit lower.
Thanks for the response. Hopefully we can figure out which is correct! I'd hate to under OR over torque these bolts.
swift996 (02-03-2014)
Old 02-03-2014, 11:14 PM   #3157
xjohnx
Grip>Slip
xjohnx's Avatar
They wrote 97 inch pounds on my bag
The Following User Says Thank You to xjohnx For This Useful Post:
Calum (02-04-2014)
Old 02-03-2014, 11:18 PM   #3158
xjohnx
Grip>Slip
xjohnx's Avatar
97 inch pounds = 8.08 ft/lbs, no? not 8.8, but pretty close.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Calum (02-04-2014), swift996 (02-04-2014)
Old 02-03-2014, 11:21 PM   #3159
TemeCal
Drives: 86
Ding, ding, ding. I think we have figured it out Great work!
Old 02-03-2014, 11:43 PM   #3160
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by CK_Bladesmith View Post
P219A = Bank 1 Air-Fuel Ratio Imbalance and P2096 = Post catalyst fuel trim system too lean bank 1
I recall getting these codes after installing the IC SC, send the codes to your tuner, if I'm not mistaken, it's tune related.
What MAP sensor you using?
Ryan86 is offline   Reply With Quote
Old 02-03-2014, 11:44 PM   #3161
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Stock map sensor. Should I upgrade?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 02-03-2014, 11:52 PM   #3162
Ryan86
Road Warrior
Ryan86's Avatar
I don't wish on anyone to go through the issues I expirienced installing the kit.
But it's is a relief to know I'm not the only one,. I kept having thrown at me that nobody else is having the issues I've reported.
Keep that list of problems going, I believe there are definitely hardware issues that the manufacturer must sort out.
The Following 2 Users Say Thank You to Ryan86 For This Useful Post:
TemeCal (02-04-2014), xxscaxx (02-04-2014)
Old 02-03-2014, 11:54 PM   #3163
Ryan86
Road Warrior
Ryan86's Avatar
I'm on stock MAP with Delicious Tune. Who is your tuner?
Old 02-04-2014, 12:12 AM   #3164
CK_Bladesmith
Drives: Raven FR-S
Innovate Supercharger Owners Topic
My tune is through delicious as well
Edit: I also found that I've got a minor leak where the lines are crimped going into the coolant bottle.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
